  • 3184阅读
  • 0回复
常用发射三级管资料 [复制链接]
离线卢炜
只看楼主 倒序阅读 0楼 发表于: 2007-12-03
型号 功率 增益 电压 频率 工作状态 封装 123脚
2n3375 10w 5db 28v 400mhz fm/am/ssb to-60
2n3553 2,5w 10db 28v 175mhz fm/am to-39 c b e
2n3632 20w 7db 28v 175mhz fm to-60
2n3866 5w 10db 28v 400mhz wintransceiver to-39 c b e
2n3924 4w 6db 13,6v 175mhz wintransceiver to-39
2n4427 2w 10db 12v 175mhz wintransceiver to-39
2n5108 1w 5db 24v 1200mhz wintransceiver to-39
2n5109 3,5w 11db 15v 200mhz wintransceiver to-39
2n5421 3w 9db 13,5v 175mhz wintransceiver to-39
2n5913 2w 7db 12,5v 175mhz wintransceiver to-39
2n5943 1w 8db 15v 400mhz fm to-39
2sc730 0,8w 10db 13,5v 175mhz fm to-39 c b e
2sc1096 10w   60mhz fm to-220
2sc1173 10w   100mhz fm/am/ssb to-220
2sc1306 16w   30mhz fm/am/ssb to-220 b c e
2sc1307 16w 12db 12v 30mhz fm/am/ssb to-220 b c e
2sc1590 5w 10db 12,5v 136-174mhz fm to-220 b e c
2sc1591 14w 7,5db 12,5v 136-174mhz fm to-220 b e c
2sc1678 5w   30mhz wintransceiver to-220 b c e
2sc1728 8w   80mhz wintransceiver to-202 e b c
2sc1729 14w 10db 13,5v 175mhz fm t-31e
2sc1909 10w 14,5db 13,5v 50mhz fm/am/ssb to-220 b c e
2sc1944 13w 11,1db 12v 30mhz wintransceiver to-220 b c e
2sc1945 16w 14,5db 12v 30mhz fm/am/ssb to-220 b e c
2sc1946 25w 6,7db 13,5v 175mhz fm t-31e
2sc1946a 30w 10db 13,5v 175mhz fm t-31e
2sc1947 3w 10db 13,5v 175mhz fm to-39 c b e
2sc1957 1,8w 17db 12v 30mhz wintransceiver to-126 e c b
2sc1966 3w 7,8db 13,5v 470mhz fm t-31e
2sc1967 7w 6,7db 13,5v 470mhz fm t-31e
2sc1968 14w 3,7db 13,5v 470mhz fm t-31e
2sc1968a 14w 5,4db 13,5v 470mhz fm t-31e
2sc1969 18w 12db 12v 30mhz fm/am/ssb to-220 b c e
2sc1970 1,5w 10db 13,5v 175mhz wintransceiver to-220 b e c
2sc1971 7w 10db 13,5v 175mhz wintransceiver to-220 b e c
2sc1972 14w 10db 13,5v 175mhz wintransceiver to-220 b e c
2sc1973 1w   50mhz wintransceiver to-92l b c e
2sc1974 13w 10db 13,5v 30mhz wintransceiver to-220 b c e
2sc1975 4w 10db 13,5v 30mhz wintransceiver to-220 b c e
2sc2028 1,8w   30mhz wintransceiver to-126 e c b
2sc2029 6w   30mhz wintransceiver to-220 b c e
2sc2036a 1,4w     wintransceiver to-202 b c e
2sc2050 10w 12db 13,5v 30mhz fm/am/ssb to-220 b c e
2sc2053 0,2w 15,7db 12v 175mhz fm/am to-92l b c e
2sc2055 0,25w 15,3db 12v 175mhz fm/am to-92l b c e
2sc2056 1,5w 9db 12v 175mhz fm to-39 c b e
2sc2075 4w 13,5v 27mhz wintransceiver to-220 b c e
2sc2078 4w 13db 12v 100mhz fm/am to-220 b c e
2sc2086 0,45w 13db 12v 175mhz fm/am to-92l b c e
2sc2092 4w 13db 12v 100mhz fm/am/ssb to-220 b c e
2sc2094 15w 8,8db 13,5v 175mhz fm/am/ssb t-31e
2sc2166 6w 13,8db 12v 30mhz fm/am/ssb to-220 b c e
2sc2207 16w     wintransceiver to-220 b c e
2sc2237 6w 13,8db 13,5v 175mhz fm t-31e
2sc2312 18,5w   27mhz fm/am/ssb to-220 b c e
2sc2314 1,8w 17db 12v 180mhz fm/am to-126 e c b
2sc2509 13w 14db 30mhz wintransceiver to-220 b c e
2sc2527 60w     wintransceiver to-220
2sc2538 0,6w 10db 12v 175mhz fm/am to-92l b c e
2sc2539 14w 14,5db 13,5v 175mhz fm t-31e
2sc2660 30w   30mhz wintransceiver to-220
2sc2695 23w 1,9db 13,5v 520mhz fm t-31e
2sc3001 6w 13db 7,2v 175mhz fm t-31e
2sc3017 1w 11db 13,5v 175mhz fm to-39 c b e
2sc3018 3w 13db 7,2v 175mhz fm t-31e
2sc3020 3w 10db 12,5v 520mhz fm t-31e
2sc3021 7w 7,7db 12,5v 520mhz fm t-31e
2sc3022 18w 4,8db 12,5v 520mhz fm t-31e
2sc3103 2,8w 6,7db 7,2v 520mhz fm t-31e
2sc3104 6w 4,8db 7,2v 520mhz fm t-31e
2sc3133 13w 14db 12v 1,5-30mhz fm/am/ssb to-220 b e c
2sc3297 15w   100mhz wintransceiver to-220
2sc3299 20w     wintransceiver to-220
2sc3668 1w   100mhz wintransceiver
2sc3807 15w   260mhz wintransceiver to-126
2sc4137 4w   400mhz wintransceiver to-126
2sc4693       fm/am to-92l b c e
ktc1006 1w   100mhz fm/am to-92l e c b
ktc1969 16w 12db 12v 100mhz fm/am to-220 b c e
ktc2078 4w 11db 12v 100mhz fm/am to-220 b c e
mrf161 5w 13,5db 12,5v 225-500mhz fm/am to-220 b e c
mrf162 15w 13,5db 12,5v 225-500mhz fm/am to-220 b e c
mrf163 25w 12db 12,5v 225-500mhz fm/am to-220 b e c
mrf237 4w 12db 18v 175mhz wintransceiver to-39
mrf260 5w 10db 12,5v 136-174mhz fm to-220 b e c
mrf261 10w 5,2db 12,5v 136-174mhz fm to-220 b e c
mrf262 14w 7,5db 12,5v 136-174mhz fm to-220 b e c
mrf264 30w 5,2db 12,5v 136-174mhz wintransceiver to-220 b e c
mrf340 8w 13db 28v 70mhz wintransceiver to-220 b e c
mrf342 24w 11db 28v 70mhz wintransceiver to-220 b e c
mrf344 60w 6db 28v 70mhz wintransceiver to-220
mrf454 80w 12db 12,5v 1,5-30mhz fm/am/ssb
mrf455 60w 13db 12,5v 1,5-30mhz fm/am/ssb
mrf475 12w 10db 13,5v 1,5-30mhz fm/am/ssb to-220 b c e
mrf476 3w 15db 13,5v 1,5-30mhz fm/am/ssb to-220 b c e
mrf477 40w 15db 13,5v 1,5-30mhz fm/am/ssb to-220 b e c
mrf479 15w 10db 13,5v 1,5-30mhz fm/am/ssb to-220
mrf485 15w 10db 28v 1,5-30mhz wintransceiver to-220
mrf486 40w 15db 28v 1,5-30mhz wintransceiver to-220
mrf496 40w 15db 13,5v 1,5-30mhz wintransceiver to-220
mrf497 60w 10db 13,5v 27-50mhz wintransceiver to-220 b e c
mrf517 0,75w 10db 20v 1000mhz wintransceiver to-39
mrf607 1,75w 11,5db 16v 175mhz wintransceiver to-39
mrf660 7w 5,4db 12,5v 400-512mhz wintransceiver to-220
ms1226 30w 18db 28v 30mhz fm/am/ssb
ms1227 20w 15db 12,5v 30mhz fm/am/ssb
