  • 9073阅读
  • 2回复
ICOM IC-746PRO TX Problems [复制链接]
离线BA4KW
只看楼主 倒序阅读 0楼 发表于: 2008-03-25
icom ic-746pro tx problems
last updated: december 17, 2007
the ic-746pro is a great rig. but it has a few reliability issues, especially with the earlier-production units.
this article addresses four problem areas:
ic151 on the rf unit.
driver circuit on the pa unit.
hrx-muting circuit on the ctrl unit.
predriver on the pa unit.
note: the following information is based on my experiences and observations. i have not consulted with anyone from icom. and i do not recommend doing any modifications to a properly functioning radio. if it ain't broke, don't fix it!
problem #1:
the first issue is smd-chip ic151 on the rf unit. this chip can fail for one or two reasons: electro-static discharge (esd), or heat.
esd: icom released a service bulletin (#920), which recommends adding two pin diodes to the hrx-line. this can help prevent esd-related failure.
heat: it is a commonly-held opinion that this chip runs too hot. it seems icom did not design the pc board with enough ground-plane to cool the chip properly. adding a heatsink on top of the chip, soldered to the ground pins, can alleviate the problem. i've found that a 2ag-style fuse-clip fits perfectly onto the chip, and serves as a decent heatsink.
later-production ic-746pro's have a couple of diodes soldered on top of ic151 (see the picture below). in this case, soldering a heatsink on top is not practical. i've drawn a diagram of the factory modification. the smd diode is an ma77. there are no visible markings on the other diode. i assume this upgrade is to prevent damage from esd (as if service bulletin #920 wasn't enough).
in the latest-production units, icom has revised the rf unit board to accommodate three extra smd diodes in the ic151 circuit (for additional esd-protection). its basically the same as the circuit described above, except it uses the smaller version of the ma77 diode (ma2s077). two of these ma2s077 diodes are in series, in place of the large amber diode in the previous circuit. the other ma2s077 is used in place of the ma77 in the previous circuit. a picture and schematic are shown here:
problem #2:
the second issue is the driver circuit (drv board). in the earlier production units, the two fet's (2sk2975) run quite hot. mostly because the factory set the idling current (bias) too high. in addition, the fet's are surface-mount types, which dissipate their heat through their source connections. but the manufacturer's heatsink doesn't seem to do a very good job. the excessive heat eventually causes the solder connections to become intermittent, which causes fluctuations of the transmitter rf output. this affects all bands and all modes, and it is most noticeable by observing the alc meter.
if the fet's are still good (and they usually are), they can be re-soldered. but there's a trick to it. the trick is to melt the solder on all three of an fet's strips at same time, while holding the fet firmly against the mounting plate, so it doesn't slide out of place. if you've re-soldered without the fet becoming loose, you didn't get it hot enough, and the joints will fail again. unless you have the proper soldering equipment and skills, its probably best to replace the entire drv board.
after the fet's are re-soldered or replaced, the the pa idling current adjustment (r11) should be set to 1.5-amps (instead of 2.5-amps, as stated in the service manual).
you may notice the factory did not apply heatsink compound under the drv board. you can add some, but i don't think it makes enough difference. the metal is machined so smoothly that heat transfer isn't greatly improved by adding heatsink compound.
to provide additional cooling, a heatsink can be added on top of the drv board. this is done by inserting a 1mm-thick thermal pad between the fet's and the new heatsink, so the transfer of heat is accomplished without putting any mechanical pressure on the components.
the original mounting screws are replaced with longer ones (of the same thread-type) to accommodate the new heatsink. two metal spacers are inserted to keep the heatsink at the proper distance above the fet's (just enough for the thermal pad to be slightly compressed). the optimal screw length is 13mm to 14mm, not including the head. the spacers should be metal, 2mm thick.
here is a cross-sectional view of the modification:
here are "before" and "after" pictures of the modification:
the heatsink and thermal-pad material are available from digi-key. here are the part numbers:
heatsink: hs274-nd
thermal pad: ber162-nd
note: re-soldering the fet's is no easy task. it requires proper tools and skills. the trick is to melt the solder on all three of an fet's strips at same time, while holding the fet firmly against the mounting plate, so it doesn't slide out of place. if you've re-soldered without the fet becoming loose, you didn't get it hot enough, and the joints will fail again. to get an idea of how the fet's are soldered, here are some photos, courtesy of zd8i:
personally, i prefer not to remove the drv board. instead, i remove the entire pa unit. this may be more labor-intensive, but it eliminates the risk of damaging the traces of the drv board, as it requires considerable heat to unsolder its mounting pins. removing the pa board only requires unsoldering the vhf so-239 connector and two of the varistor boards.
in the latest-production units, icom has made significant changes to the pa unit. retrofitting an older unit requires extensive modifications. here are the changes made to the latest pa units:
the two mounting screws on the drv board have been replaced with longer ones that have larger washers.
inductor l2 has been changed from 100uh to 10uh.
inductor l6 has been changed from a ferrite-bead type to a toroidal type.
resistors r41 and r42 have been changed to 6.8-ohm.
resistor r11 on the drv board has been removed.
the pa idling current adjustment (r11) is set to 1.5-amps (instead of 2.5-amps, as stated in the service manual).
problem #3:
another common problem is failure of the hrx-muting circuit. this is usually caused by rf overload, high swr, or lightning. if this circuit fails, the transmitter will tend to oscillate intermittently. this is most noticeable on the higher hf bands (6, 10, or 12 meters). 2-meters will not be not affected. the symptoms are: unusually high current demand from the power supply, fluctuating rf output, and/or erratic antenna-tuner operation.
to get an idea if the hrx-muting circuit is at fault, turn the receive attenuator (att) on. if the problem goes away when the att is on, the hrx-muting circuit is probably at fault. this test works because the attenuator interrupts the path of oscillation.
suspect one or more of the following components on the ctrl unit:
q25 (2sc4213)
d21, d22 (mmbv3700lt1)
d24 (ma77)
note: to check the dc voltages at q25, transmit on ssb with the mic-gain at minimum. the base voltage should be 0-volts rx, and 0.7-volts tx. the collector voltage should be 13.8-volts rx, and 0-volts tx.
in the latest-production units, icom has made changes to the ctrl unit. here are the changes made to the latest ctrl units:
two pin diodes were added back-to-back across the hrx-line, from the junction of l27/r160/rl4 to ground.
resistor r154 has been changed to 1k.
here is a photo of the added pin diodes, courtesy of bill-k0zl:
problem #4:
this is less common, but the predriver fet (q1 on pa unit) will sometimes become intermittent or fail completely. this is a 2sk2973, and it runs quite hot. when i replace the fet, i solder a small heatsink to its source tab. a 2ag-style fuse-clip fits perfectly by cutting off one of its legs, then soldering the remaining leg to the fet tab. see the pictures below:
离线BA4KW
只看该作者 1楼 发表于: 2008-03-25
资料更新于december 17, 2007
也许746pro的一些小问题并没有像icom公司说的那样全部解决
需要自己动手了
离线BA7JG
只看该作者 2楼 发表于: 2009-05-10
不是每个批次的机器都会出现相同的问题的,这关系到每个批次的各元器件的问题。
73!
