  • 9860阅读
  • 24回复
ICOM 7800 短波电台 [复制链接]
离线BG4ALI
只看楼主 倒序阅读 0楼 发表于: 2007-10-13
icom-ic-7800顶级hf/50功率200w大型台式短波机,自带电源及天调
小图 | 大图 图片
  • 哈罗CQ火腿社区 - 设备 - ICOM 7800 短波电台
离线BG4ALI
只看该作者 1楼 发表于: 2007-10-13
小图 | 大图 图片
离线BG4ALI
只看该作者 2楼 发表于: 2007-10-13
小图 | 大图 图片
离线BG4ALI
只看该作者 3楼 发表于: 2007-10-13
小图 | 大图 图片
离线BG4ALI
只看该作者 4楼 发表于: 2007-10-13
离线BG4ALI
只看该作者 5楼 发表于: 2007-10-13
后面第三楼大部分照片是手机拍的,大家见谅!
type: amateur hf/vhf transceiver
frequency range: tx: 10-160 m + warc / 6 m
rx: 0.03-60 mhz
mode: am/fm/ssb/cw/rtty/psk31
rf power output: 5-200 w (am: 5-50 w) 100% duty cycle!
sensitivity: ssb/cw/rtty (2.4 khz bw, 10 db s/n)
0.1-1.79 mhz: 0.5 uv
1.6-30 mhz: 0.16 uv
50-54 mhz: 0.13 uv
am (6 khz bw, 10 db s/n)
0.1-30 mhz: 2 uv
50-54 mhz: 1 uv
fm (15 khz bw, 12 db sinad)
28-30 mhz: 0.5 uv
50-54 mhz: 0.32 uv
selectivity: ssb/rtty (2.4 khz bw)
2.4 khz (-3 db), 3.6 khz (-60 db)
cw (500 hz bw)
500 hz (-3 db), 700 hz (-60 db)
am (6 khz bw)
6 khz (-3 db), 15 khz (-60 db)
fm (15 khz bw)
12 khz (-3 db), 20 khz (-60 db)
image rejection: better than 70 db
voltage: mains 85-265 vac
current drain: rx: max 210 va
tx: max 800 va
impedance: 50 ohms, 4*so-239
dimensions (w*h*d): 424*150*420 mm
weight: 25 kg
manufactured: 2003-200x
other: 4*32 bit dsp's. built-in rtty/psk31 encoder/decoder.
built-in auto-at. 7" color tft with vga output. twin rx
spectrum scope. digital voice recorder
rs-232c. built-in voice synthesizer
compact flash card for storing personal settings
+40 dbm ultra high intercept point.
new price 2004 in sweden: 92500:- sek
the icom 7800 is clearly one the most advanced amateur radio ever developed. it utilizes four separate 32-bit floating point dsp chips, has a 7-inch wide tft display, built in rtty/psk31 receive and transmit plus compact flash technology. as impressive as the features are; it is performance that sets this radio apart. by sparing no expense an incredible +40dbm intercept point has been achieved with ultra wide dynamic range. and you enjoy this incredible performance in two fully independent receiver circuits controlled on the left side of the radio. there is even a separate preamp and mixer for the 6 meter band. the rear panel features four primary antenna inputs [so-239] plus provisions for receive antenna a and b. and nothing is sacrificed on the transmit side. the newly designed push-pull mosfet amplifiers work with a 48 vdc, providing a powerful 200 watts of output at full duty cycle with low imd in all bands. a 120 vac switching power supply is built-in. the supplied accessories include: rack mounting ears, compact flash [64 mb] and various plugs (mic not supplied).
this new radio covers the hf ham bands plus 6 meters (receive from 30 khz - 60 mhz). the high resolution 7 inch tft color lcd display provides more operating information than you've ever had before, including a spectrum scope. and icom really stands behind this radio with a limited two year factory warranty.
important upgrade note: icom has produced an important upgrade for the ic-7800. they have added a 3 khz roofing filter. this upgraded model is what universal radio is currently shipping. ver. 2.0 will be displayed at the lower right corner of the display when the radio is first switched on during the boot up sequence if it has the 3khz roofing upgrade.
icom 7800是迄今为止最顶级的业余无线电台.他配备了四路独立的32位波动点dsp芯片,拥有7英寸宽的tft显示屏,包含了rtty/psk31两种数据收发模式以及cf卡储存技术(以便多用户使用配置).他那令人印象深刻的特点那样,他的表现将这台电台分离开来.他毫无保留的将一种难以置信的+40dbm的截点应用于极宽的动态范围.而你将会被他左侧那拥有难以置信表现的完全独立的双回路接受所深深吸引.在6米波,他甚至有独立的前置放大器混合器.后面板布局主要有四个主天线输入和两个用于接收的备用天线座a和b.新型推挽式晶体管功放由48v供电,是他具备了全波段上200w强劲的功率.120v的开关电源是内置的.
离线BG9HT
只看该作者 6楼 发表于: 2007-10-13
口水一地!
离线chengrc
只看该作者 7楼 发表于: 2007-10-14
原来到你这了!小心!锁好门呀!
离线bg8ah
只看该作者 8楼 发表于: 2007-10-14
不知又有多少人睡不好觉了。
离线ba7ib
只看该作者 9楼 发表于: 2007-10-14
毒药,超级毒药啊
离线BG3LL
只看该作者 10楼 发表于: 2007-10-14
这简直是病毒
离线BG9SZ
只看该作者 11楼 发表于: 2007-10-14
大胆问一句,多少钱?
离线咖啡泡泡
只看该作者 12楼 发表于: 2007-10-15
不错~~~~~~~~~~
离线bg5kh
只看该作者 13楼 发表于: 2007-10-15
大胆设想一下,中间的7寸屏如果能显示接收图象,以后发展就可以用八木短波互传图象,可视通联!
离线gning
只看该作者 14楼 发表于: 2007-10-15
就一个字,真美!
离线gning
只看该作者 15楼 发表于: 2007-10-15
北京和瑞通报价89000元/台(人民币),订货周期3个月。等咱有了钱,买两台,一台做qso,一台拆了当配件。 可惜没钱!
离线BG4IHT
只看该作者 16楼 发表于: 2007-10-15
bd3aaj两年前买的十万多
离线BG8CIH
只看该作者 17楼 发表于: 2007-10-15
hamradio报价10699美刀,依照现在的汇率,在8w以下比较合理。。。。。。。。
离线chengrc
只看该作者 18楼 发表于: 2007-10-15
等到了5w以下我一定买一台!真正的双接收!一边听(丰收锣鼓)!一边听(拖拉鸡)不错!
离线BH7IGW
只看该作者 19楼 发表于: 2007-11-01
真是口水流了一地啊
