  • 10063阅读
  • 40回复
这个给IBQ的! [复制链接]
离线BG7IBQ
只看楼主 倒序阅读 0楼 发表于: 2002-12-02
离线BG7IBQ
只看该作者 1楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 2楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 3楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 4楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 5楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 6楼 发表于: 2002-12-16
magnum delta force
documentation project
cbtricks.com
2002 model deltaforce - frequency modification update
1. make sure deltaforce is turned off and disconnected from power sourcel!
2. take off speaker-side cabinet.
3. find the cpu reset board located near the rear panel of the radio (see diagram below).
4. on the cpu reset board are 4 jumper positions (con-1 - con4).
each jumper position provides a different frequency range and configuration. from the list below, select the desired frequency range and configuration, and move the jumper shunt to the corresponding con.
con 1 : 10 meter only (28.000 - 29.699 mhz)
*default mode
*all functions operate normally
con2 : 10 meter & expanded mode
*at turn on, the radio defaults to 10 meter mode.
*for expanded mode, press func and then press call for 3 seconds.
*to return to 10 meter mode, repeat above steps.
tor information on expanded mode operation, see con3
con3 : expanded mode only (25.165 - 29.699 mhz)
*in expanded mode, the frequency range is divided into 10 bands of 40 channels each
"bands are shown on lcd display by letters (a through j) - band e is regular 40 channel cb. to switch bands, press the call button (do not hold down for 3 seconds),
*in expanded mode, either the frequency or channel can be displayed on the lcd. to switch between freqency display and channel display, press the func button and then press the call button (do not hold down for 3 seconds).
*on the channel display, the small number (0 - 9) to the right of the band letter is the 1 khz frequency display. example: if the frequency is 27.405, then the channel display will indicate 40 e5. "40" being the channel, "e" being the band, and "5" being the 1 khz position of 27.405.
*in expanded mode, the rpt and shift functions do not operate
con4 : 40 channel cb only (26.965 - 27.405 mhz)
*only operates on the regular 40 cb channels
5. after selecting the desired frequency range and configuration, press the cpu reset switch (sw1) for 5 - 10 seconds.
6. reassemble the radio, turn on and test.
copyright 2002 cbtricks.com
disclaimer: although the greatest care has been taken while compiling these documents,
we cannot guarantee that the instructions will work on every radio presented.
please join the cb tricks e-mail group or e-mail us at webmaster@cbtricks.com and send a message if you discover a problem.
离线BG7IBQ
只看该作者 7楼 发表于: 2002-12-16
一个好的网站!有很多资料可供参考!
http://www.cbtricks.com/
离线BG7IBQ
只看该作者 8楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 9楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 10楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 11楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 12楼 发表于: 2002-12-16
不知是什么语言的元件资料!
http://www.dart.ru/catalogue/microchips/pdf/17-1.pdf
离线BG7IBQ
只看该作者 13楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 14楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 15楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 16楼 发表于: 2002-12-16
离线BG7IBQ
只看该作者 17楼 发表于: 2002-12-16
离线BD3RJ
只看该作者 18楼 发表于: 2002-12-18
7ibq包裹到现在都没有收到。请查询一下。
离线BG7IBQ
只看该作者 19楼 发表于: 2002-12-19
这是你的usb nova disk的驱动程式
附件: win98drive.zip (0 K) 下载次数:117
