  • 3115阅读
  • 2回复
IC-281 281H 481 481H扩频方法 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2008-05-15
1- remove power and antenna.
2- remove screws open the case.
3- locate logic board.
4- locate and remove jumper w6 ( rx mode ).
5- locate and cut diode d-13.
6- reassemble the radio.
7- you may be required to reset the microprocessor. (see owners manual)
扩频范围:     118-135.995 mhz [ am rx ]
              136-174 mhz [ tx rx ]
              320-479 mhz [ rx ]
              400-479 mhz [ tx only on ic-481 ]
跨段功能
  1- enter desired frequencies in both bands
    on:   in   uhf mode press [ set] & [lock] until " l" flashes.
    off:   press [set] & lock].
离线vvb
只看该作者 1楼 发表于: 2008-05-15
太好了.感谢.
离线bd2qad
只看该作者 2楼 发表于: 2008-05-16
有ci-481h亚音片吗?沈阳 13940451616   qq592227066   bd2qad谢谢!
