  • 2174阅读
  • 2回复
Russian Radio Team Championship 2008 [复制链接]
离线BA7NQ
只看楼主 倒序阅读 0楼 发表于: 2008-06-12
the following information was published in may on the website of srr (russian amateur radio union).
--dmitri (rw3fo) db@mai.ru
russian radio team championship 2008
about the contest
the russian radio team championship (rrtc) is an annual head to head "field day" style competition which is organized by the russian amateur radio union (soyuz radiolyubitelei rossii - srr), originating in the ussr in 1980. in 2008, twenty teams of two operators will be invited, which represent the many different regions of the russian federation. on the threshold of the approaching wrtc-2010 event, the rules of the competition were changed to closely mirror those of the upcoming wrtc, and the rules for outside participants were also adapted to mirror those of iaru hfc. so, the russian radio team championship can be considered as a "dress rehearsal" of the future wrtc event.
in 2008, participants will be competing in the greater moscow region, about 60 km to the south from the city, a flat rural area which is mainly agricultural in nature. the distance between team positions is roughly 0.5 kilometer, so the antennas of the nearest two or three teams will be visible from each operating position. organizers will supply teams with food, identical tents, tables, chairs, 220 v gas generator and gasoline, 10m-high steel sectioned tower and a tri-band antenna. teams are required to bring their own 100 w (limited) transceivers, computers and peripherals, 40m-band iv dipole, antenna switching devices, filters etc. participants of russian radio team championship are also responsible for base camp set-up, as well as all antenna assembly & tower assembly/raising.
participants can make qsos among themselves and the rest of the world, so everybody is invited to the party. usually the basic activity on the bands is generated by russian radio amateurs; to raise qso rates, the teams use new callsigns and exchanges every two hours. on average, 1300 qsos by the top teams are not uncommon during the eight-hour contest. there is no limitation on band or mode changes, although only one signal can be transmitted at one time.
every team will be accompanied by an official contest referee, who will monitor all actions & the audio signals. each referee will be assigned randomly to teams from a pool of qualified referees provided by teams. the rules for the teams are complete in detail, any deviation from the published rules is strictly prohibited. during the contest period, an audio recording will be made for each team. online scores will be made available via the internet. after the competition ends, email logs will accepted from around the world during a four hour period immediately following the end of the contest. after that, computer checking of the logs will commence, and the final results will be ready the following morning.
so, immediately following iaru hfc 2008, one will have a good chance to check propagation conditions, estimate signal levels of 100w / small tri-bander stations from the heart of russia, and get some advance preparation for wrtc-2010.
1. date and contest period: the saturday of the third full weekend of july (july 19th, 2008) beginning 07:00 utc and ending
14:59 utc. both single and multi operator stations may operate the entire 8-hour period.
2. everybody can work everybody.
3. modes: cw and ssb.
4. bands: 7, 14, 21 and 28 mhz.
5. band and (or) mode can be changed at any time. only one signal is allowed at a time.
6. exchange: outside participants sends rs (rst) and itu zone number. russian radio team championship competitors sends rs
(rst) and three-character combination, e.g. 599 xyz.
7. station with the same call-sign may be worked on different bands/modes, to include both modes per band.
8. scoring point system:
qso with rrtc station (special call-sign series r1ax-r0zx) - one point.
qso with outside participant from the same itu zone - one point.
qso with outside participant from different itu zone on the same continent - three points.
qso with outside participant from different itu zone on different continent - five points.
9. multipliers: itu zone and new three-character combination received from an rrtc team - one point for the multiplier on each band (regardless of mode). rrtc station gives no itu zone multiplier.
10. the score is the product of total points and total multipliers.
11. entry categories:
А - single operator, mixed (cw and ssb), high power.
b - single operator, mixed (cw and ssb), low power (100 w and less).
c - single operator, ssb, high power.
d - single operator, ssb, low power (100 w and less).
e - single operator, cw, high power.
f - single operator, cw, low power (100 w and less).
g - multi operator team (2 or 3 operators), mixed (cw and ssb).
h (for russian stations only) - srr divisions; division score is a total of scores of all participants representing this division.
12. awards:
special trophies, certificates and medals will be awarded to the world's top scoring stations in both the a and g categories.
certificates and medals will be awarded to the world's 2nd and 3rd stations in both the a and g categories. certificates will be awarded to the world's top three stations in the b-f categories.
achievement commemorative pennants will be awarded to those participants making at least 250 qsos and submitting email logs to ochr(at)srr.ru. logs must be submitted no later than 19:00 utc, july 19th, 2008.
13. logs:
any contest logging software can be used which supports iaru hf world championship. only email logs are accepted, cabrillo log format shall be used according to iaru hf championship requirements. file name should be "mycall.cbr" where "mycall" is your callsign. please send the file as an attachment to ochr(at)srr.ru.
离线BA4KW
只看该作者 1楼 发表于: 2008-06-12
来个金山快译搞下 嘿嘿
离线BA5CW
只看该作者 2楼 发表于: 2008-06-12
在莫斯科参赛的队伍比较好玩,我怀疑其他国家的人有多少会响应的。不过他们2小时换个呼号出来应该不愁每台通。
