  • 12123阅读
  • 97回复
CQ CQ at 3.795mhz LSB tonight [复制链接]
离线bu2aq
只看楼主 倒序阅读 0楼 发表于: 2008-01-07
今天開始21:00bjt,cq cq bravo at 3.795mhz lsb .
离线bu2aq
只看该作者 1楼 发表于: 2008-01-07
改在 3.575mhz lsb cQ CQ
离线bu2aq
只看该作者 2楼 发表于: 2008-01-07
20:30bjt ba4xa 59/59
20:47bjt ji1rlj 57/55
离线bu2aq
只看该作者 3楼 发表于: 2008-01-07
qsy to 3.580mhz due to qrm since 21:00bjt
离线BA4II
只看该作者 4楼 发表于: 2008-01-07
哈哈!没有到9点我就调好频率等待。9点开始在3.795没有听到,3.7966有别人在通联(同时还有军队在通练习cw报文)。后来转到3.580终于通到bu2aq老朋友!我抄收58,2aq给我55的信号报告。山东到台湾80米传播不错,好高兴!
离线BG5RAS
只看该作者 5楼 发表于: 2008-01-07
我们是不是越距了?我这可以听到您58的信号,但呼不到您,您只抄收到了bg5前缀.
离线bu2aq
只看该作者 6楼 发表于: 2008-01-07
yes!bg5...
离线BA4II
只看该作者 7楼 发表于: 2008-01-07
他已经抄到您的bg5,请您继续!
离线BA4II
只看该作者 8楼 发表于: 2008-01-07
bu2aq还在80米呼叫,大家赶快去通,信号不错,有时信号可以到59+。
离线BA7JS
只看该作者 9楼 发表于: 2008-01-07
打雷一样 :d
离线BG5RAS
只看该作者 10楼 发表于: 2008-01-07
ok,抄我53!呵呵,天线还要好好收拾一下.
离线bu2aq
只看该作者 11楼 发表于: 2008-01-07
21:21bjt bg7jsq 59/54   21:09bjt bd4izl 58/55
21:23bjt bg5ras 58/53
noise s-8,
21:00bjt 3.575mhz qrm 59+40,so qsy to 3.580mhz
21:40bjt qrt
antenna:wire loop(horizontal),total length 90 m(hexagon),10 m high above ground + 4:1 balun with 5 m(450 ohm ladder) + coax (6m) +txv with internal atu
离线BA4II
只看该作者 12楼 发表于: 2008-01-07
noise s-8,
21:40bjt qrt
明天早上还在80米呼叫吗?我继续守侯!
离线BA7JS
只看该作者 13楼 发表于: 2008-01-07
to bu2aq:
再晚一个小时,到23:00以后(北京时间),可以听到北美的big gun以及欧洲的电台,stay tuned! :d
下面是昨天一位苏格兰om给俺的email:
80m qso gm3mou
hi liu,
          nice signal today, please try and get on the band again.
  using a 4 sq. here with an extended radial system.
  don't hear too many on ssb from your part of the world.
        73   gavin gm3mou
re:80m qso gm3mou
hi gavin,
thank you for a fb qso last night. your signal was peaking at 57/58 here in south china. worked another sm station and understand there were a few callers from your part of the world, but all under the noise level.
i prefer cw so most of my qsos are made in that mode, hi! we are experiecing very good low band propagations into europe now in this solar minimum and the best time is always in the middle of night, that is at your sunset i guess.
working conditions here is a yaesu ft450 and horizontal loop antenna, no linear,amps etc. will try to hear 80 and 40 meters around utc 14:00 and hope to work you again.
hny 2oo8 es best dx, 73
liu bg7jsq
离线BA1RB
只看该作者 14楼 发表于: 2008-01-08
noise s-8,
21:40bjt qrt
俺2150bjt上来,发现qrt了...
离线BA1RB
只看该作者 15楼 发表于: 2008-01-08
to bu2aq:
80m qso gm3mou
hi liu,
        73   gavin gm3mou
re:80m qso gm3mou
hi gavin,
liu bg7jsq
昨天晚上9:50听到hl的电台和北美的电台在3795 qso,ssb,hl俺听得很响,北美的电台隐约有些信号。如果能坚持到下半夜欧洲应该不错。
离线bu2aq
只看该作者 16楼 发表于: 2008-01-08
will to cq cq at 3.795 or 3.580 mhz lsb since 22:00bjt( 2008-01-08).
cuagn!!!! to all om!!!
离线BA5AG
只看该作者 17楼 发表于: 2008-01-08
wait 4 u tonight, if my wife permits
离线BA4II
只看该作者 18楼 发表于: 2008-01-08
bu2aq老朋友明天我给您寄卡,主要想索原来咱们在29。6fm通的卡片!
离线BA4MY
只看该作者 19楼 发表于: 2008-01-08
在济南听到了来自美国的信号
bu2aq 47 与w1ksz 37 qso
