  • 3272阅读
  • 11回复
那位可以设计一款QRP用的驻波表,短波5W满量程。 [复制链接]
离线7600
只看楼主 倒序阅读 0楼 发表于: 2008-02-15
如题所述。………
离线BD7LP
只看该作者 1楼 发表于: 2008-02-15
simple rf power meter
many beginners trying out their skill with qrp tx, for the first time have to overcome many problems before they are able to come on the air. on usual complaint is that, every thing is working fine but the signal is not going out. here is a simple set up which will enable them to measure the out put power of their transmitter. all that they require is a good multimeter which has a sensitivety of 20k ohms/4 watts which is adequate for low power transmitters. the 8k resistor should be kept close to the out put terminal of the transmitter. switch on the transmitter in the cw mode and measure the dc voltage with the multimeter. if the voltage is v then the out put power is given by
power = v2/50
the circuit can handle up to 5 watts. above this the diode may go qrt. all components should be mounted as close as possible.
离线BG6QBY
只看该作者 2楼 发表于: 2008-02-15
power = v2/50
这个测功率比swr表准
离线BA5RW
只看该作者 3楼 发表于: 2008-02-15
N年前访钻石做过,有机会将开发一款试试。
离线7600
只看该作者 4楼 发表于: 2008-02-15
设想:插入损耗大点没关系,但要明确损耗量并且本身驻波小,还可以设一个直通开关。
离线szcharle
只看该作者 5楼 发表于: 2008-02-16
忙 没时间 留个记号先!
离线bg7ixa
只看该作者 6楼 发表于: 2008-02-16
刚按二楼的图仿造了一个,可惜刻度不是线性的,那位大哥有刻度表盘!!10w满量程的!提供一下!!
展示一下,还有个电阻值没定下来!!
离线8200
只看该作者 7楼 发表于: 2008-02-16
兄弟,好表头呀!
离线BD7LP
只看该作者 8楼 发表于: 2008-02-16
离线BD7LP
只看该作者 9楼 发表于: 2008-02-17
离线7600
只看该作者 10楼 发表于: 2008-03-03
感觉增加偶合器的匝数以提高表在qrp功率下的感应电压使整流管工作在线性区是重点,后面的直流放大感觉要求不高。
在线BG4WYJ
只看该作者 11楼 发表于: 2008-03-03
9楼那个图的网址是什么?
