  • 7040阅读
  • 32回复
想买个外置声卡玩软件无线电,有什么推荐? [复制链接]
离线bg7jdy
只看楼主 倒序阅读 0楼 发表于: 2008-08-11
usb 或火线接口都行,承受力有限,最好便宜点。
96khz取样,似乎好点哦。
离线BG6QBY
只看该作者 1楼 发表于: 2008-08-11
买个创通的,好得很,淘宝大把
离线bg7jdy
只看该作者 2楼 发表于: 2008-08-11
是不是创新阿?我要外接的。
离线radiolee
只看该作者 3楼 发表于: 2008-08-11
MOTU 828-MKII 1394口
cuemix dsp? near-zero monitoring system.
front-panel control - access your entire mix, or any 828mkii setting, directly from the front panel.
stand-alone operation - program your mixes at the studio and then bring the 828mkii to your gig - no computer needed. need to tweak the mix? do it on site using the back-lit lcd and front-panel controls.
multiple cuemix dsp mixes - create different monitor mixes for the main outs and headphones. add send/return loops for outboard gear - with no latency.
two mic pre-amps with switchable 48-volt phantom power, front-panel trim controls and pre-amplified sends.
mic/guitar instrument sends - add your favorite outboard eq, preamp, reverb or other processor to the two mic/guitar inputs, before the signal goes digital.
20 inputs / 22 outputs - there's no channel sharing in the 828mkii; the mic inputs, s/pdif i/o, headphone out and main outs are all handled as separate channels.
8 channels of 24-bit adat optical input/output. eight channels at 44.1/48khz. four channels at 88.2/96khz.
sample-accurate digital transfers between adat digital tape decks and the computer via the adat sync port.
sample-accurate midi - connect a midi controller and/or sound module with no separate interface needed. midi i/o is sample-accurate with supporting software.
expandable - add additional 828, 828mkii or 896 firewire interfaces for additional i/o.
eight 24-bit 96khz analog inputs and outputs on balanced/unbalanced 1/4" trs jacks
separate trs main outs and front-panel headphone jack, each with independent volume control.
stereo 24-bit 96khz s/pdif in/out
word clock in and out
smpte in and out
includes drivers for mac & pc, including asio, wdm, wave, gsif, core audio, and core midi. supports all popular macintosh and windows audio software.
100% compatible with all host-based effects processing in today's popular audio programs.
includes audiodesk full-featured sample-accurate workstation software for the macintosh with recording, editing, mixing, real-time 32-bit effects processing & sample-accurate sync.
two firewire ports for daisy-chaining without a hub
front panel volume control for main outputs.
front panel headphone jack with independent volume control.
front panel meters for all analog, digital and midi i/o, plus smpte sync tach and lock leds.
dedicated front panel clock status leds.
离线bg7jdy
只看该作者 4楼 发表于: 2008-08-11
楼上的motu 828 最便宜4300,我无力承受。
离线radiolee
只看该作者 5楼 发表于: 2008-08-11
Konnekt 8 1394口
konnekt 8是konnekt 24d的简化版,也就是不带konnekt 24d的dsp芯片,不具备dsp效果器,是一个纯粹的音频接口。
konnekt 8主要特性:
带有两个impact话放,使用xle/trs混合接口,不仅可以连接话筒,还可以连接吉他高阻信号和线性信号
一对平衡输出,两对平衡输入
一对同轴spdif数字输入/输出接口
使用火线与电脑连接
提供一进一出midi接口
可通过面板上的旋钮来对多个重要参数做实时调节
赠送cubase le
使用tc自己的near专利技术,可使你同时连接4台konnekt 8或24d,获得更多的输入/输出通道数
使用dice ii数字芯片,可提供非常稳定的时钟源
可在windows xp和mac os x下使用,支持intel-mac
驱动支持asio、wdm、core audio
离线radiolee
只看该作者 6楼 发表于: 2008-08-11
Focusrite Saffire PRO 10 i/o 1394口
商品资料:
saffire pro 10 i/o可以看作是saffire pro 26 i/o的简化版火线音频接口,8进8出模拟接口。依然是机架版,前置话放跟绿系列一样。
saffire pro 10 i/o主要特性:
8个模拟输入,带跟绿系列一样的话放
每个输入通道都带高通滤波器
前两个输入通道可切换为高阻
8个平衡大三芯输出
midi输入/输出
spdif输入/输出
两个可独立控制音量的耳机输出
可通过火线直接供电,但无法获得最佳的动态
离线radiolee
只看该作者 7楼 发表于: 2008-08-11
motu 828是对性能的选择;
k8是对价格的选择。
请忘了usb吧。
无论哪一款,买回后改一个通道,运放换尽可能大动态的,供电尽可能用到极致,以使前端获得可以得到的最大的动态范围。详见delta44 for sdr1000改造方案。
离线迷思
只看该作者 8楼 发表于: 2008-08-11
玩外围声卡就不要玩usb的,直接上火线的,有便宜的2k左右。
离线小比尔/5
只看该作者 9楼 发表于: 2008-08-11
我用的是creative sb usb lx
300元左右,但是只能上48khz
离线bg7jdy
只看该作者 10楼 发表于: 2008-08-11
火线最便宜的也要5百多哦.
离线radiolee
只看该作者 11楼 发表于: 2008-08-11
火线最便宜的也要5百多哦.
如果只玩sdr,建议选一块支持asio,core audio驱动的火线接口卡就是了。如果顺带玩音频,那就多带个gsif就行了。现在电脑快了,有没有dsp倒不是那么重要
忘了usb吧
离线Receiver
只看该作者 12楼 发表于: 2008-08-11
大家都说不要用usb的,能说说是为什么吗?实时性不及1394?
不知radiolee大侠能不能介绍一下echo的audiofire2如何?
离线bg7jdy
只看该作者 13楼 发表于: 2008-08-12
berhringer fca202 这个声卡怎样?
http://ch.midifan.com/m_techarticle/detail.aspx?id=786
离线radiolee
只看该作者 14楼 发表于: 2008-08-12
audiofire2 外置盒12v供电,最好能改一下+-15v,运放输入部分啥好用啥。火线卡不像那种pci卡那样,有的只用一片via的烂芯片……
usb不是说速度不够快,而是包延时不及pci和1394,因为上asio的用意就是0延时,所以几乎可以这么说,用usb口的声卡只适用于民用场合。
creative公司只有emu的产品(n年前财大气粗把emu给买下来了)才是专业的,除了emu部门,其他的产品都属于民用的
离线radiolee
只看该作者 15楼 发表于: 2008-08-12
就音频用途来说,此卡只适合现场演出。没用过,具体不详。买了好卡,除了sdr,您就没想过给plmm录录歌什么的?
离线radiolee
只看该作者 16楼 发表于: 2008-08-12
另外,我想告诉大家,买专业声卡的好处不只在可以玩sdr。
你可以把电台的af pa前的输出,接入声卡line in。然后使用vsti插件可以轻松实现af dsp。由于电台是单声道,那么另外一路可以接mic输入,line out接电台mic,实现硬件人声压缩,以优化ssb发射效果。如果有高手,可以找到delphi环境的vsti sdk,做if dsp(这就是sdr了)。而且,如果是af dsp,一来可以多路,比如现场有8个电台在工作,使用一块卡就可以搞定;二来就是,有些好一些的卡,内置2-8路dsp,并可以外扩至64个dsp并行处理,做硬件eq,人声压缩,采样降噪,门,都是很有用处的
离线bg7jdy
只看该作者 17楼 发表于: 2008-08-12
从来没有想过,现在现场想想,也没有什么可录.
离线radiolee
只看该作者 18楼 发表于: 2008-08-12
从来没有想过,现在现场想想,也没有什么可录. [表情]
那就房间里架摄像机,放电容话筒,反正有48v镜像电源什么的。摄像机要fullhd的,无论图像还是声音全面超越成灌西! 注意,有asio的声卡,还可以 “听湿录干” 呢
离线小比尔/5
只看该作者 19楼 发表于: 2008-08-12
也有不使用vst的,不过好像是用dx的,略有点延时(类似回音)。
以前坛子上见过,现在本本挂了暂时看不了~
