  • 4588阅读
  • 4回复
Russian DX Test Back For 2008; [复制链接]
离线BA4RF
只看楼主 倒序阅读 0楼 发表于: 2008-03-10
帮rx9tx发rdxc相关消息。注意:这个比赛对wrtc2010是有用的,如果对wrtc2010有兴趣请关注,别到了时候又说不知道:)
hello ,
david, pse post it on the rdxc thread on hellocq.net.
http://www.radio-sport.net/rdxc08_pre.htm
russian dx test back for 2008; submitted logs to be open for all
by jamie dupree ns3t radio-sport.net
posted march 10, 2008
after another strong year of growth in 2007 that brought about an
eight percent jump in the number of logs submitted, the russian dx
contest returns for 2008, ready to play a major role in the wrtc 2010
selection process.
"we can for sure say that in rdxc 2008 we may expect new skilled
operators and big-gun stations from all over the world," said a
statement from the three member russian dx contest committee of rw1ac,
ua2fz and ra3auu.
among the changes announced for the 2008 contest, the russian dx
committee says it will join cqww dx in publishing the logs of contest
entrants on the internet.
"starting 1st july 2008, we plan to open access to rdxc participants
logs at www.rdxc.org to bring you the possibility to anyalyze your
friends and your rivals logs," said the rdxc committee.
with propagation in recent major contests making life much more
difficult for operators all around the world, the 2008 russian dx test
may be likely to evolve into a competition that is more limited to
europe and asia because of bad band conditions.
that was clear from the arrl ssb contest, where willy umanets ua9ba
trained his big antennas on the us and canada, but could only come
away with 19 contacts on 20 meters.
"i had never heard the bands in such poor shape for such lengthy
period," said umanets, who added that he did not hear one north
american signal on 40 meters during the arrl phone test.
"this is a great contest, but at this pointof the cycle, it's very
difficult to work russia on any band from w6," said dan craig n6mj,
who will operate from w6yi.
despite some tough band conditions in recent years, the russian dx
test continues to grow at a healthy pace, with over 3,000 logs
submitted in 2007. log reviews show that over 9,000 stations made at
least five qso's.
the defending single operator champ from 2007 is max pustovit rv3ba,
who operated ex9a in krygyzstan to victory, getting 2,669 net qso's
for a total of 9.98 million points, over a million ahead of his
nearest competitor.
along with the public release of contest logs, the rdxc committee is
also trying to tighten overall post-contest reviews, adding rules this
year that require multi-two stations to submit cabrillo files that
"indicate which transmitter made each qso."
the committee also is asking participants to specify the frequencies
on which qso's were made for more careful refereeing.
one other rule change for 2008 is that rdxc is recommending that qrp
stations sign "/qrp." for those who do not, they may be moved into the
low power category.
rx9tx
"real knowledge is to know the extent of ones ignorance."   [confucius]
离线BA7JS
只看该作者 1楼 发表于: 2008-03-11
喜欢最后那句孔老二说的话! :d
离线BA7NO
只看该作者 2楼 发表于: 2008-03-12
:d :d
宠辱不惊,看庭前花开花落;去留无意,望碧空云卷云舒
山阻石拦,大江毕竟东流去;雪辱霜欺,梅花依旧向阳开
离线BD1FBV
只看该作者 3楼 发表于: 2008-03-15
离线bg4wzh1
只看该作者 4楼 发表于: 2008-03-15
俄罗斯dx 为2008 向后测试;
帮rx9tx 发rdxc 相关消息. 注意 : 这个比赛对wrtc2010 是有用的, 如果对wrtc2010 有兴趣请关注, 别到了时候又说不知道
你好,
大卫,pse在rdxc在hellocq.net上的思路上邮寄它。
俄罗斯dx 为2008 向后测试; 提交记录开全部
由杰克dupree ns3t收音机sport.net
2008年3月10日公布
在另一强大的在引起a的2007的增长的年之后
木材的数量百分之8 的猛增提交,俄罗斯dx
比赛为准备在wrtc 2010中起主要作用的2008 回来
选择过程。
"我们能肯定说在2008 rdxc,我们可能期望新熟练
操作者和来自全世界的大枪的车站,"a 说吗
rw1ac的3 名成员俄罗斯dx 比赛委员会的陈述,
ua2fz和ra3auu。
在为2008 比赛,俄罗斯dx 宣布的变化中
委员会说它将在出版比赛的木材过程中参加cqww dx
在因特网上的新到者。
"2008年7月1日开始,我们计划打开rdxc 参加者的入口
木材在 www.rdxc.org 对anyalyze 你的为你带来可能性
朋友和你的竞争者木材,"rdxc委员会说。
由于在新近的较大的比赛里的繁殖制造生命更多
对于操作者全世界难,2008俄罗斯dx测试
可以很可能逐步形成成为更局限于的竞争
因为坏带子条件的欧洲和亚洲。
那从那些arrl ssb 清楚比赛,在哪里威利umanets ua9ba
在美国和加拿大上训练他的大的天线,但是只能来
到远处有19 接触在20米上。
"我决不听说在这样糟糕形状内的乐队为冗长的这些
时期,"补充说他没听到一北方,umanets 说
在40米的美国信号在arrl电话期间测试。
"这是大的比赛,但是在这pointof 循环,它非常
难工作俄罗斯在任何带子从w6那里上,"丹·克雷格n6mj 说,
其将从w6yi 操作。
近年来尽管一些结实的带子条件,俄罗斯dx
试验继续以健康的速度增长,带有超过3,000根木材
在2007年提交。 木材检阅显示超过9,000个车站挣对
最小5 qso。
单个的操作者从2007大声咬嚼的保护是最大的pustovit rv3ba,
谁对胜利在krygyzstan方面操作ex9a,得到2,669网qso
对于共998万个点,超过领先他的的100万来说
最近的竞争者。
跟比赛木材的公开释放一起,rdxc委员会
此外努力加强总的比赛后评论,增加规章这
提交cabrillo 文件那的二要求数的年车站
"表明传送者使每qso哪个"。
委员会也正要参加者指定频率
qso完全适合更仔细的担任裁判。
因为2008是rdxc正推荐那qrp,另外一个规章改变
安置签字"/qrp"。 那些以来不,他们可能被搬进
低功率种类。
rx9tx
"真正的知识将知道东西无知的程度"。 [孔子 ]
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
喜爱dxing!
