  • 3302阅读
  • 1回复
软件推荐:DStar Comms V1.0.55 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2008-03-23
功能:
1) manual check for updates (will auto download new version if there is a new release).
2) beacon start/stop from main window .
3) check smtp server settings.
4) sound setting for beacon sending.
5) filter for regeneration nodes (repeaters). some of you may have noticed that when sending text through a repeater the last 10 to 15 chars are returned to your screen, ticking this in options should prevent that. this will happen with any chat style program but i believe this is the first to apply a filter for it.
6) id-800h model added.
7) query all stations (if enabled allows other using to send a broadcast request to all dstar comms users. dstar comms will then send a message to only that user with an online message. the transmission is set to send at a random period between 1 and 15 seconds to prevent other users signals clashing at the same time).
点这里下载
离线osagem
只看该作者 1楼 发表于: 2008-04-01
做个记号,回家试验。
