  • 3899阅读
  • 16回复
看了这样的QRP成绩,真是让人又敬佩又惭愧! [复制链接]
离线BA4RF
只看楼主 倒序阅读 0楼 发表于: 2007-11-28
call           qsos zones cntry   hr     score club
non-usa soab qrp
6v7d(k1xm)     2227   95   318   41 2,702,672 yccc
这位老兄还出过一本书:dxing on the edge
离线BG1TTI
只看该作者 1楼 发表于: 2007-11-28
没看懂,老师能讲讲吗?
先谢了!
离线BA6QH/QRP
只看该作者 2楼 发表于: 2007-11-28
成绩肯定很好,但说实话,我一直也没能看懂那些数字代表的是何含意? 也请大佬讲解讲解如何?
离线BA7NQ
只看该作者 3楼 发表于: 2007-11-28
non-usa soab qrp
2227个qso,95个分区,318个国家字头,操作了41小时,总分2,702,672,yccc俱乐部的成员
离线BA5CW
只看该作者 4楼 发表于: 2007-11-28
call: 6v7d
operator(s): k1xm
station: 6w7rv
class: soab qrp
qth: senegal
operating time (hrs): 41
summary:
band qsos zones countries
160:   10   6     9
  80:   40   10     32
  40: 343   16     60
  20: 602   25     86
  15: 1113   25     90
  10: 119   13     41
total: 2227   95     318 total score = 2,702,672
club: yankee clipper contest club
comments:
station: elecraft k2, titanex vertical 160-40,
3 element monoband yagis 20-10. see http://www.le-calao.com
for details.
when i finish typing this i need to pack for the trip home.
i hate packing more than i hate writing so i'll ramble a bit.
maybe this wasn't the best year to try qrp. but i operated
low power last year and wanted to do something different. high
power wasn't an option and single-band means less chair time
so i decided to go after the african qrp record.
i really didn't know what to expect. i thought i'd run a bit
on the high bands and spend most of the contest s&p. this
turned out to be wrong.
s&p was much more difficult than i expected (and i should have
known better). the smart stations just called cq in my face.
the less smart stations would send a question mark, which began
a half-dozen transmissions while they worked through bv7d, sv7d,
uv7d, 647d, and a bunch of less common choices. eventually most
got it, some just gave up.
the titanex vertical with 5 watts was just not enough on 80 and
160, and even on 40 europe was difficult. i never worked the us
on 160 - i called kc1xx, w3lpl, k3lr, nq4i, k1lt, kt1v, vy2zm, and a
few others, but nobody heard me. on 80 i called just about every
european that called cq and most never heard me. on the other
hand kh6 on 80 was easy. on 40 i was able to get a run going
early in the contest but could not repeat it later.
20 was ok but the competition was tough. i think i had my best
hour there.
15 was the money band, with almost half of my qsos. i was
pleasantly surprised. last year 15 was noisy and i spent more
time on 20 and 10. this year 15 was quiet and productive.
10 was disappointing. last year with low power i had over 900
qsos there. this year it just didn't open well. i had one
run sunday.
thanks to everyone who heard my weak signal, and especially to
francois, 6w7rv for his help.
离线BA5DX
只看该作者 5楼 发表于: 2007-11-28
不知道他用什么天线
离线BA5CW
只看该作者 6楼 发表于: 2007-11-28
上面写了 titanex vertical 160-40,
离线ba7ib
只看该作者 7楼 发表于: 2007-11-29
只能写一个“服”字了
离线BA5CW
只看该作者 8楼 发表于: 2007-11-29
首先操作员肯定是牛人,但是地理位置使他相对容易获得高分,塞内加尔先不说稀有程度,从距离上到欧洲的距离比北京到ua9还近,到南美的位置相当于我们对南亚,到美国的位置相当于我们到欧洲,所以qrp比我们这里想象得要好一些,我还看见某个qrp的160m成绩比b1z的还要好,cqww的分数地域位置关系很大。
不同的地方给操作员得到的培养也不一样,欧洲附件的国家,比赛的时候电台似乎永远通不完,所以他们的qso速度上得到的锻炼就多,而我们by的要得到这样的锻炼,去iota是个捷径,但现在by连iota都烂了,只有玩低波段还能保持点稀有度。
离线ahhui
只看该作者 9楼 发表于: 2007-11-29
alc分析的有道理,不过这个成绩还是让人敬佩。
离线VR2KW
只看该作者 10楼 发表于: 2007-11-29
我建议,下次cqww到oc去,yb、9m6、du、v8、t88、h44、p29、kh0、kh2等等,根据cqww的规则,这些地方通ja台都是3分台。
看看你们自己的log,是不是有50%左右的as台,oc台5%左右,自己算一下,如果那50%的as台都是3分的话,总分会增加多少??
离线BA1RB
只看该作者 11楼 发表于: 2007-11-29
v8让4rf打通关系,他不肯。
离线BA4RF
只看该作者 12楼 发表于: 2007-11-29
v8让4rf打通关系,他不肯。
乱说,分工很清楚,你搞定签证,我负责执照,你的第一项工作还没完成呢!xixi
离线VR2KW
只看该作者 13楼 发表于: 2007-11-29
:d :d 我不需要搞签证,你什麽时候搞定执照啊??
离线VR2KW
只看该作者 14楼 发表于: 2007-11-29
v8让4rf打通关系,他不肯。
原来各位老大早已经有这个打算啦
离线VK3JUZ
只看该作者 15楼 发表于: 2007-11-29
        看了这样的qrp成绩,真是让人又敬佩又惭愧!
不是这样啊!中国的ham qrp 电台是不错的,在这里基本上每天都抄收得到,听他说用功率20w,我收到56-7,在7050上,应该敬佩啊才对!不是惭愧 啊!go 中国 ham !
离线BA4VE
只看该作者 16楼 发表于: 2007-11-29
20w还是qrp呀 呵呵而且 一般三级的ham都是报25w
