  • 4700阅读
  • 9回复
VX-8R [复制链接]
离线VR2ZUY
只看楼主 倒序阅读 0楼 发表于: 2008-05-15
离线7600
只看该作者 1楼 发表于: 2008-05-15
11111111111111111111111111111111
离线BG9TF
只看该作者 2楼 发表于: 2008-05-16
好漂亮!!
离线BD1LKK
只看该作者 3楼 发表于: 2008-05-16
the yaesu vx-8r ht provides a full 5 watts fm on 50/144/430 mhz plus 1.5 watts on 222 mhz. it supports blue tooth hands-free operation with the optional bu-1 and bh-1 or bh-2 accessories. there is also an optional gps unit and antenna with loads of features. this radio supports aprs 1200/9600 bps data communication (b band only). like the vx7r, the vx8r is submersible and meets ipx57 specifications (3 feet for minimum of 30 minutes). a powerful 7.4 v 1100 mah lithium ion battery is included. an optional 3 x aa battery cell case will be offered soon. this ht is small, only 2.36 x 3.74 x 0.92 inches (thinner than vx-7r). it supports simultaneous independent 2-signal dual receive function with both v + v or u + u. it has weather band receive with weather alert. a barometric sensor is included. you can even operate amateur radio while receiving fm broadcasts! the receive coverage is wider than vx-7r, with an independent am/fm broadcast receiver circuit. the dot matrix lcd display provides memory tag up to a maximum of 16 characters. you even get a high-resolution spectrum analyzer with ア60 channels indication with wave monitoring of received/modulated signal! and dcs and ctcss encode and decode is included.
features
optional bluetooth
optional gps
aprs 1200/9600 bps (b band only)
ctcss/dcs encode & decode
weather receiving with weather alert
wideband receive
dual receive
submersible ipx57
dot matrix lcd
hi-rez spectrum analyzer
离线江南牧童
只看该作者 4楼 发表于: 2008-05-17
和摩托罗拉杂交=混血儿
离线wangjie11
只看该作者 5楼 发表于: 2008-05-17
看着怪怪的
离线BG4RID
只看该作者 6楼 发表于: 2008-05-19
外观像铁甲机器人
离线BG4RID
只看该作者 7楼 发表于: 2008-05-19
features
optional bluetooth
optional gps
wideband receive
dual receive
submersible ipx57
dot matrix lcd
离线osagem
只看该作者 8楼 发表于: 2008-05-20
要观察观察
离线BG4DQX
只看该作者 9楼 发表于: 2008-05-21
2008年10月,美国正式上市。
