  • 3294阅读
  • 4回复
有人用AOR AR-5000吗? [复制链接]
离线zsh
只看楼主 倒序阅读 0楼 发表于: 2008-07-29
frequency range: 100 khz to 2036 mhz (cellular blocked)
receive modes: am, fm, usb, lsb, cw
nominal filter bandwidths: 3 khz, 6 khz, 15 khz, 30 khz, 110 khz & 220 khz (provision for 500 hz option)
tuning steps: 1, 10, 50, 100, 500 hz, 1, 5, 6.25, 9, 10, 12.5, 20, 25, 30, 50, 100 and 500 khz
typical sensitivity: 10 - 20 mhz
0.56µv am 6 khz filter10db s/n
0.25µv ssb 3 khz filter10db s/n
0.36µv fm 6 khz filter12db sinad
0.56µv fm 15 khz filter12db sinad
90 - 150 mhz
0.50µv am 6 khz filter10db s/n
0.20µv ssb 3 khz filter10db s/n
0.25µv fm 6 khz filter12db sinad
0.28µv fm 15 khz filter12db sinad
0.50µv fm 30 khz filter12db sinad
0.80µv fm 110 khz filter12db sinad
1.12µv fm 220 khz filter12db sinad
400 - 700 mhz
0.23µv ssb 3 khz filter10db s/n
0.28µv fm 6 khz filter12db sinad
0.32µv fm 15 khz filter12db sinad
1.80µv fm 110 khz filter12db sinad
1.25µv fm 220 khz filter12db sinad
1.6 - 2.6 ghz
0.36µv am 6 khz filter10db s/n
0.14µv ssb 3 khz filter10db s/n
0.20µv fm 6 khz filter12db sinad
0.22µv fm 15 khz filter12db sinad
0.40µv fm 30 khz filter12db sinad
0.63µv fm 110 khz filter12db sinad
0.90µv fm 220 khz filter12db sinad
memory channels: 2000 (100ch x 20 banks)
memory scan speed: 45 channels/second (max)
search speed: 45 increments/second 9max with step size of 100khz or less)
pass frequency: 2100 total
aerial input: 50 ohm undalanced. n-type & so239
audio output: 1.7 watts into 8 ohms (@ 13.5v) @ 10% distortion
power requirements: nominal 12 vdc, @ 1 amp or less
dimensions: 8.5x3.5x10 inches (217x100x260 mm).
weight: 7.8 lbs. (3.5kg)
离线bg7nf
只看该作者 1楼 发表于: 2008-07-30
家里躺着一个,有什么可以帮你吗?
离线7600
只看该作者 2楼 发表于: 2008-07-30
家里躺着一个,有什么可以帮你吗?
  让给他啊………
离线zsh
只看该作者 3楼 发表于: 2008-07-30
哈哈 ls厉害 很想拥有这机器 想找渠道。。。。。。。。。。嘿嘿
离线菠萝蜜
只看该作者 4楼 发表于: 2008-08-03
家里躺着一个,有什么可以帮你吗?
想要。。。。。。。。转吗?
