  • 3214阅读
  • 8回复
PLL Performance, Simulation, and Design (文件有问题,已经重新上传了) [复制链接]
离线bg8am
只看楼主 倒序阅读 0楼 发表于: 2008-07-23
这本书不错,可以解答你在pll设计和应用中碰到的很多问题
table of contents
pll basics ......................................................................................................................................................7
chapter 1 basic pll overview ....................................................................................................................9
chapter 2 the charge pump pll with a passive loop filter............................................................12
chapter 3 phase/frequency detector theoretical operation.......................................................14
chapter 4 basic prescaler operation .....................................................................................................22
chapter 5 fundamentals of fractional n plls ...................................................................................27
chapter 6 delta sigma fractional n plls ............................................................................................32
chapter 7 the pll as viewed from a system level .............................................................................36
pll performance and simulation................................................................................................41
chapter 8 introduction to loop filter coefficients.........................................................................43
chapter 9 introduction to pll transfer functions and notation................................................48
chapter 10 applications for pll other than a signal source........................................................54
chapter 11 reference spurs and their causes ......................................................................................64
chapter 12 fractional spurs and their causes.....................................................................................77
chapter 13 other types of spurs and their causes.............................................................................92
chapter 14 pll phase noise modeling and behavior........................................................................100
chapter 15 integrated phase noise quantities ..................................................................................112
chapter 16 transient response of pll frequency synthesizers ..................................................125
chapter 17 impact of pfd discrete sampling effects on lock time............................................138
chapter 18 routh stability for pll loop filters ............................................................................148
chapter 19 a sample pll analysis.........................................................................................................153
pll design .................................................................................................................................................167
chapter 20 fundamentals of pll passive loop filter design........................................................169
chapter 21 equations for a passive second order loop filter.....................................................174
chapter 22 equations for a passive third order loop filter........................................................178
chapter 23 equations for a passive fourth order loop filter.....................................................186
chapter 24 fundamentals of pll active loop filter design.........................................................198
chapter 25 active loop filter using the differential phase detector outputs ....................209
chapter 26 impact of loop filter parameters and filter order on reference spurs............212
chapter 27 optimal choices for phase margin and gamma optimization parameter ............220
chapter 28 using fastlock and cycle slip reduction......................................................................228
chapter 29 switched and multimode loop filter design................................................................235
chapter 30 dealing with real-world components...........................................................................239
chapter 31 partially integrated loop filters..................................................................................243
additional topics................................................................................................................................277
chapter 32 lock detect circuit construction and analysis.........................................................279
chapter 33 impedance matching issues and techniques for plls .................................................286
chapter 34 crystal oscillators and vcos .........................................................................................293
chapter 35 other pll design and performance issues ....................................................................317
supplemental information...........................................................................................................325
chapter 36 glossary and abbreviation list........................................................................................327
chapter 37 references and credits .......................................................................................................336
离线bg7vi
只看该作者 1楼 发表于: 2008-07-23
已经下载,谢谢!
离线TITAN-ZY
只看该作者 2楼 发表于: 2008-07-23
好东西,谢谢了!
离线acbear
只看该作者 3楼 发表于: 2008-07-23
pdf文件损坏,32页后面全是空白。
离线bg8am
只看该作者 4楼 发表于: 2008-07-23
pdf文件损坏,32页后面全是空白。
重新上传了
离线kyughanum
只看该作者 5楼 发表于: 2008-07-23
重新上传了
老样子!!
离线bg8am
只看该作者 6楼 发表于: 2008-07-23
老样子!!
'我下载后打开,没有问题啊
离线bg6qbt
只看该作者 7楼 发表于: 2008-07-23
可以打开没有问题....
离线代洪波
只看该作者 8楼 发表于: 2008-07-23
可以打开了!谢谢楼主!很好的资料,可惜我需要配合金山才看得懂!
