  • 15830阅读
  • 139回复
与奥运特设台通联之我见 [复制链接]
离线樊绍民
只看楼主 倒序阅读 0楼 发表于: 2008-05-19
奥运特设台将设通联金奖、银奖和铜奖,具体规则将在特设台网站上陆续公布。一两天后,已有通联纪录的朋友,可在网上查询:www.bj2008ses.com.cn
奥运特设台bt1ob、bt1oh、bt1oj、bt1on、bt1oy,其中每个台都将用ssb、cw、和rtty三种模式工作在短波的9个频段(3.8mhz 没有rtty 模式,10mhz没有ssb模式):
1.8mhz     cw   1.800-2.000 mhz
          rtty   1.830-1.834 mhz
          lsb   1.840-2.000 mhz
3.5mhz   cw   3.500-3.900 mhz
          lsb   3.535-3.900 mhz
7mhz     cw   7.000-7.025 mhz
        rtty   7.025-7.040 mhz
        lsb   7.030-7.100mhz
10mhz   cw   10.100-10.150 mhz
        rtty   10.140-10.150 mhz
14mhz   cw   14.000-14.350 mhz
        rtty   14..070-14.112 mhz
        usb   14.100-14.350 mhz
18mhz   cw   18.068-18.168 mhz
        rtty   18.100-18.110 mhz
        usb   18.110-18.168 mhz
21mhz   cw   21.000-21.450 mhz
        rtty   21.070-21.125 mhz
        usb   21.125-21.450 mhz
24mhz   cw   24.890-24.990 mhz
        rtty   24.920-24.930 mhz
        usb   24.930-24.990 mhz
28mhz   cw   28.000-29.700 mhz
        rtty   28.050-28.150 mhz
        usb   28.300-29.300 mhz
这样,如果要和某个特设台在以上9个频段用三种模式都完成通信的话,那就要完成25次通联。如果要和5个特设台都完成三种模式通联,那就是要完成125次通联。
我这样计算不知是否正确?请朋友们指正,讨论。
下帖再接着谈。
ba1eo/樊绍民
离线bv2ac
只看该作者 1楼 发表于: 2008-05-19
到北京一定到到樊老家朝聖... :)
离线樊绍民
只看该作者 2楼 发表于: 2008-05-19
奥运特设台网站新闻:
news release #3 (2008/05/19)
may 19, 2008. china on monday began a three-day national mourning for the tens of thousands of people killed in the may 12 earthquake. 2008 beijing olympic games special event amateur radio station will qrt for 3 days, and will resume from 22 may, 2008.
news release #2 (2008/05/18)
today the 2008 beijing olympic games special event amateur radio station started the first call with sichuan earthquake area amateur radio operators, by8aa (qsped by ba8ab) and chinese red cross foundation front station bt8rc. the first day operation has made 1800+ qsos in the log.
news release #1 (2008/05/13)
the beijing 2008 olympic game special event amateur radio station setup application was approved by the beijing organizing committee for the games of the xxix olympiad (bocog) and state radio regulatory committee (srrc). the first station on air was planned to 18, may, 2008.
特设台第一天完成1800个qso
ba1eo
离线樊绍民
只看该作者 3楼 发表于: 2008-05-19
蔡先生玩笑了!
我和bv2ls、bv2ft是好朋友,可是......唉!
ba1eo
下图左起:ba1one ba1ss bv2ls ba1eo ba1ky ba1ra 照片是ba1cy照的
离线樊绍民
只看该作者 4楼 发表于: 2008-05-19
持三级操作证书的朋友,要注意合法使用频率。
三级允许使用频率:
3.5 mhz   3.570-3.590 mhz
          3.700-3.750 mhz
          3.840-3.860 mhz
7 mhz     7.050-7.075mhz
14 mhz     14.250-14.350 mhz
21 mhz     21.100-21.200 mhz
          21.300-21.450 mhz
28 mhz     28.100-28.500 mhz
          29.200-29.300 mhz
          29.550-29.700 mhz
也希望特设台能照顾三级的朋友,抽出一定时间到三级允许操作的频率上工作。
持四级操作证书的爱好者,只被允许在29.200-29.300和29.500-29.700 mhz频率上工作,和特设台通联的机会很小。
下贴继续。
ba1eo
离线BD1LKK
只看该作者 5楼 发表于: 2008-05-19
好玩,一个人要是完成了1个台的卡片上就没空间拉,请教请辈一个台25次的通连怎样方便写qsl?
离线樊绍民
只看该作者 6楼 发表于: 2008-05-19
完全取决于爱好者本人。申请奖状依据网站log记录就可以了。如果本人希望收藏不同频段、不同模式的通联卡片,那就要寄卡片交换了。不过,可以以包裹形式邮寄。国外有的爱好者,专门申请单频段奖状,他们如果能得到1.8和3.5mhz的中国卡片,那会非常高兴的。
ba1eo
离线BA1RB
只看该作者 7楼 发表于: 2008-05-19
到北京一定到到樊老家朝聖... :)
樊老家里值得一去的。有很多值得一看的地方,特别是单独的电台室...
离线BA1RB
只看该作者 8楼 发表于: 2008-05-19
我觉得可以打印一张纸条,纸条上一行写一个qso就行。同呼号、同模式、同波段的qso不建议多通,交换卡片也是同呼号、同模式、同波段的qso写一个就可以了。
有的远征台规定一张卡片上最多3个qso...
离线BA1RB
只看该作者 9楼 发表于: 2008-05-19
5个台都通了交换一套bjhyn的卡片比较有纪念意义。
离线樊绍民
只看该作者 10楼 发表于: 2008-05-19
1rb说的对,不同时间、不同频段通联同一个电台,可以在一张卡片上完成填写。
例如:vr97sar 给我的一张卡片就是打印后贴上去的。
97-7-1 0111 14mhz ssb 59
97-7-1 0500 21mhz ssb 59
ba1eo
离线bv2ac
只看该作者 11楼 发表于: 2008-05-19
[quote=樊绍民]蔡先生玩笑了!
ba1eo
下图左起:ba1one ba1ss bv2ls ba1eo ba1ky ba1ra 照片是ba1cy照的[/quote]
珍貴的照片..!
這裡是 bv2dk 余民雄先生提供的, 十幾年前在余家拍的, 左起 ba1cy, bv2ls, bv2dk,bv2ft.
离线樊绍民
只看该作者 12楼 发表于: 2008-05-19
谢谢蔡先生! 这是珍贵的历史资料。收藏了!
ba1eo
离线樊绍民
只看该作者 13楼 发表于: 2008-05-21
奥运特设台在全国三天哀悼日结束后,明天将恢复工作。
后附特设台通州基地和顺义基地天线。
ba1eo
离线bd4jk
只看该作者 14楼 发表于: 2008-05-21
避让一些dx网络频率,
展现by电台的大家风范。
如同救灾通信时,我们希望7050
没有qrm
离线樊绍民
只看该作者 15楼 发表于: 2008-05-21
www.bj2008ses.com.cn 网站已经可以查询qso纪录了。资料约每周更新一次。
如果想把所有的空格您都填满(约125个,因为10兆没有ssb模式,3.5兆没有rtty模式),那是非常不容易的!朋友们,努力啊!!!
ba1eo
我首日通了两个台:
离线BA1RB
只看该作者 16楼 发表于: 2008-05-21
樊老好快啊,bt1oj的ssb部分还没有进去,今天晚上应该能上载。
离线樊绍民
只看该作者 17楼 发表于: 2008-05-21
还有一个专门的贴子也贴上了。
希望朋友们与同一个特设台在同一个频段、同一种模式下,不要重复通联。
1rb,我把您的两个邮件转发给几位老先生了。
ba1eo
离线alex911
只看该作者 18楼 发表于: 2008-05-21
这样看来四级操作证书的爱好者能和特设台通联的机会很少啦~ 况且有全模式的机器的四级操作证书的爱好者更少,有点不公平的感觉呀~ 为什么不能在29.550~29.700 mhz 之间选一个频点用fm模式的呢.
离线BG3QAQ
只看该作者 19楼 发表于: 2008-05-21
我个人觉得,这个特设台非常好,但是台址都在京城附近,我们唐山地区的ham离得这么近,很难有效通联啊,想通也难啊!建议全国范围多点设台,波段多点覆盖。
