  • 4095阅读
  • 0回复
New Release of PacTerm and PKTerm [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2008-05-16
creative services software expands radio and tnc support, enhances automation in new release of pacterm and pkterm amateur radio software
for immediate release: dayton, ohio, may 15, 2008—creative services software, inc. (css) will debut a new release of the company's tnc software at the dayton amateur radio association's hamvention,® which gets underway tomorrow at the hara arena. version 3.76.02 of both pactermâ„¢ (for timewave/aea tncs) and pktermâ„¢ (for kantronics tncs) expands the number of radio transceivers that may be pc-operated through a terminal node controller (tnc), adds flexibility to tnc operation, further automates setup, startup and shutdown procedures, expands support to 2000 hz in mt 63 mode, and increases file transfer capabilities.
css expands support for icom, yaesu transceivers
pacterm/pkterm now supports the new icom 7700 and four new yaesu radios, adding the ft-450, ft-950, ft-2000, ft-dx 9000 models. the expanded radio compatibility is in addition to the 66 radios already supported, providing many times greater compatibility than other tnc software solutions.
in addition to new radio support, pkterm also now supports the new timewave dsp-232+ tnc. the plug-and-play dsp-232 is timewave's newest multimode data controller designed around a high-speed digital signal processor. digital signal processing combined with memory arq, true dcd, and hardware hdlc provide advanced signal filtering, modem performance and flexibility.
pacterm/pkterm now offer expanded multitasking power
pacterm and pkterm are already the only available tnc software offering true 32-bit multitasking capability, allowing operators to control radio transmissions and run logging programs, call book programs and any windows application simultaneously. pacterm/pkterm also continues to support dual tncs, allowing radio amateurs to work in hf and packet modes simultaneously as well as two single port tncs on different com ports.
“multitasking is taken for granted in a windows environment, but many radio amateurs may not realize that most tnc software products were written before 32-bit multitasking was a standard. pacterm and pkterm are the only software solutions of their kind that don't restrict the user's ability to work in other applications at the same time.” said rick ruhl, css president. “the ability to work in hf and packet modes at the same time gives operators a real advantage in contesting. it's like turbo-charging the sport of radio. and that's not to mention the personal productivity to be gained from keeping an eye on email and other applications while operating radios.”
new startup and shutdown commands support continuous packet bbs operation
pacterm/pkterm version 3.76.02 adds support for multiple start-up and shut-down commands, allowing hams to operate packet, amtor and pactor bulletin board systems from the tnc, even when the software and your computer are shut down.
tnc wizard further automates set-up
in addition to the new and enhanced capabilities of pacterm and pkterm, css' tnc wizard has been enhanced to automate soundcard mode setup for the user. the tnc wizard, included with pacterm and pkterm, automatically locates a computer's serial ports and baud rate, making tnc emulation easier to set up and ensures more error-free operation.
file sharing, transmission modes improved
pacterm and pkterm also now support an unlimited buffer for ascii file transfers, an important enhancement for marsgrams in particular. in addition, mt-63 mode has been updated to support the 2000 hz spectrum.
pacterm and pkterm will be available for purchase in booth 108-109 at hamvention. existing customers who are current maintenance subscribers may download the new release at no charge from the css website, or may pick up an upgrade cd at hamvention. pacterm and pkterm retail for $99 and are available for purchase online at www.cssincorp.com, at many ham radio retailers and through several amateur radio equipment catalogs.
about css
css is a privately held software and technology consulting company specializing in software connectivity for amateur radio operators; office automation and network management solutions for business; and custom software development for specialized web and wireless applications.
creative services software, the css logo, and pkterm are trademarks of creative services software, inc. pacterm is a trademark of kantronics used with the permission of the trademark owner. all other trademarks or registered trademarks are the property of their respective holders. all rights reserved.
press release
=====================下面是google翻译的=======================
创意服务软件扩展电台和跨国公司的支持,增强了自动化,在新版本的pacterm和pkterm业余无线电台的软件
即时发布 :美国俄亥俄州戴顿市, 2008年5月15日-创意服务的软件公司(的css )将推出新版本的该公司的跨国公司的软件在代顿业余无线电协会的hamvention , â ®其中得到正在进行明日在原舞台。 版本3.76.02双方pactermâ “ ¢ ( timewave /积极就业援助跨国公司)和pktermâ ” ¢ ( kantronics跨国公司)数量扩展无线电收发可能pc的运作通过终端节点控制器(跨国公司) ,增加了灵活性,以跨国公司行动中,进一步自动化,安装,开机和关机的程序,扩大支持,至2000年,赫兹在山63模式,并增加文件传输能力。
css的扩展支持国际博物馆理事会,八重洲收发器
pacterm / pkterm现在支持新的国际博物馆理事会7700和四个新的八重洲收音机,加入英尺- 450 ,英尺- 950 ,英尺- 2000年,英尺-的dx 9000的型号。 扩大电台的兼容性是在除了66个收音机已经支持,提供了许多倍,更大的相容性比其他跨国公司的软件解决方案。
此外,新电台的支持, pkterm ,现在也支持新timewave的dsp - 232 +跨国公司。 该即插即用的dsp - 232是timewave最新的多模数据控制器设计围绕一个高速数字信号处理器。 数字信号处理技术相结合,与记忆arq的,真正的dcd的,和硬件的hdlc提供先进的信号滤波,调制解调器的性能和灵活性。
pacterm / pkterm现在提供多的权力扩大
pacterm和pkterm已是仅适用于跨国公司的软件提供真正的32位元多工能力,使运营商能够控制的无线电发射和运行日志记录程序,呼吁书的程序和任何windows应用程序同时进行。 pacterm / pkterm还继续支持双跨国公司,让业余无线电工作在hf和包模式,同时也是二:单一端口的跨国公司对不同的com端口。
“多是采取理所当然的在windows环境,但许多业余无线电爱好者可能没有意识到,大多数跨国公司的软件产品,分别书面前32位的多是一个标准。 pacterm和pkterm是唯一的软件解决方案,他们的那种不限制用户的工作能力,在其他应用程序在同一时间内。说: “里克ruhl , css的主席。 “工作能力,在高频和包模式,在同一时间,使运营商真正的优势,在争夺。 这就像汽轮发电机组的收费运动的电台。 这不是更遑论个人生产力,以获得从保持留意您的电子邮件和其他应用程序的同时,经营无线电通讯设备“ 。
新开机和关机的命令,支持连续的数据包的bbs运作
pacterm / pkterm版本3.76.02增加了支持多个启动和停机命令,让火腿经营包, amtor和pactor电子布告栏系统,从跨国公司,即使当软件和您的电脑是关机。
跨国公司向导进一步自动化的设立
除了新的和增强的能力pacterm和pkterm , css的'跨国公司的精灵已经加强自动化音效模式安装为用户。 跨国公司的向导,其中包括与pacterm和pkterm ,自动寻找电脑的串行端口和波特率,使跨国公司的仿真更容易成立,并确保更多的错误-自由运作。
文件共享,传输模式的改进
pacterm和pkterm ,现在也支持无限缓冲区为ascii的文件传输,一个重要的增强,特别是marsgrams 。 此外,山- 63模式已更新为支持2000年赫兹的频谱。
pacterm和pkterm将可购买在摊位108-109在hamvention 。 现有客户谁是目前的维修用户可以下载新版本在不收费从css的网站,或可上落了一个升级cd在hamvention 。 pacterm和pkterm零售价为99美元和网上有售,在www.cssincorp.com ,在许多业余无线电零售商和通过几个业余无线电设备的目录。
约的css
css的是一家私人控股的软件和技术咨询公司,专门从事软件连接为业余无线电操作员;办公自动化和网络管理解决方案业务;和自定义软件开发的专门网页和无线应用。
创意服务软件, css的标志,并pkterm的商标创意的服务软件,公司pacterm是一个商标kantronics使用许可,该商标的拥有者。 所有其他商标或注册商标是其各自持有人财产。 保留所有权利。
新闻发布
