  • 4037阅读
  • 19回复
Invitation for RRTC-2008 [复制链接]
离线bd4ahs
只看楼主 倒序阅读 0楼 发表于: 2008-07-16
dear bd4ahs!
rrtc has a great pleasure to invite you to take part in rrtc held from 07:00 gmt july, 19th, 2008 till 14:59 gmt july, 19th, 2008. 8 hours only!
russian operators will be back at it this weekend, as 21 different two-man teams will use a field day style event to prep for the 2010 world radiosport team championships.
the teams will be set up close together as portable stations, using an agricultural area not far outside of moscow. the rules the teams will use are similar to the wrtc, which will be run in conjunction with the 2010 iaru contest.
rules for rrtc outside participants
1. date and contest period: the saturday of the third full weekend of july (july 19th, 2008) beginning 07:00 utc and ending 14:59 utc. both single and multi operator stations may operate the entire 8-hour period.
2. everybody can work everybody.
3. modes: cw and ssb.
4. bands: 7, 14, 21 and 28 mhz.
5. band and (or) mode can be changed at any time. only one signal is allowed at a time.
6. exchange: outside participants sends rs (rst) and itu zone number. russian radio team championship competitors sends rs (rst) and three-character combination, e.g. 599 xyz.
7. station with the same call-sign may be worked on different bands/modes, to include both modes per band.
8. scoring point system: qso with rrtc station (special call-sign series r33ba-r33fz) - one point. qso with outside participant from the same itu zone - one point. qso with outside participant from different itu zone on the same continent - three points. qso with outside participant from different itu zone on different continent - five points.
9. multipliers: itu zone and new three-character combination received from an rrtc team - one point for the multiplier on each band (regardless of mode). rrtc station gives no itu zone multiplier.
10. the score is the product of total points and total multipliers.
11. entry categories:
a - single operator, mixed (cw and ssb), high power
b - single operator, mixed (cw and ssb), low power (100 w and less)
c - single operator, ssb, high power
d - single operator, ssb, low power (100 w and less)
e - single operator, cw, high power
f - single operator, cw, low power (100 w and less)
g - multi operator team (2 or 3 operators), mixed (cw and ssb).
12. awards: special trophies, certificates and medals will be awarded to the world`s top scoring stations in both the a and g categories. certificates and medals will be awarded to the world's 2nd and 3rd stations in both the a and g categories. certificates will be awarded to the world's top three stations in the b-f categories. achievement commemorative pennants will be awarded to those participants making at least 250 qsos and submitting email logs to ochr(at)srr.ru. logs must be submitted no later than 19:00 utc, july 19th, 2008.
13. logs: any contest logging software can be used which supports iaru hf world championship. only email logs are accepted, cabrillo log format shall be used according to iaru hf championship requirements. file name should be mycall.cbr where mycall is your callsign.
please send the file as an attachment to ochr@srr.ru during 4 hours after contest, for checking rrtc team 250 qso - and 4 hours sending = t-shirt rrtc
thank you and see you in rrtc 2008
离线bd4ahs
只看该作者 1楼 发表于: 2008-07-16
rrtc从2008年7月19日gmt0700(bjt1500)至2008年7月19日gmt1459(bjt2159)持续8个小时比赛。
这个周末,俄罗斯操作员以field day的形式作为2010国际无线电锦标赛的热身赛。
参赛队们都是移动台,彼此距离较近,设台地点是莫斯科郊区的一个农场。参赛规则同wrtc相同。
1、比赛时间只有8个小时(7月份第三个周末的周日gmt0700~gmt1459)
2、每个人都可以参加
3、模式:cw和ssb
4、波段:7、14、21、28mhz(40米、20米、15米、10米)
5、波段和(或)模式任何时间都可以改变,但是同一时间只允许一个信号出现
6、信号交换:户外的参加者交换rs(rst)+itu分区号,rrtc成员给出rs(rst)+3个字符组合,例如:599+xyz
7、相同呼号的电台可以工作在不同的波段/方式,包括同一波段的不同模式。
8、计分系统:和rrtc台(特殊呼号:r33ba~r33fz)qso1次得1点。和相同itu分区号的户外参与者qso 1次得1点。和同一洲不同itu分区号的户外参与者qso 1次得3点。和不同洲不同itu分区号的户外参与者qso 1次得5点。
9、倍数:itu分区号和从rrtc处获得一个新的3字符组合 - 每个波段获1点的倍数(与模式无关)。rrtc电台提供没有itu分区号倍数(不知道什么意思)
10、总分是全部的点数和全部的倍数的乘积
11、分组:
a-单人混合高功率
b-单人混合低功率(100w以下)
c-单人ssb高功率
d-单人ssb低功率
e-单人cw高功率
f-单人cw低功率
g-多人(2-3人)混合
12、奖状
13、log提交:很多电台日志软件都提供iaru hf比赛的模式。只接受email log,根据iaru hf锦标赛的需要,使用cabrillo日志格式。文件名为:呼号.cbr
在比赛后4小时将日志文件作为附件发送到ochr@srr.ru,rrtc qso 250个,工作4小时,可以得到t-shirt rrtc(真的吗)
离线BD1VWI
只看该作者 2楼 发表于: 2008-07-16
这个比赛如何呼叫?
离线bg3apx
只看该作者 3楼 发表于: 2008-07-17
谢谢,详细地介绍!
离线gning
只看该作者 4楼 发表于: 2008-07-18
一样收到邮件一封,明天下午参与一把。
离线bg3apx
只看该作者 5楼 发表于: 2008-07-18
一样收到邮件一封,明天下午参与一把。
老朋友好,祝玩儿得高兴。
离线BD4IXA
只看该作者 6楼 发表于: 2008-07-18
楼上的二位老大,我就听你们玩儿了
离线BD1VWI
只看该作者 7楼 发表于: 2008-07-19
玩了会,现在已经结束了。大家成绩如何?
离线BG2RST
只看该作者 8楼 发表于: 2008-07-19
本来想参加的,有事情回来晚了,听个尾巴~~ uw2m
离线bg3apx
只看该作者 9楼 发表于: 2008-07-19
玩了会,现在已经结束了。大家成绩如何?
北京时间23点结束。
离线BD1VWI
只看该作者 10楼 发表于: 2008-07-20
北京时间23点结束。 [表情]
又看了遍规则,确实是23点结束。思来想去,原来是2楼老大翻译的帖子中写成21点59结束了。 没什么收获,草草结束了。倒是在spot上面看到了bd3apx大佬一直在14008附近,祝取得好成绩!
离线BA4TB
只看该作者 11楼 发表于: 2008-07-20
他们的成绩出来了,不过是俄文,看不懂。
Технические результаты участников Очного Чемпионата Российской Федерации
          по радиосвязи на коротких волнах 2008 года
Место Состав команды   З а я в л е н о   П о д т в е р ж д. Штраф   Итого
              Связей Множ. Очков Связей Множ. Очков       очков
1 rw1ac   ra1aip   1205 372 448260   1138 351 399438   -   399438
2 rw3qc   rn3qo   1190 340 404600   1118 326 364468   5%   346244
3 ua3qdx rk3qs   1192 299 356408   1148 289 331772   -   331772
4 ru9wx   rx9wr   1192 304 362368   1131 292 330252   -   330252
5 ua9sp   ua9tq   1129 330 372570   1059 311 329349   -   329349
6 ra1zz/3 rl3fo   1180 334 394120   1123 325 364975   10%   328477
7 rv3ba   ra3co   1237 328 405736   1180 324 382320   15%   324972
8 ua3dpx rl3ft   1148 304 348992   1089 297 323433   -   323433
9 rw6hx   rw6ha   1012 345 349140   965 335 323275   -   323275
10 rw4wr   ru4hp   1068 312 333216   1017 304 309168   -   309168
11 rn4wa   rw4wm   1131 308 348348   1040 284 295360   -   295360
12 ra9aa   rz9ar   1056 299 315744   1019 289 294491   -   294491
13 ra3tt   ua3tu   1042 285 296970   987 283 279321   -   279321
14 rx9tl   rz9sz     986 274 270164   942 267 251514   -   251514
15 rz9oo   ua9onj   991 290 287390   909 275 249975   -   249975
16 ua9clb ua9cdv   1042 300 312600   860 282 242520   -   242520
17 rv3aca rn3az     954 275 262350   911 265 241415   -   241415
18 ua4pn   rw4py     938 280 262640   860 262 225320   -   225320
19 rv9whn rv9wle   897 277 248469   840 265 222600   5%   210470
20 ua4hox ua4hbw   820 252 206640   760 242 183920   -   183920
21 rw3ta   ra3tyl   778 241 187498   703 224 157472   -   157472
                Главный судья, СРК         М.И.Клоков
                Главный секретарь, СВК       З.А.Гераськина
Штрафы:
ra1zz/3 rl3fo - за самоидентификацию
rw3qc   rn3qo - плохое качество аудиозаписи
rv3ba   ra3co - отсутствие аудиозаписи, отсутствие переданных контрольных номеров
rv9whn   rv9wle - за другой формат времени
离线gning
只看该作者 12楼 发表于: 2008-07-21
[表情] [表情]
老朋友好,祝玩儿得高兴。
我是瞎闹,听老兄你和别人通时一叫就通,我是同一个台叫了n遍对方听不到。呵呵!
离线bg3apx
只看该作者 13楼 发表于: 2008-07-21
我是瞎闹,听老兄你和别人通时一叫就通,我是同一个台叫了n遍对方听不到。呵呵! [表情]
中间停顿了大约4个小时,正式晚8点开始,感觉传播滞后了;快结束时传播有点上来了---奇怪。15m,10m,40m感觉不太好 玩儿个高兴。
谢谢您老,欢迎到天津来。
离线BD4IXA
只看该作者 14楼 发表于: 2008-07-21
他嗓门大, 嘿嘿
离线BD1FBV
只看该作者 15楼 发表于: 2008-07-22
几个老朋友出来了!通联愉快!
离线BD1FBV
只看该作者 16楼 发表于: 2008-07-22
他们的成绩出来了,不过是俄文,看不懂。
蒙着看懂了大概:裁判公布比赛结果
名次,队员组合,声明成绩,核对成绩,罚分百分比,最后总分
罚分(原因)
ra1zz/3 rl3fo - 自我识别(?)
rw3qc   rn3qo - 听写成绩差(?)
rv3ba   ra3co - 缺少听写,缺少传送检查号码(?)
rv9whn rv9wle - 使用其它时间格式
离线BD1FBV
只看该作者 17楼 发表于: 2009-07-14
rrtc-2009 又来了。规则没变,但俄罗斯比赛队少了2只,而且比赛日期前后矛盾:
rrtc has a great pleasure to invite you to take part in rrtc held from 07:00 gmt july, 18th, 2009 till 14:59 gmt july, 18th, 2009. 8 hours only!
russian operators will be back at it this weekend, as 19 different two-man teams will use a field day style event to prep for the 2010 world radiosport team championships.
1. date and contest period: the saturday of the third full weekend of july (july 19th, 2009) beginning 07:00 utc and ending 14:59 utc. both single and multi operator stations may operate the entire 8-hour period.
离线bg7nwf
只看该作者 18楼 发表于: 2009-07-14
能告诉 bjt 的时间吗??
离线BD1FBV
只看该作者 19楼 发表于: 2009-07-15
能告诉 bjt 的时间吗??
应该是7月18日(周六)15:00-23:00bjt吧?
