  • 26140阅读
  • 66回复
放毒是什么感觉 [复制链接]
离线BG3LL
只看楼主 倒序阅读 0楼 发表于: 2007-12-03
m3tr
advanced hf/vhf tactical radio r&s mr3000h
the r&s mr3000h belongs to a new family of high-performance digital radios covering the hf and vhf/fm band in a single unit.
thanks to different high-speed data modes and protocols as well as different antijam modes for hf and vhf/fm, it perfectly integrates into tactical communication networks.
the radio is software-configurable and reprogrammable including pre planned product improvement (p³i).
all members of the r&s m3tr family are based on one mechanical platform, with a common logistic concept and one man machine interface (mmi).
features
◆ multiband capability (1.5 mhz to 512 mhz with external devices)
◆ multiwaveform capability
◆ high data rate up to 64 kbit/s for data and video
◆ software-configurable and upgradeable (p³i)
◆ selective links in one net
◆ low volume/weight
◆ power saving mode
◆ integrated gps and position report
◆ removable front panel for flexible use and integration
◆ user-friendly mmi
general specifications
frequency range
tx: 1.5 mhz to 108 mhz
rx: (100 khz), 1.5 mhz to 512 mhz
channel spacing
  hf
  vhf/fm
1 hz
6.25 khz, 8.33 khz, 12.5 khz, 25 khz
frequency stability
standard: ±0.5 ppm
presets
100 (10 available on rotary switch)
modulation
j3e (usb, lsb), a3e (am), h3e (ame), f1b/f1d (fsk), a1a (cw), f3e (fm)
operating modes
ssb/fm/am, frequency hopping (vhf/fm), frequency hopping (hf),
clear voice/data transmission (ff mode), secure voice/data transmission (fh mode, dff mode), test (bite), remote control, gps mode (time, position), erase
antenna tuning
  hf
  vhf
built-in, automatic, silent tuning
built-in matching filter
test (ibit)
module level; manually initiated bit continuous monitoring
hf transmitter specifications
  rf output power
  power reduction protection
  carrier suppression
  sideband suppression
  intermodulation products
  harmonic suppression
1 mw, 0.1 w, 0.2 w, 0.5 w, 1 w, 2 w, 5 w, 10 w, 20 w pep, fm average,am pep
high vswr, high temperature
>50 db below pep (j3e)
>50 db below pep
>36 db below pep
>40 db
hf receiver specifications
  sensitivity (1.5 mhz to 30 mhz)
  squelch
ssb: -117 dbm (0.3 µv) for 10 db (s+n)/n (2.4 khz bandwidth)
syllabic squelch, 150 hz tone squelch, signal squelch, rssi (relative signal strength indication)
vhf/fm transmitter specifications
  rf power output
  power reduction protectionhigh
  harmonics
  spurious emission
1 mw, 0.1 w, 0.2 w, 0.5 w, 1 w, 2w, 5 w, 10 w, fm average, am pep
-60 dbc
-70 dbc
vhf/fm receiver specifications
  sensitivity (30 mhz to 512 mhz)
fm: -113 dbm, 10 db sinad
power supply
  input voltage
14 v to 33 v dc
19 v to 33 v fully specified
fast data modes (optional)
  hf modes (ff)
  vhf mode (ff)
stanag 4285 waveform up to 3600 bit/s
stanag 4539 waveform up to 12800 bit/s
r & s proprietary waveform up to 64 kbit/s
automatic link establishment (optional for hf)
  specifications
mil-std-188-141b, app. a
voice processor (r&s secom only)
  vocoder bitrate
hf: 1200 bit/s
vhf: 4800 bit/s
epm (optional)
frequency hopping modes
  hf
  vhf/fm
  encryption
r & s secom-h
r & s secom-v
r & s secom embedded voice/data encryption
environmental conditions
temperature range (mil-std-810e methods 501.3 and 502.3)
  operational
  fully specified
  storage
  temperature shock
  shock
  vibration
  waterproofness
  sand and dust
  solar radiation
  icing and freezing rain
  salt fog
  low pressure (altitude)
  humidity
  fungus
  emi
  bench handling
-40°c to +70°c
-25°c to +55°c
-40°c to +85°c
to mil-std-810e method 503.3
to mil-std-810e method 516.4
to mil-std-810e method 514.4
1 m immersion during 2 hours,
to mil-std-810e method 512.3
to mil-std-810e method 510.3
to mil-std-810e method 505.3
to mil-std-810e method 521.1
to mil-std810e method 509 .3
to mil-std810e method 500.3, proc. i+ii
5000 m above sea level at <+35 °c
to mil-std810e method 507.3 (cycle5),
33 °c/63 °c, 75% rh, 15 days
to mil-std810e method 508.4
to mil-std-461
to mil-std810e method 516.4, proc.vi
dimensions (w x h x d)
199 mm x 74 mm x 309 mm
(with battery pack)
weight
<5.8 kg (with battery pack)
accessories (optional)
handset, headset, battery charger, loudspeaker with external 3 w audio amplifier
external control units, data terminals
data terminal (dt) for field use, fill gun, message handling pc software, mission planning pc software, remote control terminal, remote control software (installed on a pc) for remote control of the radio
antennas
hf whip antenna 2.4 m, vhf whip antenna 1.5 m, short rod antenna vhf, long wire antenna, dipole antenna for vhf and hf range, other antennas on request
external amplifiers
50 w vhf power amplifier, 50 w vhf/uhf power amplifier, 150 w hf power amplifier
the power amplifier r&s vk3150 increases the hf output power of the r&s mr3000 manpack radios to 150 w pep or 100 w average. the r&s vk3150 provides medium-power/medium-range communications links. typical applications include mobile or base station installations for general-purpose hf ssb voice and data communications.
continuous coverage is provided over the 1.5 mhz to 30 mhz frequency range. the power amplifier section is of broadband design and fully supports frequency-agile operation modes (automatic link establishment, slow frequency hopping).
when used with the automatic hf antenna tuning unit r&s fk3150, the output of the r&s vk3150 is automatically matched to most rod and whip antennas and requires no special operator procedures.
built-in self-test features permit operators or maintenance personnel to fully check the transceiver and associated power amplifier performance down to the module level. fault conditions are displayed on the transceiver's front-panel display.
the rf drive requirements for full 150 w pep or 100 w average are –2 dbm (±3 db) from the associated receiver- transmitter.
the manpack r&s mr3000 therefore acts as an exciter for the power amplifier, avoiding the disadvantages of transceiver/ booster solutions with respect to unwanted emissions.
the hf power amplifier is mounted separately on an independent shockmount with room for proper air flow. this provides additional flexibility when installing tactical radio systems into vehicles.
the r&s vk3150 uses rugged tactical packaging and meets the same environmental specifications for temperature, shock, vibration, and submersibility as the rest of the r&s m3tr family components.
external antenna tuning units
vehicular antenna tuning unit hf 150 w
docking stations
docking station for one or two radios, one or two 50 w vhf power amplifiers and a switchbox (dds)1) or auxbox (sds)2)
batteries
  li-ion (rechargeable) or liso2 (primary)
autonomy/capacity at +25 °c
  (ff-operation, duty cycle tx/rx/stdby = 18)
  li-ion   vhf (5 w, fm): 22 h, hf (10 w, ssb): 14 h
  liso2   vhf (5 w, fm): 28 h, hf (10 w, ssb): 18 h
1) double docking station.
2) single docking station.
&#44288;&#47144;&#51088;&#47308;
rohde & shwarz
m3tr_23.pdf
m3tr_bro.pdf
m3tr_mil.pdf
mr3000h.pdf
mr3000u.pdf
mr3000h_24.pdf
mr3000u_24.pdf
rs150t_de.pdf
rs150t_speci.pdf
113212cat.pdf
ek895ent.pdf
fk2020t.pdf
fk3150t.pdf
ga3001t.pdf
gm3001s.pdf
gn2100t.pdf
hv3004t.pdf
hv3015t.pdf
ib3001t.pdf
m3sr22t.pdf
n163t.pdf
secom.pdf
vk3150t.pdf
vt3050.pdf
xk2000t.pdf
小图 | 大图 图片
  • 哈罗CQ火腿社区 - 设备 - 放毒是什么感觉
离线BG3LL
只看该作者 1楼 发表于: 2007-12-03
离线BG3LL
只看该作者 2楼 发表于: 2007-12-03
########3
离线BD4VNG
只看该作者 3楼 发表于: 2007-12-03
剧           毒
离线huashao128
只看该作者 4楼 发表于: 2007-12-03
好东西。。。。。
离线电锯
只看该作者 5楼 发表于: 2007-12-03
太——毒——啦!
只看该作者 6楼 发表于: 2007-12-03
舒服         .
离线BG8DMY
只看该作者 7楼 发表于: 2007-12-03
剧毒....相当的剧毒.....
离线BG8CIH
只看该作者 8楼 发表于: 2007-12-03
买不到。。。。。。。。。。楼主出个套件吧。。。。。。
离线bd4jk
只看该作者 9楼 发表于: 2007-12-03
离线bg1iwk
只看该作者 10楼 发表于: 2007-12-03
这毒饱眼福,太棒了。多上点。
离线BG3LL
只看该作者 11楼 发表于: 2007-12-03
我要是能出这样的套件 ,那烽火的工程师就都得失业了.呵呵
不知道国内有没有设计出这样的物件
离线BG8AIQ
只看该作者 12楼 发表于: 2007-12-03
太漂亮了.
离线BA7EI
只看该作者 13楼 发表于: 2007-12-03
请问,以性能来论,在中国军方的通信设备生产厂家中,烽火排第几?
不知道国内有没有设计出这样的物件
能不能介绍一下烽火曾经生产过的符合中华人民共和国军标一级机的短波电台的型号?
只看该作者 14楼 发表于: 2007-12-03
离线BA7GM
只看该作者 15楼 发表于: 2007-12-03
漂亮!!!!漂亮
离线bd7idi
只看该作者 16楼 发表于: 2007-12-03
能告诉我烽火厂那堵围墙后面有没有养狼狗,或者告诉我厂外面哪个下水道可以进到仓库里边。。。。
让我进去瞧瞧有没有存货,搞两台出来耍一耍。。。。。
离线ba7ib
只看该作者 17楼 发表于: 2007-12-04
没事,非毒不侵了
离线key
只看该作者 18楼 发表于: 2007-12-04
德国的东西,呵呵。有没有与美国的产品两者对比后的数据?
离线BG3LL
只看该作者 19楼 发表于: 2007-12-04
还有一张 我中毒太深了做梦都见了
