  • 2915阅读
  • 2回复
本周末比赛。喜欢rtty的进来 [复制链接]
离线ba2ia
只看楼主 倒序阅读 0楼 发表于: 2008-09-04
感谢5ham提供比赛信息并翻译~
russian radio rtty ww contest
starting 2004 this contest is moved to the first saturday of september, contest period is decreased to 24 hours, contest logs are simplified and sosb entry terms are clarified. other contest rules are the same as they were for previous years. please modify your contest calendar!
date: 00.00 – 24.00 utc september 6, 2008
bands: 10 – 80 meters, no warc bands.
mode: rtty, one contact with same station on each band is permitted.
entry: single op – all bands, single op – single band, multi op – all bands – single tx, swl. single op – single band stations may operate during contest on all bands and claim score only for one band. contest exchange: russian stations – rst plus two letters (oblast designator), all others – rst plus waz zone.(信号交换方式: 俄罗斯电台: rst + 两个字母的省代号, 其它电台: rst + waz分区号)
points: 5 points for qso inside own continent, 10 for contacts outside own continent.(qso分数计算: 与本着洲电台的一次qso得5分, 与本洲外的电台一次qso得10分)
multiplier: each russian oblast and dxcc country give 1 point for multiplier on each band.(系数分计算方法: 每通到一个俄罗斯的省或 dxcc 国家得到 1 个系数分)
score: the sum of qso points is multiplied by the sum of multiplier points to obtain the final contest score. (总成绩计算方法: 总qso分数 x 总系数分)
log: cabrillo format logs are preferred but other ascii logs are acceptable too. no dupe or multiplier lists are now required. e-mail address is contest@radio.ru . please send logs as attachment and include your call-sign in subject field. address for paper logs is: radio magazine, seliverstov per. 10, 107045 moscow, russia. (竞赛日志提交方式: cabrillo 格式, 电子邮件地址: contest@radio.ru )
awards: the soab winner will be awarded with medal, moab winner – with plaque. additional medals for sosb entries may be issued if contest activity returns. their runners up (2nd and 3d place) as well as country leaders (provided if their score is higher than 1/3 of the winner) will be awarded with contest certificates.
离线BA4KW
只看该作者 1楼 发表于: 2008-09-05
rtty不错 就是眼睛累些(弄副墨镜戴上先)
ims这次记得我的劝告 不要再把电源搞挂了
离线welkin
只看该作者 2楼 发表于: 2008-09-05
参与下,不过要下午才有空,天线还要临时架
