  • 4773阅读
  • 6回复
能不能用软件模拟aprs数据通过串口发给uiview [复制链接]
离线BG3OGR
只看楼主 倒序阅读 0楼 发表于: 2008-01-01
tnc可以通过计算机的串口发送数据给uiview或agwtracker,假如我想编制一个小软件,模拟tnc给uiview/agw传送数据,我现在想知道的是,这样的一祯数据应该是什么格式呢?请老师赐教。
离线BG3OGR
只看该作者 1楼 发表于: 2008-01-02
这里真冷清阿
离线BD4OS
只看该作者 2楼 发表于: 2008-01-02
怎么说呢,tnc跟应用软件连接有多种方式,而每种方式在传送同一内容时的数据格式不尽相同,拿ui-view32来说可以使用的模式有dde,kiss,agwpe,flexnet,wa8ded以及bpq等方式,其每种方式在串口端的数据结构是不一样的。
离线BG3OGR
只看该作者 3楼 发表于: 2008-01-02
ui-view32可以使用的模式有dde,kiss,agwpe,flexnet,wa8ded以及bpq等方式,麻烦您给说一下其中一种,比如kiss,谢谢您了!
离线BD4OS
只看该作者 4楼 发表于: 2008-01-06
the kiss tnc: a simple host-to-tnc communications protocol
mike chepponis, k3mc
phil karn, ka9q
presented at the arrl 6th computer networking conference, redondo beach ca, 1987.
translated to html by ka9q, january 1997.
abstract
the kiss ("keep it simple, stupid") tnc provides direct computer to tnc communication using a simple protocol described here. many tncs now implement it, including the tapr tnc-1 and tnc-2 (and their clones), the venerable vadcg tnc, the aea pk-232/pk-87 and all tncs in the kantronics line. kiss has quickly become the protocol of choice for tcp/ip operation and multi-connect bbs software.
1. introduction
standard tnc software was written with human users in mind; unfortunately, commands and responses well suited for human use are ill-adapted for host computer use, and vice versa. this is especially true for multi-user servers such as bulletin boards which must multiplex data from several network connections across a single host/tnc link. in addition, experimentation with new link level protocols is greatly hampered because there may very well be no way at all to generate or receive frames in the desired format without reprogramming the tnc.
the kiss tnc solves these problems by eliminating as much as possible from the tnc software, giving the attached host complete control over and access to the contents of the hdlc frames transmitted and received over the air. this is central to the kiss philosophy: the host software should have control over all tnc functions at the lowest possible level.
the ax.25 protocol is removed entirely from the tnc, as are all command interpreters and the like. the tnc simply converts between synchronous hdlc, spoken on the full- or half-duplex radio channel, and a special asynchronous, full duplex frame format spoken on the host/tnc link. every frame received on the hdlc link is passed intact to the host once it has been translated to the asynchronous format; likewise, asynchronous frames from the host are transmitted on the radio channel once they have been converted to hdlc format.
of course, this means that the bulk of ax.25 (or another protocol) must now be implemented on the host system. this is acceptable, however, considering the greatly increased flexibility and reduced overall complexity that comes from allowing the protocol to reside on the same machine with the applications to which it is closely coupled.
it should be stressed that the kiss tnc was intended only as a stopgap. ideally, host computers would have hdlc interfaces of their own, making separate tncs unnecessary. [15] unfortunately, hdlc interfaces are rare, although they are starting to appear for the ibm pc. the kiss tnc therefore becomes the "next best thing" to a real hdlc interface, since the host computer only needs an ordinary asynchronous interface.
2. asynchronous frame format
the "asynchronous packet protocol" spoken between the host and tnc is very simple, since its only function is to delimit frames. each frame is both preceded and followed by a special fend (frame end) character, analogous to an hdlc flag. no crc or checksum is provided. in addition, no rs-232c handshaking signals are employed.
the special characters are:
abbreviation         description             hex value
  fend           frame end                 c0
  fesc           frame escape               db
  tfend           transposed frame end           dc
  tfesc           transposed frame escape         dd
the reason for both preceding and ending frames with fends is to improve performance when there is noise on the asynch line. the fend at the beginning of a frame serves to "flush out" any accumulated garbage into a separate frame (which will be discarded by the upper layer protocol) instead of sticking it on the front of an otherwise good frame. as with back-to-back flags in hdlc, two fend characters in a row should not be interpreted as delimiting an empty frame.
3. transparency
frames are sent in 8-bit binary; the asynchronous link is set to 8 data bits, 1 stop bit, and no parity. if a fend ever appears in the data, it is translated into the two byte sequence fesc tfend (frame escape, transposed frame end). likewise, if the fesc character ever appears in the user data, it is replaced with the two character sequence fesc tfesc (frame escape, transposed frame escape).
as characters arrive at the receiver, they are appended to a buffer containing the current frame. receiving a fend marks the end of the current frame. receipt of a fesc puts the receiver into "escaped mode", causing the receiver to translate a following tfesc or tfend back to fesc or fend, respectively, before adding it to the receive buffer and leaving escaped mode. receipt of any character other than tfesc or tfend while in escaped mode is an error; no action is taken and frame assembly continues. a tfend or tesc received while not in escaped mode is treated as an ordinary data character.
this procedure may seem somewhat complicated, but it is easy to implement and recovers quickly from errors. in particular, the fend character is never sent over the channel except as an actual end-of-frame indication. this ensures that any intact frame (properly delimited by fend characters) will always be received properly regardless of the starting state of the receiver or corruption of the preceding frame.
this asynchronous framing protocol is identical to "slip" (serial line ip), a popular method for sending arpa ip datagrams across asynchronous links. it could also form the basis of an asynchronous amateur packet radio link protocol that avoids the complexity of hdlc on slow speed channels.
4. control of the kiss tnc
each asynchronous data frame sent to the tnc is converted back into "pure" form and queued for transmission as a separate hdlc frame. although removing the human interface and the ax.25 protocol from the tnc makes most existing tnc commands unnecessary (i.e., they become host functions), the tnc is still responsible for keying the transmitter's ptt line and deferring to other activity on the radio channel. it is therefore necessary to allow the host to control a few tnc parameters, namely the transmitter keyup delay, the transmitter persistence variables and any special hardware that a particular tnc may have.
to distinguish between command and data frames on the host/tnc link, the first byte of each asynchronous frame between host and tnc is a "type" indicator. this type indicator byte is broken into two 4-bit nibbles so that the low-order nibble indicates the command number (given in the table below) and the high-order nibble indicates the port number for that particular command. in systems with only one hdlc port, it is by definition port 0. in multi-port tncs, the upper 4 bits of the type indicator byte can specify one of up to sixteen ports. the following commands are defined in frames to the tnc (the "command" field is in hexadecimal):
command     function       comments
  0       data frame     the rest of the frame is data to
                    be sent on the hdlc channel.
  1       txdelay       the next byte is the transmitter
                    keyup delay in 10 ms units.
                     the default start-up value is 50
                    (i.e., 500 ms).
  2       p           the next byte is the persistence
                    parameter, p, scaled to the range
                    0 - 255 with the following
                    formula:
                          p = p * 256 - 1
                    the default value is p = 63
                    (i.e., p = 0.25).
  3       slottime       the next byte is the slot interval
                    in 10 ms units.
                    the default is 10 (i.e., 100ms).
  4       txtail       the next byte is the time to hold
                    up the tx after the fcs has been
                    sent, in 10 ms units. this command
                    is obsolete, and is included here
                    only for compatibility with some
                    existing implementations.
  5       fullduplex     the next byte is 0 for half duplex,
                    nonzero for full duplex.
                    the default is 0
                    (i.e., half duplex).
  6       sethardware     specific for each tnc. in the
                    tnc-1, this command sets the
                    modem speed. other implementations
                    may use this function for   other
                    hardware-specific   functions.
  ff       return         exit kiss and return control to a
                    higher-level program. this is useful
                    only when kiss is incorporated
                    into the tnc along with other
                    applications.
the following types are defined in frames to the host:
type                  function            comments
0           data frame     rest of frame is data from
                        the hdlc channel.
no other types are defined; in particular, there is no provision for acknowledging data or command frames sent to the tnc. kiss implementations must ignore any unsupported command types. all kiss implementations must implement commands 0,1,2,3 and 5; the others are optional.
5. buffer and packet size limits
one of the things that makes the kiss tnc simple is the deliberate lack of tnc/host flow control. the host computers run a higher level protocol (typically tcp, but ax.25 in the connected mode also qualifies) that handles flow control on an end-to-end basis. ideally, the tnc would always have more buffer memory than the sum of all the flow control windows of all of the logical connections using it at that moment. this would allow for the worst case (i.e., all users sending simultaneously). in practice, however, many (if not most) user connections are idle for long periods of time, so buffer memory may be safely "overbooked". when the occasional "bump" occurs, the tnc must drop the packet gracefully, i.e., ignore it without crashing or losing packets already queued. the higher level protocol is expected to recover by "backing off" and retransmitting the packet at a later time, just as it does whenever a packet is lost in the network for any other reason. as long as this occurs infrequently, the performance degradation is slight; therefore the tnc should provide as much packet buffering as possible, limited only by available ram.
individual packets at least 1024 bytes long should be allowed. as with buffer queues, it is recommended that no artificial limits be placed on packet size. for example, the k3mc code running on a tnc-2 with 32k of ram can send and receive 30k byte packets, although this is admittedly rather extreme. large packets reduce protocol overhead on good channels. they are essential for good performance when operating on high speed modems such as the new wa4dsy 56 kbps design.
6. persistence
the p and slottime parameters are used to implement true p-persistent csma. this works as follows:
whenever the host queues data for transmission, the tnc begins monitoring the carrier detect signal from the modem. it waits indefinitely for this signal to go inactive. when the channel clears, the tnc generates a random number between 0 and 1. [2] if this number is less than or equal to the parameter p, the tnc keys the transmitter, waits .01 * txdelay seconds, and transmits all queued frames. the tnc then unkeys the transmitter and goes back to the idle state. if the random number is greater than p, the tnc delays .01 * slottime seconds and repeats the procedure beginning with the sampling of the carrier detect signal. (if the carrier detect signal has gone active in the meantime, the tnc again waits for it to clear before continuing). note that p = 1 means "transmit as soon as the channel clears"; in this case the p-persistence algorithm degenerates into the 1-persistent csma generally used by conventional ax.25 tncs.
p-persistence causes the tnc to wait for an exponentially-distributed random interval after sensing that the channel has gone clear before attempting to transmit. with proper tuning of the parameters p and slottime, several stations with traffic to send are much less likely to collide with each other when they all see the channel go clear. one transmits first and the others see it in time to prevent a collision, and the channel to conform to the literature, here p takes on values between 0 to 1. however, fractions are difficult to use in a fixed point microprocessor so the kiss tnc actually works with p values that are rescaled to the range 0 to 255. to avoid confusion, we will use lower-case p to mean the former (0-1) and upper-case p whenever we mean the latter (0-255). remains stable under heavy load. see references [1] through [13] for details.
we believe that optimum p and slottime values could be computed automatically. this could be done by noting the channel occupancy and the length of the frames on the channel. we are proceeding with a simulation of the p-persistence algorithm described here that we hope will allow us to construct an automatic algorithm for p and slottime selection.
we added p-persistence to the kiss tnc because it was a convenient opportunity to do so. however, it is not inherently associated with kiss nor with new protocols such as tcp/ip. rather, persistence is a channel access protocol that can yield dramatic performance improvements regardless of the higher level protocol in use; we urge it be added to every tnc, whether or not it supports kiss.
离线BD4OS
只看该作者 5楼 发表于: 2008-01-06
另外还有一份6pack协议的介绍给你参考,我记得以前德国人给我一份完整的wa8ded协议(即常见的tf)等我找找我的一台老机器看看能不能翻出来。
附件: 6pack.pdf (0 K) 下载次数:70
离线BG3OGR
只看该作者 6楼 发表于: 2008-01-12
e文,好怕,谢谢4os!
