  • 3471阅读
  • 3回复
2008 Ducie Island Expedition: VP6DX [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2008-01-15
all equipment that was shipped from germany and the usa has now arrived in new zealand, and everything except the last air freight shipment (laptops, microkeyers) has cleared customs in auckland. this equipment is now traveling by truck to tauranga, the home port of the "braveheart".
on thursday night this week robin wa6cdr flies from los angeles to auckland with the radios and a few other last-minute items. robin will sail with the "braveheart" when it leaves new zealand january 21st. during the 2 weeks of the voyage from tauranga to magareva, robin will work onconsolidating all the different shipments into the needed order for orderly transport to shore. lets hope the sea weather is kind!
the expedition team also wired funds due under its contract with the "braveheart" management company for fuel, use of the ship and crew. during 2007 oil prices have increased substantially on world markets, and the us dollar has declined in strength on world currency markets. these twochanges have increased the cost of the dxpedition, in us dollar terms, by us$20,000.
qsl information:
on-line qsl information has been added to the website, www.vp6dx.com.
no need to fill out a card or write a letter... and no need forself-addressed envelopes! just fill out an on-line form to request qsls.
donors will receive accelerated, automated processing of their request. verified contacts will be confirmed romptly as soon as printed cards are available after the expedition. lotw confirmations will also be accelerated.
non-donors will have their requested and verified contacts confirmed with a printed qsl card, sent via the bureau, and a lotw entry at a later date.
for people who prefer not to use on-line forms or make on-line donations, the website explains how to submit a paper request.
thanks to dl1mgb, df3cb and om1avk for the implementation of on-line qsl processing.
site planning:
the "braveheart" is permitted to carry 13 passengers. with careful scheduling, 13 operators can staff 7 operating positions 24 hours per day.
each operator will be on-air 12-13 hours per day, typically in three-hour shifts with breaks of one hour for meals and other camp jobs. by avoiding long operating shifts, operators will be more alert and logging accuracy should improve.
given likely propagation, how can 7 operating positions be best used? late at night 160 through 30, and perhaps 20m, may be the only open bands. our solution: two operating locations, separated by about 1.5 km.
the west site will host three operating positions, plus these antennas:
-- 75m ssb and 40m: 4-squares.
-- 20, 17, 15, 12, and 10m: 2-element vertical dipole arrays.
the east site, near the only safe landing point, will host four operating positions plus these antennas:
-- 160m: one or two element verticals.
-- 80m cw, 40m, and 30m: 4-squares.
-- 6m: 5-el yagi (we will try vertical polarization).
the east site also contains our sleeping tents and eating / relaxing area.
with the exception of the narrow 160m and 30m bands, the large separation between sites should permit us to put two stations on any lf/hf band. the actual hour-by-hour allocation of stations to bands/modes depends on:
-- propagation: priority given to "edge" bands with the most difficult propagation.
-- geographical balance: priority given parts of the world under-represented in qsos made to date on a particular band-mode.
-- mode balance: priority given to modes under-represented in qsos made to date during band's opening with a particular region.
low band receiving antennas will be midway between the east and west sites. these will be reversible beverage arrays, with each antenna split out into a separate 160m, 80m cw and 75m output (w3lpl bandpass filters).
the low band operators can choose their listening antenna independently via a remote controlled switching up.
dx engineering pre-amps boost the signal from the selected antenna before it travels down the long coax run (750m) to the operator's k3 radio.
the pre-amps are protected from the low band transmit signals through a combination of bandpass filters, custom notch filters (for example, to reject the 80m cw transmitter on the 75m ssb operator's antenna), physical separation from the transmit antennas, and other measures.
a sketch of the site layout will be posted to the website shortly.
73
carsten, dl6lau and eric, k3na
http://www.vp6dx.com/
离线ahhui
只看该作者 1楼 发表于: 2008-01-15
清一色的vertical antenna啊,连6米的yagi也要垂直架设。
离线BA7JS
只看该作者 2楼 发表于: 2008-01-15
这才够男人啊!
离线BA6QH/QRP
只看该作者 3楼 发表于: 2008-01-16
等着吧,这个关注很久啦
