  • 7396阅读
  • 39回复
有鱼竿的可以试试这个:40m 端馈 ( 重新上图 ) [复制链接]
离线bd1len
只看楼主 倒序阅读 0楼 发表于: 2008-08-01
来源:
a 40m vertical
http://www.southgatearc.org/news/march2006/40metre_vertical.htm
画了张图,方便自制时参考 :d
原图有误,线圈只画了18圈,接线位置不对。重新上传了图。
哪位知道18号漆包线是多粗的?
原文中这样写:把馈线芯接到天线那端的第9圈,在我的图里把顺序反着说了,所以是第十圈
离线火腿蛋
只看该作者 1楼 发表于: 2008-08-01
效率怎样呢,感觉挺好玩。
离线BG7AQD
只看该作者 2楼 发表于: 2008-08-01
线圈是密绕还是间绕?
离线BA1IO
只看该作者 3楼 发表于: 2008-08-01
来源:
a 40m vertical
画了张图,方便自制时参考 :d
我的天条要还了!准备这个!
离线BG9ADQ
只看该作者 4楼 发表于: 2008-08-01
原贴打不开。猜一下:
间绕,每匝占4mm间距:4x18=72mm.
离线bd1len
只看该作者 5楼 发表于: 2008-08-01
重新上图了,请看1楼新图
离线bd1len
只看该作者 6楼 发表于: 2008-08-01
如果用1毫米直径的线,线长为:
64*3.14*19 = 3830.4 mm = 3.83 米
不知这么算是不是符合线圈的要求
不行就多绕两圈然后调整
离线bd1len
只看该作者 7楼 发表于: 2008-08-01
我的天条要还了!准备这个!
做个手动的吧,调谐范围可能更大
离线bd1len
只看该作者 8楼 发表于: 2008-08-01
线圈是密绕还是间绕?
我觉得应该是间绕
离线bd1len
只看该作者 9楼 发表于: 2008-08-01
原贴打不开。猜一下:
原地址需要用代理才能上 :confused:
离线bd1len
只看该作者 10楼 发表于: 2008-08-01
原文:
a 40m vertical
let me first say i make no claims of originality for this item. it is intended as a simple, inexpensive solution for the newcomer to experiment across the 40m band (7.0–7.2mhz) when only restricted space is available. “a picture speaks a thousand words” so by including a couple i’ll keep it as short as possible!
with the rally season upon us, it is an ideal time to pick up those bits and pieces with which to experiment. the antenna described here consists of a 50r coax fed, inductor loaded 5.44m vertical section mounted on a 1m alloy tube driven into the ground and requires no radials although this may well depend on the local soil structure.
the vertical itself is a salvaged unit (probably ex. cb) consisting of 4 telescoping aluminium sections with an extended length of 5.44m and its mounting bracket.
the thick wire in the picture is the coax centre connection from the bracket mounted so239 connector to the coil.
the coil is of open air construction, 19 turns of 18 gauge copper wire equally spaced over a length of 72mm with an inside diameter of 63mm and with the coax centre connected 9 turns from the antenna end of the coil and to the opposite end of the coil. i know this may seem strange but it works.
connect to a transceiver, check the swr and if necessary adjust the antenna length or coil tap slightly and away you go, it’s that simple!
with the antenna set to resonate at 7.1mhz i found there was little need for adjustment by the internal atu of my ts2000 or ft1000mp-mkv to cover the entire band.
copyright david barber g8oqw
离线bd1len
只看该作者 11楼 发表于: 2008-08-01
[quote=火腿蛋]效率怎样呢,感觉挺好玩。[/quote]
没试过,准备找点材料做一个
离线BA1IO
只看该作者 12楼 发表于: 2008-08-01
做个手动的吧,调谐范围可能更大
:d
离线BA4XA
只看该作者 13楼 发表于: 2008-08-01
awg18   1.02mm
离线BG2STN
只看该作者 14楼 发表于: 2008-08-01
学习了!好贴
离线bd1len
只看该作者 15楼 发表于: 2008-08-02
awg18   1.02mm
多谢,看来按1mm算就可以了 :rolleyes:
离线bd1len
只看该作者 16楼 发表于: 2008-08-02
算了一下电感量,不知道该听谁的 :confused: :confused:
离线BH1FCZ
只看该作者 17楼 发表于: 2008-08-02
用的是什么软件,可否发一份,我也想玩玩,tjafz@hotmail.com谢谢
离线憨五弟
只看该作者 18楼 发表于: 2008-08-02
再加个电容,和这个半波天线就一样了
http://www.hellocq.net/forum/showthread-t-105409.html
离线四大侠
只看该作者 19楼 发表于: 2008-08-02
18号漆包线就是铜芯的横截面积为1平方毫米。
