  • 3382阅读
  • 2回复
10 METER BEACON LIST [复制链接]
离线BG4XOV
只看楼主 倒序阅读 0楼 发表于: 2008-01-26
10 meter beacon list
ten meter propagation beacons
23 january 2008 00:42 z
c=continuous i=intermittent #=confirmed as active or heard
      ($)=ncdxf/iaru bcn [see end of list]
calls that were listed as qrt? past 90 days were removed from the list.
freq.   call   operation   location       oper notes
28.1154 py4yyf     ? belo horizonte, mg br   # 15w vertical
28.165   fy1fv     ? cacao, french guiana   # ?, ? new
28.1674 lu3dbj     ? quilmes,buenos aires,ar # 5w, vertical
28.170   va3xcd     c oshawa, ontario ca     # 1.5w,1/2 vertical
28.174   9h1ia     c malta               7.5w,vertical new
28.175   ve3ten     c ottawa, canada       # 10w, gp
28.177   hp1rcp     c cerro jefe, panama     # 5w, vertical
28.177   ve2crh     c quebec city, canada     2w, vertical new
28.180   od5ten     c tripoli, lebanon     # ? qrt
28.180   i1m       c bordighera, italy     # 2/20w, vertical
28.181   va6ck       bassano alberta canada     testing 10 jan 07
28.1825 sv3aqr     c amaliada, greece     # 4w, gp vertical
28.185   i8emg     c cosenza, italy       # 40w, vertical
28.185   va3src     i holland landing,ontario # 5w, vertical
28.1852 lu1ayz     i capital federal cf, arg # ?w, ?   new
28.188   je7ynq     c fukushima, japan     # 50w, dipole
28.190   lu1dz     i buenos aires,arg     # 10w,vertical(temp?)
28.1902 py2sba     i sao paulo, brazil     # ?, ? new
28.1905 va3ror     c orillia, on         # 5w, vertical whip
28.1909 lu7vch     i patagonia,argentina   # 5w, vertical
28.191   va6re     c bassano, ab canada     # 3w, vertical
28.1915 lu1jmc     i gualeguaychu e.r. arg   # 5w, vertical
28.1921 lu2eor     i buenos aires,arg     # ?,?
28.1925 lu2ffv     i san jorge, arg       # 5w gp
28.193   ve4arm     c austin,mb           # 5w, gp
28.194   a47rb     c oman             # 10w, qrt
28.1947 py2ja     c s o paulo,brazil     # 10w, vertical
28.1937 lu2dt     i mar del plata argentina # 2 w, gp vertical
28.1948 cx4dx     ? montevideo uruguay     # 10w, ? new
28.195   lu4eg     c bernal , argentina     # 10w, quad
28.195   iy4m       c bologna , italy (robot) # 20w, 5/8 vertical
28.195   lu6dts     c la plata city, arg     # 5w, vertical
28.195   ve6yf     c edmonton, alberta     # 10w gp
28.196   ea5ahn     c valencia, spain       # ? qrt
28.196   lu4jj     i concordia er, arg     # 4w, 1/4 vertical
28.196   lu7ww     i chubut, arg         # 5w
28.196   vo1mds     i st.johns, nl           5w, vertical new
28.197   ep4hr     i shiraz, iran           5w, gp testing
28.197   ve7mty     c pitt meadows, bc     # 5w, vertical
28.197   lu9auy     i buenos aires, arg     # 10w, 3 ele yagi
28.198   iz0ais     i rome, italy         # 5w, ?
28.198   hb9tc     i canton ticino,swiss alps# 3w, beam
28.1985 lu5fsy     i rafael, arg         # 5w, ?
28.199   lu1fhh     c el trebol sf,arg     # 5w, vertical
28.1995 cx2ddp     i elpinarcanelone uruguay # 30w, vertical new
28.200       ncdxf/iaru international beacon network-
          *see end of list*($)
离线BG4XOV
只看该作者 1楼 发表于: 2008-01-26
28.200   4u1un   c   united nations nyc   # ($)
28.200   ve8at   c   nunavut, canada     # ($)
28.200   w6wx     c   san jose, ca       # ($)
28.200   kh6wo   c   laie,oahu hi       # ($)
28.200   zl6b     c   masterton, new zealand # ($)
28.200   vk6rbp   c   rolystone, australia   # ($)
28.200   ja2igy   c   mt asama, japan     # ($)
28.200   rr9o     c   novosibirsk, russia   # ($)
28.200   vr2b     c   hong kong, china     # ($)
28.200   4s7b     c   colombo,sri lanka     # ($)
28.200   zs6dn   c   pretoria, s.africa   # ($)
28.200   5z4b     c   kiambu kenya, africa   # ($)
28.200   4x6tu   c   tel aviv , israel     # ($)
28.200   oh2b     c   karkkila, finland     # ($)
28.200   cs3b     c   madeira island       # ($)
28.200   lu4aa   c   buenos aires,argentina # ($)tempqrt?
28.200   oa4b     c   lima,peru         # ($)
28.200   yv5b     c   caracas,venezuela     # ($)
each transmission is repeated every three minutes. a transmission
consists of the callsign of the beacon sent at 22 wpm followed by
four 1 second dashes.
the callsign and the first dash is sent at 100watts. the remaining
dashes are sent at 10watts, 1 watt and 0.1 watts.
this listing is by no means complete and totally accurate. if you
know of any information that can be included into this list that is
now indicated with a ? , i would appreciate this info via either
e-mail         wj5o@amsat.org
or snail mail     bill hays   wj5o
            100 rick street
            troy, al 36079
            usa
离线bg7nwf
只看该作者 2楼 发表于: 2008-01-26
给几个我这段时间收到的!!
28.298.05 v73ten
28.268.20 vk8vf
28.188.00 je7ynq
28.263.83 vk6rwa
28.209.00 kh6ap
28.227.88 zl3ten
28.256.53 vk3rmh
28.229.50 zl2mhf
28.229.00
28.260.02 vk5wi
28.224.20 yb9bwn
28.262.10 vk2rsy
祝各位好运!!
