  • 5263阅读
  • 7回复
今晚解的ISS信号 [复制链接]
离线bd8te
只看楼主 倒序阅读 0楼 发表于: 2007-09-24
硬件tm271a+kiss tnc
软件 ui3-view32
我是先录音后解码所以下面的时间过了5分多
解码内容
2327r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
welcome to rs0iss's message board
system ver 1.50 110448 bytes free
kiss on
restart
2331r rs0iss-11>hs1jan <rr c p r0>
2336r rs0iss-11>hs1jan <rr c p r0>
2338r rs0iss-11>hs1jan <ua r f>
2339r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2341r rs0iss-11>hs1jan <ua r f>
2342r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2344r rs0iss-11>hs1jan <ua r f>
2345r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2347r rs0iss-11>hs1jan <rr c p r0>
2350r rs0iss-11>hs1jan <rr c p r0>
2353r rs0iss-11>hs1jan <rr c p r0>
2356r rs0iss-11>hs1jan <ua r f>
2357r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2359r rs0iss-11>hs1jan <ua r f>
2300r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2302r rs0iss-11>hs1jan <ua r f>
2303r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2305r rs0iss-11>hs1jan <ua r f>
2306r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2308r rs0iss-11>hs1jan <rr c p r0>
2311r rs0iss-11>hs1jan <ua r f>
2312r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2314r rs0iss-11>hs1jan <ua r f>
2315r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
2317r rs0iss-11>hs1jan <rr c p r0>
2320r rs0iss-11>hs1jan <ua r f>
2322r rs0iss-11>hs1jan <rr c p r0>
2325r rs0iss-11>hs1jan <rr c p r0>
2327r rs0iss-11>hs1jan <ua r f>
23[s:49]28r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
23[s:49]30r rs0iss-11>hs1jan <ua r f>
23[s:49]31r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
23[s:49]33r rs0iss-11>hs1jan <rr c p r0>
23[s:49]36r rs0iss-11>hs1jan <rr c p r0>
23[s:49]39r rs0iss-11>hs1jan <rr c p r0>
23[s:49]41r rs0iss-11>hs1jan <ua r f>
23[s:49]42r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
23[s:49]45r rs0iss-11>hs1jan <ua r f>
23[s:49]46r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
23[s:49]48r rs0iss-11>hs1jan <rr c p r0>
23[s:49]51r rs0iss-11>hs1jan <rr c p r0>
23[s:49]54r rs0iss-11>hs1jan <ua r f>
23[s:49]55r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
23[s:49]57r rs0iss-11>hs1jan <rr c p r0>
23[s:49]58r rs0iss-4>cq,sgate <ui r len=51>:
>ariss - international space station (bbs/aprs on)
23[s:50]00r rs0iss-11>hs1jan <ua r f>
23[s:50]01r rs0iss-11>hs1jan <i c p s0 r0 len=68>:
23[s:50]02r rs0iss-11>hs1jan <i c p s1 r0 len=22>:
cmd(f/k/m/r/w/b/h/?)>
23[s:50]08r rs0iss-11>hs1jan <rr r f r1>
23[s:50]09r rs0iss-11>hs1jan <i c p s2 r1 len=57>:
msg# size   ts date   time from   to   @ bbs subject
23[s:50]12r rs0iss-11>hs1jan <rr c p r1>
23[s:50]14r rs0iss-11>hs1jan <i c p s2 r1 len=57>:
23[s:50]14r rs0iss-11>hs1jan <rr c p r1>
23[s:50]16r rs0iss-11>hs1jan <i c p s2 r1 len=57>:
23[s:50]18r rs0iss-11>hs1jan <rr c p r1>
23[s:50]21r rs0iss-11>hs1jan <rr c p r1>
23[s:50]24r rs0iss-11>hs1jan <rr c p r1>
23[s:50]27r rs0iss-11>hs1jan <rr c p r1>
23[s:50]30r rs0iss-11>hs1jan <rr c p r1>
23[s:50]33r rs0iss-11>hs1jan <disc c p>
23[s:50]36r rs0iss-11>hs1jan <disc c p>
23[s:50]39r rs0iss-11>hs1jan <disc c p>
23[s:50]42r rs0iss-11>hs1jan <disc c p>
23[s:50]45r rs0iss-11>hs1jan <disc c p>
23[s:50]48r rs0iss-11>hs1jan <disc c p>
23[s:50]51r rs0iss-11>hs1jan <disc c p>
23[s:50]54r rs0iss-4>cq,sgate <ui r len=57>:
23[s:50]54r rs0iss-11>hs1jan <dm r f>
23[s:51]53r rs0iss-4>cq,sgate <ui r len=51>:
离线xiaolei_200
只看该作者 1楼 发表于: 2007-09-25
有意思,呵呵,能解释一下吗??
离线bv2ac
只看该作者 2楼 发表于: 2007-09-25
iss 上附掛的是 kenwood tm-d700 車載機, 內藏數據通訊 tnc , 其中含有 pbbs...
以下是 d700 bbs 的相關操作指令,
cmd:*** connected to bv0mdu-1
welcome to bv0mdu's message board
system ver 1.50 112864 bytes free
h
commands
w(rite)   = type w (callsign)<cr> to begin message entering.
subject: = header(max 30 characters) are entered after the prompt: "subject:".
        ending the header with a carriage return <cr>.
message: = message are entered after the prompt: "message:".
        ending each line with <cr>.
        you terminate with either a <cr>/ex<cr> or <cr><ctrl-z><cr>
        to the indicate end of your message.
b(ye)   = type b<cr> to disconnect.
f(ile)   = type f<cr> to show the latest 20 messages.
l(ist)   = type l<cr> to show the all messages.
m(ine)   = type m<cr> to show latest 20 messages (to or from you).
        subsequent f or m command will show next 20 active messages.
r(ead)   = type r n<cr> to show the number n message.
a(bort)   = type a<cr> to abort.
j       = type j<cr> to show connect stations.
k(ill)   = type k n<cr> to delete the number n message (only to or from you).
h(elp)or ?= type h<cr> or ?<cr> to display this.
s all
w all
subject:
test from bv0jfs..
message:
hi: this is bv0jfs with/bq001,bq002, it's find signal to bv0mdu, no good
to bv0chu...
/ex
thank you for your message.
b
thank you cu agn 73
*** disconnected
bv0mdu>cq:hello bq003 de bv0mdu
bv0chu>cq,relay:1234567890
cmd:c bv0chu-1
cmd:d
*** retry count exceeded
*** disconnected
cmd:c bv0chu v bv0mdu
cmd:*** connected to bv0chu via bv0mdu
cmd:d
cmd:c bv0chu-1 v bv0mdu
*** disconnected
cmd:*** connected to bv0chu-1 via bv0mdu
welcome to bv0chu's message board
system ver 1.50 112668 bytes free
b
thank you cu agn 73
*** disconnected
离线BD7PA
只看该作者 3楼 发表于: 2007-09-25
高技术含量的业余无线电设备真的很好玩, 支持支持!!
下一步,也想设置一个属于自己的 bd7pa's message board。
离线BG4REB
只看该作者 4楼 发表于: 2007-09-25
刚才过顶试着用mixw解码出的两段
rs0iss-4/sgate>cq>ui,r,f0:
离线bd4rs
只看该作者 5楼 发表于: 2007-09-26
早5:00- 5:06 收到3次packet的信号,5:04仰角5度时,仍打开机器的静噪。声音十分清晰。
奇怪的是在5:06分iss从我的计算机显示已落入地平线以下仍收到一声packet。也许是我计算机时间和轨道的误差吧。
还没将信号接入计算机,有时间的时候,再把以前的软件翻出来译译码吧。上一次是很久以前的事了。
离线cqrbd
只看该作者 6楼 发表于: 2007-10-07
感谢ba4rs的提前预报.我用吸盘天线加th25a也听到了宇航员的呼叫.确实如大家所说,好象开始时,天上收不到地上的信号,通联没有南京的这次顺利.
离线RAIN BD1ND
只看该作者 7楼 发表于: 2007-12-26
谁知道那里可以搞到 ax25的 tnc啊
