  • 3282阅读
  • 5回复
751A与751AF [复制链接]
离线BA4KW
只看楼主 倒序阅读 0楼 发表于: 2008-05-19
手头有朋友一台751af
不知道icom搞什么   多出一个f
是不是海外版呢?内部也带500hz滤波器
没发现什么不同 就是脸上写751af
屁股标签还是751a
离线BD3RJ
只看该作者 1楼 发表于: 2008-05-19
图       ?
离线BA4KW
只看该作者 2楼 发表于: 2008-05-19
就是多一个字母f啊   别的跟751a一样的!!不需要图了吧
离线BD3RJ
只看该作者 3楼 发表于: 2008-05-19
general coverage version of ic-751a transceiver, will receive on 100 khz - 30 mhz and transmit on any frequency between 1.6 mhz - 30 mhz, 100 watts output (50 watts am). bought brand new by me from tst in 2003 and very little used, this is a collectors' piece and guaranteed to be in like new condition, complete with original box, manual and supplied hand mic and dc cable/spare fuses and plugs.
basic transceiver operates from 13.8v dc however i am also including the following optional accessories in the asking price (sorry, will not split): ps 35 ac internal psu (already rewired for 230v ac), rc 10 frequency controller for keypad control of frequency, fl 52a 500 hz cw filter (new in box) and new spare nardo ram board (see [home1.gte.net]), although supplied ex 341 ram board still works fine. incidentally, when nardo ram board is installed transceiver can receive 10 khz - 31 mhz and tx from 1.6 mhz - 31 mhz.
price is hk8,000. if interested please email me.
wyn
vr2ax
离线BA4KW
只看该作者 4楼 发表于: 2008-05-19
在eham看到了!!
离线BA4KW
只看该作者 5楼 发表于: 2008-05-19
751af型号求助!
