  • 5988阅读
  • 18回复
2008年3月4日将有六颗业余卫星发射 [复制链接]
离线BD4NU
只看该作者 1楼 发表于: 2008-01-23
沙发!
离线bd4rs
只看该作者 2楼 发表于: 2008-01-23
还得在找些详细的资料
http://www.amsat.org/amsat-new/news/
six university cubesat/amateur radio satellites are planned for launch in early march, 2008 from india. full satellite information for each is too lengthy for complete coverage here. below is a summary of the satellites and their frequencies and operating modes (if known).
links to the university cubesat team's web pages with many additional mission details can be found at:
http://www.uk.amsat.org/
http://showcase.netins.net/web/wallio/cubesat.htm (w0rpk cubesat page)
canx-2
university of toronto (canada)
2m cw tlm plus 70cm uplink/13cm downlink (not ax.25)
aausat-ii
aalborg university (denmark)
437.425 afsk & fsk up/downlink
1200-9600bps ax.25
fm cw tlm
compass-1
university of applied sciences (germany)
primary telemetry downlink: 437.405 9600bps fsk ax.25
beacon downlink: 437.275 cw
delfi-c3
technical university of delft (netherlands)
primary telemetry downlink: 145.870 mhz 1200 baud bpsk ax.25 400mw
backup telemetry downlink: 145.930 mhz 1200 baud bpsk ax.25 400mw
the satellite will be in telemetry only mode for approximately
the first three months of the mission, after which it is switched
to linear transponder mode.
downlink: 145.880 - 145.920 mhz (inverting) 400mw pep
uplink: 435.570 - 435.530 mhz
transponder mode beacon: 145.870 mhz cw (10db below transponder pep)
cute 1.7+apd ii
tokyo institute of technology (japan)
srll protocol
seeds
nihon university (japan)
437.485mhz ax.25 (450mw)
cw (90mw)
离线adiadi
只看该作者 3楼 发表于: 2008-01-23
离线BA6QH/QRP
只看该作者 4楼 发表于: 2008-01-23
我们的“奥运星”要加油了啊!!!
离线bd4jp
只看该作者 5楼 发表于: 2008-01-23
有几个能真正用的?
离线浦东星
只看该作者 6楼 发表于: 2008-03-07
[quote=bd5rv]将有六颗业余卫星预计于今年3月4日从印度发射升空,其中包括等待已久的delfi-c3。
她们是
离线anybody-hf
只看该作者 7楼 发表于: 2008-03-08
别人的大学忙着发小卫星,我们的忙着磨芯片
离线BD3RJ
只看该作者 8楼 发表于: 2008-03-08
>delfi-c3
bpsk 很麻煩, 估計用的是 ssb 收發模式.
而且是1200bps的bpsk,看来不是一般人能玩的.
离线bd5rv
只看该作者 9楼 发表于: 2008-04-16
离线bd4rs
只看该作者 10楼 发表于: 2008-04-17
这颗业余卫星很值得关注!感觉很新颖!
http://www.delfic3.nl/index.php?option=com_content&task=view&id=67&itemid=109
离线bv2ac
只看该作者 11楼 发表于: 2008-04-17
uv 天線構造是全向性的, 有感測太陽裝置表示有一定的姿勢控制能力, 姿勢控制大概是配合地球感測器, 驅動線圈, 產生與地球磁場箱對抗的吸力或斥力,.... 原網站沒交代太多細節....
离线bd5rv
只看该作者 12楼 发表于: 2008-04-19
delfi-c3的blog
http://www.delfic3.nl/photoblog/
他们已经完成所有发射前的检查工作,就等着上天了
离线bd4rs
只看该作者 13楼 发表于: 2008-04-19
telemetry decoding software: rascal
rascal is the name of the software package that we, the delfi-c3 team, are offering to radio-amateurs around the world to be able to collect and decode data of the delfi-c3 satellite. rascal does this by decoding the incoming audio-signal on the system's soundcard that is originating from a transceiver tuned to the frequency of the delfi-c3 telemetry downlink. next to decoding and making the telemetry information visible to the users, rascal also stores and forwards the telemetry to our data collection server(s).
准备下载个译码软件研究研究。
好像头三个月只工作在数据模式下。
离线bv2ac
只看该作者 14楼 发表于: 2008-04-19
希望中國 bh-01 設計小組也有 blog 能告訴大家一些點滴.....
离线bd5rv
只看该作者 15楼 发表于: 2008-04-19
什么是bh-01?
离线bv2ac
只看该作者 16楼 发表于: 2008-04-19
什么是bh-01?
ba1du 正在開發的奧運業餘衛星.... 由於沒有公告任何名稱資訊, 我暫且替它取的乳名....
离线bd4rs
只看该作者 17楼 发表于: 2008-04-19
这里能看到暂且的大名
cas-1 updated: 18/08/2007 responsible operator alan kung ba1du
离线bv2ac
只看该作者 18楼 发表于: 2008-04-20
衛星可以有許多名字.
jas-2, fo-29, fuji3號, 8j1jcs 都是指同一衛星.
