  • 2029阅读
  • 1回复
求教c168设置 [复制链接]
离线shl
只看楼主 倒序阅读 0楼 发表于: 2008-05-11
我的c168没有办法调步进了,好象被索定的样子,有知道怎么设置吗
离线bg6qjn
只看该作者 1楼 发表于: 2008-05-11
马兰士c160/460/168/468)手持台功能表
  keyfunction功能
  0~9numeric input数字输入
  lampdisplay illumination on/off背景照明灯
  sql offsquelch control on/off静噪开关
  b v/m entvfo/memory mode togglevfo/记忆(mr)模式切换
  c?pagfrequency or address number down频率数或者信道向下变化
  d?codefrequency or address number up频率数或者信道向上变化
  #cl pscancel mode取消模式
  *ms ms.mmemory scan on/off信道扫描开关
  callcall up call frequency呼叫频率
  call+f+# 扫描时越过mhz
  f+1switch transmit power level发射功率调整
  f+2dual watch on/off双频率守候开关
  f+3memory shift mode on/off记忆变化开关
  f+4tuning step setting频率步进设置
  f+5save on/off省电开关
  f+6frequency lock on/off锁键盘
  f+7tone squelch/tone encoder toggle亚音静噪开关
  f+8repeater mode on/off异频收发模式开关
  f+9invert transmit and receive frequencies in repeater mode设置中继台亚音转发接收频率
  f+0switch to set mode set模式转换
  f+aturn lamp on长明灯开关
  f+bswitch memory record mode切换记忆记录模式
  f+cpaging / code squelch on/off记录/代码静噪开关
  f+dcode setting mode代码设置模式
  f+*ms.m setting/ms.m operationms.m设置/ms.m操作
  f+#scan on/off扫描开关
  f+call/p.lptt switch lock on /off发射锁定开关
  f+sql offdtmf memory modedtmf记意模式
  se->0beep on/offbp声开关
  se->1length of paging beep 1/5 toggle呼叫bp声1/5切换
  se->21khz column input from numeric keys enable/disable
  toggle使能够从1khz开始设置频率
  se->3repeater+pag transmission delay time半双工发送延迟时间
  se->4squelch pop noise reduction减小弹出燥声
  se->5apo(auto power off) on/off自动关闭电源开关
  se->6enable encoder even in frequency lock status在频率锁定状态下也能使编码可能
  se->7ctcss frequency setting mode (ctn160 tone frequency selection)ctcss
  频率设置模式(ctn 160 双音频频率选择)
  se->8repeater offset frequency setting半双工差频设置
  se->9(display indications appear normally,but no tones are produced
  internally.)(发射亚音设置)显示指示正常出现,但中间没有音频被建立
  se->f+1all reset(restores factory settings)全部重新设置(恢复出厂时的设置)
  se->f+2long medium pitched beep (boo) (no function)调频、调幅模式转换(c160/168有此功能)
  se->f+3all reset enable/prohibit toggle全部清除使能够切换
  se->f+4switch to protect mode保护模式转换
  se->f+5squelch audio during paging even if code matches
  se->f+6toggle tuning steps when rotary channel selector is turned with the
  func key held down between 100khz and 1 mhz按f键时旋转旋钮,步进1mhz或100khz
  se->f+7clone mode无线复制模式
  se->f+8 无功能
  se->f+9switch bank of optional cmu161 memory unit99/199信道转换开关(配置cmu161选件)
  se->f+bdelete memory frequency删除记忆频率
  se->f+0switch to extra modeea模式转换
  ea->1high speed scan on/off扫描速度开关
  ea->2high speed dual watch on/off快速双频率监视开关
  ea->3change lamp key to rev key改灯键为倒频键
  ea->4select interval for save function选择省电功能间隔时间
  ea->5reduce dtmf transmission speed改变双音频发送速度
  ea->6 设置频率范围
  ea->7 按上下键时的频率步进
  ea->8enable frequency input from 100 mhz column使键盘置频能够从100mhz位开始设置
  ea->9 无功能
  ea->0 无功能
