  • 18907阅读
  • 29回复
ne602应用! [复制链接]
离线BG7IBQ
只看楼主 倒序阅读 0楼 发表于: 2002-11-26
离线BG7IBQ
只看该作者 1楼 发表于: 2002-11-26
离线BG7IBQ
只看该作者 2楼 发表于: 2002-11-26
又是一个有关ne602的网站!
http://www.amwindow.org/tech/htm/602mod.htm
离线BG7IBQ
只看该作者 3楼 发表于: 2002-11-26
ne602 ne612
sa602a sa612a
balanced rf amplifier and oscillator
the sa612a is a low-power vhf monolithic double-balanced mixer with on-board oscillator and voltage regulator. it is intended for low cost, low power communication systems with signal frequencies to 500mhz and local oscillator frequencies as high as 200mhz. the mixer is a 馟ilbert cell?multiplier configuration which provides gain of 14db or more at 45mhz. the oscillator can be configured for a crystal, a tuned tank operation, or as a buffer for an external l.o. noise figure at 45mhz is typically below 6db and makes the device well suited for high performance cordless phone/cellular radio. the low power consumption makes the sa612a excellent for battery operated equipment. networking and other communications products can benefit from very low radiated energy levels within systems. the sa612a is available in an 8-lead dual in-line plastic package and an 8-lead so (surface mounted miniature package). pin name description
1 input
2 input
3 gnd ground
4 output
5 output
6 oscillator input
7 oscillator output
8 vcc supply voltage
this counter shows the number of hits since the 29th january 2000
离线BA7EI
只看该作者 4楼 发表于: 2002-11-27
Re: ne602应用!
最初由 bg7ibq 发布
作为唱响级功能验证用途,俺还介绍一个电路.不过ne602类机器属于低档货
  由双极型晶体管组成的模拟乘法器比如说ne602之类的集成电路作混频器的用在短波收信机上作一混频器时,其动态远低于场效应晶体管平衡混频器、场效应晶体管双平衡混频器和肖特基二极管双平衡混频器,目前凡是用由双极型晶体管模拟乘法器作第一混频器在做cw或ssb短波接收机套件,如果其输入端有lc调谐选频回路的还能作为唱响级的玩具,如果是用带通(含亚倍频带通滤波器)宽带输入则完全属于纯粹为学习而弄的功能验证型无实用价值的电子垃圾(我说得可能过了点,不过我曾经悬赏过,只见有缺乏纯正品行的人狂吹甚至进行人身攻击,就是没人拿出性能象样的作品,分析其原因很简单——利益驱使)!使用602类由双极型晶体管组成的模拟乘法器做ssb机器第一混频器就是低档次低性能的象征(ne602或ne612这两个型号的模拟乘法器可以用于短波机其他地方,但是远洋货轮上的短波专业机或者军方的短波收信机或电台里罕见)。
  某些人经常举一些例子:xx商品电台就是用xxxx元件,既然存在,就一定有存在的道理。那是一派胡言!杀人,抢劫,在你我来到这个世界之前就已经存在,而且每天都在发生,如果你坚持说是“合理”,那我也无话可说的!我还可以为你提供点依据:美国套件kx1用的是ne602、我国某业余无线电爱好者在上世纪九十年代曾经用mc3361做过ssb收发信机呢!不过它们的接收性能不上档次!
离线BG7IBQ
只看该作者 5楼 发表于: 2002-11-27
Re: Re: ne602应用!
最初由 bd7ei 发布
还有啊
所以说这个ic是个很好的ic,在以前有篇文章说过这个ic可以说是从ne555以来最好用的一个呀!
离线BA5CA
只看该作者 6楼 发表于: 2002-11-27
ham diy的万能ic,可外接晶体,振荡器,又可做发射,又可做接收,如价格和555一样就好了。
离线BG7IBQ
只看该作者 7楼 发表于: 2002-11-28
最初由 bd5cag 发布
是个好ic,但是价格是不能跟ne555相比较了!
但是数量多的话可能会低一点!
离线BG7IBQ
只看该作者 8楼 发表于: 2002-12-03
最初由 bg7ibq 发布
但是数量多的话可能会低一点!
离线BG7IBQ
只看该作者 9楼 发表于: 2002-12-12
航空通讯频谱监视系统(二)
ne602 简介
no.24   1994 dec.   p48~53,   by 林茂荣 / bv5oc
  前期介绍过此一航空通讯频谱监视系统的通讯接收机后,本期继绩介绍其中的要角: ne602。它是内含本地振荡的单晶片变频器,在超外差式接收机或发射机中,可以扮 演变频器的角色,独挑中频线路。除此之外,也可以供做简易的频谱分析仪,从极低 的频率到极高频范围内的接收机中,都可用做接收机的前端线路,甚至可以单独地完 成一部简易的接收机…
  销售市场上有抢手货,市场有畅销书,电子零件市场亦复如此。记得当初,计时 ic555 出现时,造成轰动,时至今日,仍历久不衰,依然是一只受到普遍采用的计时 ic。如今,原为行动无线电话机而设计的 ic,ne602,应用广泛,也可能成为紧接 555 之后的另一只热门 ic。
  ne602 是内含本地振荡的单晶片变频器,在超外差式接收机或发射机中,它可以扮演 变频器的角色,独挑中频线路。
  除此之外,他也可以供做简易的频谱分析仪。从极低的频率到极高频率范围内的接收 机中,都可拿它用做接收机的前端 (front ended) 线路,甚至,以此 ic 为中心, 便可以单独地完成一部简易的接收机。
  功能强,是它被广泛应用的主因,但是,这只 ic 更大的特色是,容易使用,即使在 没有任何测试仪器的协助下,也不难利用此 ic,去完成一些普遍的应用线路。
  概述
  ne602 单晶片里头,就包含有混频器及可做本地振荡器的主要零件,它是八脚的 dip 包装。ne602ad 及 ne602an 则是经过改良的新版 ic。
gtc式的混频器
  ne602 内的变频器是一个 gtc(gilbert transconductance cell),它有混频的功能 ,但比双平衡变频器 (dbm) 还好。 gtc 是如此好用,因此在各类的倍频器及振幅调 制器当中,都不难发现 gtc 的踪迹。
  gtc 与由二极体组成的变平衡混频器大不相同,gtc 是由电晶体之类的主动元件所组 成,它的优点是,灵敏度高,可以处理低到微伏 (uv) 的讯号,更重要的是,它对于 本地振荡或射频输入端的射频讯号,只产生该有的反应,对射频外泄有很好的抑制能 力;而其它种类的混频器,则容易经由输出管道,外泄射频讯号,如果在线路的设计 上发生了射频外泄时,是会很折腾人的;必需要附加一些过滤射频的相关线路,以防 止这类现像发生,或减少射频外泄程度。
  ne602 不仅输出端不会把高振幅的本地振荡讯号外泄,而且,其输出讯号还可以直接 推动后面的线路,也不会有超载之处。对于一个没有任何外加射频放大器牵涉在内。 以 ne602 为主的线路而言,能有如此高的灵敏度,的确真叫人吃惊。
  此片 ic 可以处理低到微伏的无线电讯号,而一般接收机系统中,天线感应所得的讯 号,也在这个等级,因此,即使不再添加任何射频放大线路, ne602 可以说是用来 处理接收机前端线路的最佳选择。
  动态范围
  ne602 的动态范围不能说是很理想,不过它可以接受的最大讯号强度是 "-15dbm", 可以动作的最低讯号强度是 "-25dbm" 或更低一些。这种处理的能力,可谓不低也不 高。"-25dbm" 在 50 欧姆负载下,大约是 12.5 毫伏,这强度规模对接收无线电讯 号而言是太高了些,但在混频器的线路内,则稍嫌低些。
  工作频率
  ne602 内的 gtc 混频器,工作频率可高达 500mhz 左右。而可内含的本地振荡线路 ,实际上是一只高截止频率的 npn 型电晶体,其振荡频率可高达 200mhz 左右,该 电晶体的基极与射极,可由 ic 脚接触,所以可供外部自由运用。
  ic包装接脚
  ne602 的接脚安排,如图 1 所示,脚一及脚二是射频的差动输入;第三脚是接地; 四脚与五脚则是推挽式输出,但两只脚均分别可成为单端点输出 (single-ended output);第六脚及第七脚分别是振荡电晶体的基极与射极;第八脚则是电源输入端。
  如何供应电源
  ne602 是属于低电压、低电流的设计,它的正常供电范围是 4.5~8.0 伏之间,耗电 流通常低于 3 毫安培,若能借用 ttl 使用的 5 伏电源,应颇为理想,要是使用 006p 9 伏干电池供电,则应特别小心,
  图 2 是几种典型的供电线路。图 2a 是利用抗高频扼流圈做“去耦合”,扼流圈 l1 及去耦合电容 c1 的组合,可以防止 ne602 内部的任何射频讯号,经由电源管道流 窜到别处,或被它处的射频流入 ne602 内。
  决定 l1 的基本原则是,3mhz 以下为 25 毫亨利,3~30mhz 之间采用 1 毫亨利, 30mhz 以上一律采用 100 微亨利。
  设计时,ne602 与 l1 及 c1 应该紧靠在一起,以免效果被大打折扣,这个例子的供 电形式,务必介于 4.5~8.0 伏之间。
  图 2b 是很实用的一个线路,普受欢迎,电源经由 100 欧姆的电阻之后,再供给 ne602,并且利用电容做去耦合。与图 2b 相类似的图 2c,虽然使用 9 伏供电,但 电阻 r1 可以降低电压,使第八脚上的电压不会超过 8 伏特。
  在某些情况下,很难提供稳定的直流电压,像汽车电瓶就是一个很好的例子,它可能 低至 11 伏以下,高到 14.5 伏,如果发生异常现像的话,更可能高达 18 伏。
  就算利用市电为电源。也有稳压的必要,因为墙壁上的 ac 电源,在 105 到 127 伏 之间,都算是正常的。这种情况下,使用图 2d 的线路,既可降低过高的电压,又有 稳压的功能。
  图 2d 的要角是稽纳二极体 d1,这里可以选用 5.6 伏、6.8 伏或 8.2 伏中的任何 一种,耐功率可以是半瓦或一瓦。
  图 2e 中,动用了稳压 ic,动用 7805,虽有班门弄斧的味道,也可说是杀鸡用牛刀 。基本上,7805 散热得宜的话,可提供高达 1 安培的电流,而一只 ne602 才不过 耗用小小的 3 毫安培而已,因此,你可以改用小黑豆型的 78l05,当然,你也可以 使用 78l06 或 78l08,只是输出电压分别为 6 伏及 8 伏。
  另外,去耦合电容也应紧靠 ne602,至于稳压 ic 输入端的电容,是用来减少开关之 类的杂讯,也不可少。
  输入线路
  ne602 的输入线路。采用差动方式,然而两脚均可以分别成为单端输入,此输入单阻 抗大约是 1.5k 欧姆,如果频率高的话,此阻抗会低些,交流线路最重要的是彼此间 的匹配问题,要讯号通行无阻,不会衍生其它麻烦,就得注意讯号来源与负载端之间 的阻抗匹配是否恰当。
  很明显地,在这里必须把天线来的 50 欧姆或 75 欧姆讯号源,变换为 1500 欧姆, 以便与 ne602 的输入阻抗相匹配。图 3 就是为了解决匹配问题的一些基本组合。这 些线路并非一成不变,更不是非用它不可,只不过这些都是大家常引用的匹配方式, 所以提出来供做参考。
  图 3a 是一高阻抗的单端输入线路,当 ne602 做为混频器或乘积检波器时,此种结 构极为适合,要不然,就是在此输入之前,加用有射频放大器的接收机线路,讯号经 过 c1,耦合进入第一脚,以去除直流成分。第二脚在这里不用,因此利用一只去耦 合电容 c2,以旁路接地。
  图 3b、c、d 三种情况,都是用来接受比 1.5k 欧姆更低阻抗的讯号,例如一般接收 机,标准的天线输入阻抗是 50 欧姆或 75 欧姆。
  图 3b 的阻抗匹配是由 ca 及 cb 来完成,两电容与电感 l1 要安排与所要的频率产 生共振,所以,这种线路比较适合单一频率的应用场合。
  图 3c 则采用射频变压器 t1、 c1,用来配合次级线圈,让我们所要的频率,在这里 产生共振,如果 c1 改用可变电容,那么,可根据 c1 的容量范围大小,调谐到一整 段的频率,而不是单一个频率。
  图 3d 所采用的射频变压器,不再有调谐电容,它改采宽频的射频变压器,因此,可 以处理极大频率范围的讯号,t1 的阻抗比例,则可恨据下列公式求得,
np/ns=zp/zs
np:初级线圈数
ns:次级线圈数
zp:初级阻抗
zs:次级阻抗
  如果拿典型的 zp:50 欧姆,及 zs:1.5k 欧姆,那么套入公式,可求得 np/ns=o.183 ,也就是初级每一圈,次级得为 5.5 圈。
  图 3e 是利用差勤的输入变压器,主要的调谐电容 c1,是按在 ne602 第一脚与接地 之间,只要 c2 在线路上,便会影响次级线圈的共振线路,但 c2 又不得不用,因此 ,只能在 t1 的次级线圈两端并联一电容 cx,来解决这个问题。当 c1 处在电容量 最大时,cx 是用来设定频率的底端,然后可变动 c1,来包含我们所要取得的波段范 围。
  图 3f 则是利用变容二极体,代替图 3e 中的可变电容,变容二极体的间隙电容会随 着加诸其上的逆向电压大小而改变。当调谐电压 vt 改变,二极体 d1 的电容量便随 之而变,而达到调谐共振频率的目的。
  输出线路
  ne602 的输出阻抗是 1.5k 欧姆,与其输入阻抗相同。 ne602 的输出端是一推挽式 ,但是很容易可以改成单端输出,只要在所选 (第四成第五脚 )的输出端,串接去除 直流成分的电容即可,另一端可以放着不管,而不用像输入端一样,不用的另一接脚 必须用电容旁路接地,参看图 4a。
  图 4b 与图 3d 类似,利用一宽频的射频变压器,当然利用相同的公式,其间的阻抗 匹配,也要做好,假设负载是 50 欧姆,那么 t1 的初级及次级圈数比是 5.5:1。
  图 4c 则是在图 4b 中线圈的初级上加一只调谐电容。
  图 4d 则是另外一种完全不同的单端输出线路,它的输出负载为一陶瓷滤波器或石英 晶体滤波器,它可以是一般接收机里头广泛使用的 455khz 或 10.7mhz 中周,当然 ,也可以是 9mhz 的石英晶体滤波器或 260khz、455khz 与 500khz 的机械式滤波器 ,不过,这类型滤波器极为昂贵。
  本地振荡器线路
  要超外差式接收机能正常工作,本地振荡讯号不可少,接收到的射频与本地振荡讯号 ,在混频器中起了作用,分别产生了两讯号之﹝差﹞与﹝和﹞的二个讯号。在超外差 接收机应用上,通常是取﹝差﹞讯号,这也就是我们所称的中频,例如 am 接收机采 用了 455khz 的中频,那么,为了接收 1240khz 的讯号,所以,本地振荡器必需是 1695khz 或 785khz,实际应用上,本地振荡频率采用比接收讯号高 455khz 者,与 直接转换式接收机不同,此接收机的本地振荡与接收讯号相同或几乎相同。
  其实,ne602 的本地振荡讯号也可以由外部供应,图 5a 就是一个典型的例子,外界 的本地振荡讯号经由可去除直流成分的电容,耦合到第六脚,这外界供应的讯号,振 幅大小以 700 毫伏左右为宜。
  图 5b 则是利用内部电晶体的一个可变频率振荡器,此振荡器是哈特莱武,由调谐线 圈的中间抽头,得到回馈。
  图 5c 则是考毕兹式振荡器,回馈讯号来自 c2 与 c3 的分压器抽头。
  图 5d 是并联式基本波石英晶体振荡器组合,c1 为 1000/f,f 是振荡频率,求得的 电容单位是 pf。此处使用的石英晶体应该是并联式,负载电容是 20pf 或 30pf,线 路内的 c3 是用来微调振荡频率,这种线路比较适合固定频率的接收机。
  图 5e 为倍频石英晶体振荡器,极适合 vhf 低阶部份使用,电感是配合 c1 及 c2, 用来使石英晶体振荡器在其倍频产生共振。
  最后看图 5f,这是压控振荡器,线路中采用变容二极体,配合 l1 来取得所需的共 振频率,从线路中的 c1 及 c2,可以看出来,这也是一种与图 5c 相同的考毕兹式 振荡器。
  ne602 是一只设计不错的 ic,它的真正意义在于像是一把钥匙,能让对射频线路并 不限熟悉的人,很容易地打开深锁的大门,进入到射频领域内。动手吧!相信你很快 就能充份运用 ne602 这只 ic。《下期待续》
离线BG7IBQ
只看该作者 10楼 发表于: 2002-12-12
最初由 bg7ibq 发布
航空通讯频谱监视系统(二)
ne602 简介
  概述
gtc式的混频器
  动态范围
  工作频率
  ic包装接脚
  如何供应电源
  输入线路
np/ns=zp/zs
np:初级线圈数
ns:次级线圈数
zp:初级阻抗
zs:次级阻抗
  输出线路
  本地振荡器线路
离线BG7IBQ
只看该作者 11楼 发表于: 2002-12-12
最初由 bg7ibq 发布
离线BG7IBQ
只看该作者 12楼 发表于: 2002-12-12
最初由 bg7ibq 发布
离线BG7IBQ
只看该作者 13楼 发表于: 2002-12-12
最初由 bg7ibq 发布
离线BD7FP
只看该作者 14楼 发表于: 2004-11-10
温习一下           !
离线BG6ADK
只看该作者 15楼 发表于: 2004-11-10
好东西!!!!!!!!!!!!!!!!!!
离线大头
只看该作者 16楼 发表于: 2006-09-23
没看到“图3”啊
[quote=bg7ibq][/quote]
这篇文章不错,但没看到“图3”啊。
离线bg2sv
只看该作者 17楼 发表于: 2006-09-23
又学习了一次.
离线大头
只看该作者 18楼 发表于: 2006-09-23
找到“图3”了
[quote=大头]这篇文章不错,但没看到“图3”啊。[/quote]
加上!
离线BA5SBA
只看该作者 19楼 发表于: 2006-12-28
好好好!!!!!
