  • 10518阅读
  • 18回复
一个好电路(6P1+Fu7)+一篇好文章 [复制链接]
离线刘新阳
只看楼主 倒序阅读 0楼 发表于: 2007-12-14
最近在qsl上闲逛,发现一个我向往已久的电子管cw发射机的,管子好找,而且电路简单,仔细看了看作者的描述,发现这不仅是一篇电路制作说明,而且还是一篇很好的散文呢,作者回顾了他自从少年时代的发烧史,小时候翻阅手头上有限的资料,遇到喜欢的电路,兴奋异常,可常常因为找不到合适的元件而只好望图兴叹,很多文章的作者都是他们的电路所用的元件都是在你的“垃圾箱”里可以找到的,于是他开始羡慕有这样的“垃圾箱”的人,于是开始收藏各种能得到的元件,随着自己“垃圾箱”内容的丰富,有了一个梦想,希望有一天能够利用手头上的元件完成一件自己满意的作品,于是又开始翻阅资料,动手尝试,终于迎来梦圆的那一天……看着看着,我仿佛看到了自己的影子,小时候也曾经翻阅老爸当年订阅的70年代末80年代初的《无线电》,很多文章的作者挂在嘴边上的话就是某某元件“业余品”即可,可我有时连业余品也找不到,当我有一天终于凑齐元件,焊成一个无线话筒,并用收音机收到信号时,那个高兴啊,简直是彻夜难免……现在工作了,有了时间,本着怀旧的心态又焊无线话筒玩,可发现元件和工具都不是问题了,就是成功率还不及当年了,后来才发现城市里十几个调频台都信号超强,而当时我在家乡的小城,只有一两个调频台,哎……
the "secret dream" transmitter
a simple and nostalgic project.
by steve johnston, wd8das
when i was a teenager in the 1970s, constructing electronic projects could be frustrating. the once-common full line radio parts shops had closed and with them went the easiest sources of parts for the radio devices i wanted to build. it didn't help that the books and magazines i was reading were filled with projects built with 1950's and 60's parts. the only parts store left open, radio shack, had only a limited selection of modern items.
nearly every electronic construction article mentioned that some of the parts would be found in the reader's "junk box". this rather mysterious box, not unlike pandora's, held the important stuff needed for the project. self-reliance is a great thing -- but as a beginner without a well-stocked "junk-box" most of my building plans were dead in the water.
my secret dream has been that one day i would be able to build complete projects without the hassle and delay of buying parts. to combat this frustration, over the years i've tended to collect inexpensive parts and equipment from hamfests, auctions, estate sales, and the like, organizing them for future use. i haven't been a maniac about it; cross-country moves, forays into other hobbies, and the growth of our family have limited the size of my "junk-box" (i wonder if my wife would agree that i've "limited" my collecting?). to keep the cost reasonable i focused my efforts on older parts. along the way i've put my stock to good use as i repaired and restored classic radio gear, but i continued to find that i still needed to order parts to build anything from scratch. would the day ever come that i could get an idea and just build it?
a couple weeks ago some friends and i were swapping email messages about building some very simple cw transmitters from 2n2222 transistors. i'm known for my love of vintage radio gear, so i felt obliged to jokingly reply that i should build an equivalent tube rig just to be different. then i felt the tingle, the itch... i started to look back over my books and magazines... i found myself lingering in the garage staring at my "junk" collection... could i do it? had i finally reached the point where i could fulfill my "secret dream"? could i design and build a tube rig using parts already on hand?
the first task was to design a simple, effective cw rig using vintage parts. my research sources for the project included the...
1962 rca tt-5 transmitting tube manual
arrl "handbooks" of 1945, ཮, ཷ, ཾ, and 1975
radio magazine/editors and engineers radio handbooks from 1938 - 1975
arrl's 1971 "understanding amateur radio".
the latter is one of my most cherished books on ham radio. when i was starting out as a novice i read "understanding amateur radio" over and over -- it's great.
in keeping with the goals of simplicity and nostalgia, i envisioned a transmitter such as a beginner would have built in the mid-to-late 1950's. as i perused the journals this idea gelled into a design based on an electron-coupled colpitts crystal oscillator using a 6ag7 metal tube and a dual-807 power amplifier. the only semi-modern feature would be a pi-network as the pa tank circuit (see schematic).
bandswitching was considered -- and rejected. the prototype would be built for 40 meters and if successful, plug-in oscillator coils and the movable tap on the pa tank coil could be used later to allow band changes.
cathode keying is one of the simplest ways to put some intelligence on the carrier, so it seemed the logical choice for this design.
my choice of chassis was a major turning point in the project. i'd selected a metal chassis and a very professional-looking instrument case from the garage when i realized i would be hiding the best parts of the rig inside a relatively featureless cabinet. why not build it out in the open on a wooden breadboard? that was, after all, a common construction technique for simple, beginner's tube transmitters. i changed gears, put the metal chassis and case away, and went up to the kitchen. there i found a 8.5" x 13" wooden breadboard with nicely turned edges. it was ready-made for the task -- absolutely no further cutting or sanding was needed.
building the rig on a breadboard made a lot of sense in this application. it gave me an excuse to use the components that have the sexy vintage radio "look" such as cloth-covered wire, copper buss bars, transmitting caps, and the like. the elegant shape and polished glass of the canadian-westinghouse 807s would really catch the eye.
putting artistic concerns aside for the moment, it is important to realize there are serious safety drawbacks to this construction method. the finished product is intrinsically hazardous, with high voltage and rf exposed right out in the open. this won't stop a real ham who is aware of the risks and treats the equipment with due respect, but for an appliance-operator, or even a serious ham who is only familiar with solid-state projects, this could probably result in serious bodily harm. visitors to the shack have to be kept away from it as well ("oooh, that's pretty" zzzzappp!).
due respect means that the operator of breadboard equipment must be ever-mindful of electrical safety. the medium and high dc voltages in this rig can cause death under the right (wrong?) conditions, and the radio-frequency voltages on the final stage and output can cause painful burns.
follow these rules to minimize the chance of shock:
? lay out the circuit so live conductors do not extend beyond the edge of the breadboard.
? use insulated wire and spaghetti tubing to minimize points with exposed voltage.
? don't work on the equipment when tired or angry.
? turn off the power supply every time a circuit change is needed.
? turn off and unplug the power supply if the equipment is to be left unattended.
? keep children, pets, section managers, and other simple folk clear of the energized rig.
? when testing and adjusting the operating transmitter keep one hand in a pocket.
this final rule provides some back-up protection - in case of accidental contact with the circuit the possibility of heart-stopping current flow across the chest is reduced.
construction used normal hand tools. bright-brass wood screws mounted the parts to the board. polished brass l-brackets held the variable capacitors and antenna connector, and screws/spacers mounted the tube sockets. i found the older, flat-plate-style sockets were better for this application. an ft-243 crystal socket was placed along the front edge of the board for quick frequency changes without getting my fingers near the "live wires". (see photos)
my l2 coil is a section of junk airdux or b&w coil stock that i can tap with a clip as needed - as you go higher in the bands less coil is needed so the clip shorts out more turns. you know you've found the right tap point when the transmitter loads to roughly the right value of plate current, say 180 ma, with a nice sharp dip when you adjust the plate tuning cap (the one on the left of the pi network) and you are getting the expected wattage out. as an example, my l2 is 2-1/4" long and 1-7/8" diameter, has 18 turns total (8 turns per inch), and on 40m the last two turns are shorted out by the clip. l1 is a slug-tuned coil from my junkbox... using a grid-dip meter, i just tried various coils from my collection in parallel with the 50 pf variable cap and checked for resonance in the 40m band. let's see... the 50 pf cap has a reactance of about 450 ohms at 7 mhz, so to be resonant the coil will have the same reactance. working backwards 450/6.28x7= about 10 microhenries. but i say make them both adjustable and tune for max drive to the finals!
for convenience i used one of my all-purpose heath hp-23 power supplies under the operating desk to provide the necessary voltages -- but with only three voltages required a dedicated power supply could be fashioned without too much effort.
the initial "test firings" were conducted into a 100-watt light bulb with one hand in my pocket. it worked! the pa was stable, showing no tendency to take-off, and the oscillator ran loud and proud and did not stall under any condition of tuning. listening on a nearby receiver i discovered key-clicks were not a problem, and while i could hear some chirp it was not as bad as some commercial designs. and it was much better than most homebrew solid-state rigs of similar simple design.
i noticed the greatest shift in the oscillator frequency coincided with the pa tuning and loading adjusted for peak output. this indicated that the chirp was due more to the power supply voltage sagging a bit at full power than the changing load on the oscillator. switching to a well-regulated low b+ supply for the oscillator took care of that problem. perhaps one day i'll add a colorful gas-regulator tube to the rig. for now, the stability is quite good for such a simple design.
the brightness of the lamp indicated i was getting significant power out. moving the output to a wattmeter and a 50 ohm dummy load revealed it was making about 85 watts out at the optimum settings for both signal quality and quantity. the scope showed a smooth waveform low in harmonic energy.
the first on-air test was a snap. i tuned around the low end of 40 and heard a strapping signal calling cq within a kilocycle or so of one of my crystals, so i gave him a call. unlike my previous homebrew transmitters (all qrp) this transmitter has some significant rf output, so unless the other op was using a brick for a receiver i should be heard. and since paul, k2ofm, was using a fine old national receiver, he copied me 599. the qso was all the more special when i learned that paul was also running a homebrew transmitter: a solid-state/tube hybrid. how appropriate!
constructing this transmitter from scratch using parts on hand has given me more satisfaction than any hobby project in recent memory. my "secret dream" has been fulfilled.
-end-
-----sidebar-----
sources of classic parts:
hf crystals in ft-243 holders can be a challenge to locate. many show up at hamfests, but few are on useful amateur frequencies! i'm aware of two places to buy new, cut-to-your-frequency, ft-243 crystals:
jan crystals, po box 60017, fort myers, fl 33906-6017, (800) 526-9825.
pr crystals, 2735 avenue a, council bluffs, ia 51501, (712) 323-7539.
i many hams today bemoan the trouble of locating vacuum tubes, but in some respects it has never been easier to find the once-common varieties of tubes. in recent years a number of excellent mail order tube dealers have come forward. examples include...
electron tube enterprises, po box 8311, essex, vt 05451-8311 (802) 879-1844. http://members.aol.com/etetubes/
ersc, 1599 sw 30th ave., unit 4, boynton beach, fl 33426, (561) 737-8044. http://home.att.net/~esrc/esrcmain.html
radio electric supply, po box 1939, melrose fl 32666 (352) 475-1950. http://www.vacuumtubes.net/npage/indexc.html
for tubes, sockets, variable caps, connectors and many, many other classic electronic components, resources include...
antique electronic supply, 6221 s maple ave, tempe, az 85283 (480) 820-5411. http://www.tubesandmore.com/
dan's small parts and kits, po box 3634, missoula, mt 59806-3634 (406) 258-2782. http://www.fix.net/dans.html
ocean state electronics (800) 866-6626. http://www.oceanstateelectronics.com/
fair radio sales, po box 1105, lima, oh 45802 (419) 227-6573. http://www.fairradio.com
离线tbggbt
只看该作者 1楼 发表于: 2007-12-14
有能力的朋友译一下?
离线刘新阳
只看该作者 2楼 发表于: 2007-12-14
其实文中的技术问题并不多,参数都在图上标明了
作者的l2用的是2.25英寸长直径1又7/8英寸的空心线圈,共18匝(每英寸8匝),对于40m波段,后两匝短接。
l1就是普通的铁心线圈
离线珊瑚鱼
只看该作者 3楼 发表于: 2007-12-14
呵呵,好文章,以前我家里有很多五十年代的电子书,上写内部资料,或机密.就有好多这图纸.以前也玩过无数胆机.就是没有装过胆电台.怀念呀.谢谢楼主,顶一个.我在湛江的中继的名字就叫807,可本地有哪个火腿或香肠知道它的含义.在ham这个圈子,我这代人和年轻的有代沟,和老的也有代沟。郁闷。
离线BA6QH/QRP
只看该作者 4楼 发表于: 2007-12-15
不错,最近正在打算用6p1做一个qrp的cw发信机玩玩
离线i387
只看该作者 5楼 发表于: 2007-12-15
大功率的胆机电源比较麻烦我也是觉得6p1搞单管qrp用的小机器比较合适。
用2p2或2j27s做个用电池的直流胆机也是不错的……
离线刘新阳
只看该作者 6楼 发表于: 2007-12-15
区分好零线火线(用3芯插头),倍压整流,用继电器键控,注意安全,还是可以试验一下的。最近工作太忙,打算过些日子做做。
离线珊瑚鱼
只看该作者 7楼 发表于: 2007-12-16
美国人的中功率发射机喜欢用6146,我手里也有些rca 的.手中的2p29s有一瓦的出力,可以用来玩qrp.印象中,外国人在小功率管中,用6v6多一些。严重羡慕有时间diy的朋友。
离线bg7tu
只看该作者 8楼 发表于: 2007-12-16
文化大革命时.6p1都很难搞到呵.公安局证明才可买到.
离线刘新阳
只看该作者 9楼 发表于: 2007-12-17
也见过6v6的图,说6v6时807的小弟弟
呵呵,我好像还见过一个帖子,是一张照片,60、70年代的,凡是能够接触到这类可能用于发射的电子元件的,都要挂一个公安发的证,就是修收音机的也要挂。
现在幸福多了,不过空中秩序也有点太乱了。
离线珊瑚鱼
只看该作者 10楼 发表于: 2007-12-18
哪个年代太特殊了.以前我家里面有个真空管的收音机.几千职工的单位,好象就只有几台.楼主有好的制作,记得通知大家.抽点时间练练手.6v6是一个高效率的束射管.也是一个音响名管.音响爱好者给它的雅称是.高山流水..最能演绎出中国的古琴的韵味.也呼之为琴圣.
离线刘新阳
只看该作者 11楼 发表于: 2007-12-18
对不起记错了是6L6
[quote=刘新阳]也见过6v6的图,说6v6时807的小弟弟
现在幸福多了,不过空中秩序也有点太乱了。[/quote]
说6l6是807的小弟弟
离线珊瑚鱼
只看该作者 12楼 发表于: 2007-12-19
807是大名鼎鼎的6l6的改进型号.两者在低屏压时的特性曲线几乎是一样的.6l6最能表达出电吉它的味道.我以前玩过古典吉它,卡尔卡西的50首练习曲练到第三十三左右就不练了.
离线bd4igh
只看该作者 13楼 发表于: 2007-12-20
能不能用先不说,做的真精细!
离线刘新阳
只看该作者 14楼 发表于: 2007-12-20
我们应该学习老外这种扎扎实实,认认真真,因陋就简,自得其乐的diy精神!
离线bv6fo
只看该作者 15楼 发表于: 2007-12-30
与 6ag7 相近的国内管是 6p9p.
6cl6 是缩小的 6ag7.
离线BH7KQK
只看该作者 16楼 发表于: 2009-07-28
电子管啊!真不错!
离线BG7IR
只看该作者 17楼 发表于: 2009-07-29
学习.学习,认真学习.
离线胆小二
只看该作者 18楼 发表于: 2009-08-25
电子管不错的。
