  • 3992阅读
  • 14回复
今天有个火腿MM比赛 [复制链接]
离线BG4CZX
只看楼主 倒序阅读 0楼 发表于: 2008-03-03
今天傍晚,打开电台,突然发现7mhz上有好多日本mm在摆摊呼叫,感觉很是奇怪,怎么平时都难得一见的yl电台,今天一下子都涌出来了?没想那么多,顺手通了5个日本mm和一个韩国mm,其中一个日本mm英语还讲得很标准,不容易啊。后来google了一下,原来今天(3月3日)是日本的女孩节,japan ladies radio society (jlrs)举办了一个yl contest(年轻女ham比赛),全世界的火腿,不管男女,都可以参加,只不过每通到一个mm火腿可以得10分基本分,通到一个男火腿只能得1分,这个比赛很有趣吧。这也是我连续通到yl电台最多的一次。
附:今年的比赛规则
hina-maturi
this is a famous girl’s festival on march 3 in japan.
when the birth of girls is celebrated and wishes are expressed for their futurehappiness.
we display a set of dolls in ancient costumes which is called “hina- ningyo” at each house.
the 5th jlrs 3・3 hina contest
purpose: jlrs sponsors the jlrs hina 3.3 contest to encourage women’s interestand active participation in amateur radio, and deepen friendship between them.
eligibility: all licensed men and women operators throughout the world are invited to participate.
the contes time: march.2 .2008. 15:00utc~march 3.2008. 15:00utc
bands: 1.9 mhz ~ 1200mhz(this includes warc bands)
modes: all modes (this includes rtty, psk31, sstv)
(to permit to change the mode in the same band)
(each station must be counted only once per band and mode)
entry: (a) yl- multi band (b) om- multi band
proceduce: phone call “cq hina contesrt” or “cq hinatest”
exchange: oms: rs (t) yls: rs (t) yl
multiplier: every worked different prefixes counts as multiplier.
(if you work jd1 (as), (oc) that would make different multiplier)
points: every qso with yl- 10points. every qso with om -1point. qso from om to om -1point.
condition: included 3 or more yls in a and b entry.
total score: points of all bands together times multipliers.
logs: multiply the total number of contact by the total number different prefix worked in each band.
the logs must show scores claimed, date, time, band, mode, call signs worked, report
and power transmitted, signed by operator.
logs must be received by the contest custodian by 20th march, 2008logs must be legible. please type or print logs.
contest custodian; kimiko saito (ja8uwt) 16-2-22 kamui4jyo, asahikawa, hokkaido, 070-8014, japan.
tel & fax: 0166-61-5304 e-mail:ja8uwt@jarl.com
certificates: the certificate and supplementary prize will be awarded
to first place ~ third place in each entry.
announcement of result: result will be appeared on jlrs’s web site in june, 2008 to receive contest results by post, please enclose sase with your log.
离线ba6qr
只看该作者 1楼 发表于: 2008-03-03
晕,现在才看到,错过机会乐~~~~~~~~~~~``
离线BG4CZX
只看该作者 2楼 发表于: 2008-03-03
难得有比赛放在非周末进行的。
离线BG4CZX
只看该作者 3楼 发表于: 2008-03-03
好象每年3月3日都有这个比赛。
离线bl7ic
只看该作者 4楼 发表于: 2008-03-03
走寶了..........
离线bg7nwf
只看该作者 5楼 发表于: 2008-03-03
今天听到两个ja 的yl 就是不敢回,不知道要给她什么报告!
要早知道就可能会得到她的88咯!!!
离线BG4CZX
只看该作者 6楼 发表于: 2008-03-03
要早知道就可能会得到她的88咯!!!
给她报告59就行,没有序列号的,在比赛的时候我甚至和其中一位用英语聊了5分多钟。
离线BG4CZX
只看该作者 7楼 发表于: 2008-03-03
给她报告59就行,没有序列号的,在比赛的时候我甚至和其中一位用英语聊了5分多钟,让一堆在旁守听的台干着急。
离线BD4KA
只看该作者 8楼 发表于: 2008-03-04
7050上主叫的mm真行,我bjt;10;00左右听到一直到bjt;18;00没歇气,报呼号挺快,好象ja1ccg?不知我抄的对不对...
离线BG4DVK
只看该作者 9楼 发表于: 2008-03-04
走宝。。。明年再战:d
离线bg8ah
只看该作者 10楼 发表于: 2008-03-04
走宝。。。明年再战:d
呵呵,明年再战3月3.
离线BA8AT
只看该作者 11楼 发表于: 2008-03-04
可惜了,明年统统搞一遍
离线bg8am
只看该作者 12楼 发表于: 2008-03-10
竟然不知道,早晓得我就把天线架好,抓几个日本mm
离线BG9TL
只看该作者 13楼 发表于: 2008-03-20
对,结束一定要说88
离线VR2UNA
只看该作者 14楼 发表于: 2008-03-22
yl 好像具有女朋友的意思哦,xyl则是老婆的意思。哈哈。
