  • 9037阅读
  • 25回复
关于CW速度的问题 [复制链接]
离线BG4CHL
只看楼主 倒序阅读 0楼 发表于: 2007-08-29
部队使用的100码相当于现在的paris制多少wpm?
离线BA7JS
只看该作者 1楼 发表于: 2007-08-29
长码还是短码?长码的话应该等于20wpm。短码应该更快一些,估计在25以上了。
离线BA4II
只看该作者 2楼 发表于: 2007-08-29
部队训练时一般使用数字短码平均报底,每十组只出现0至9的数码各4个,这样计算速度非常标准。
每分钟100码就是每分钟25组报文,120码时是30组报文,140码时是35组报文。
英文字母组成的报文,是单词为组,每个30组的报文可能速度都不一样!
离线BG9TF
只看该作者 3楼 发表于: 2007-08-29
you yi si a!
离线BG7RMD
只看该作者 4楼 发表于: 2007-08-29
180码等于多少wpm?
离线BA7JS
只看该作者 5楼 发表于: 2007-08-29
三种方法测量wpm(words per minute),分别为: paris/codex/vvvvv
wpm calculations.
paris
     total morse speed is dependant upon the character speed, inter-character delay and inter-word delay, to the paris test formula. this formula is based on the number of times the word "paris" can be transmitted as morse code in 1 minute. the variation of any one component will affect the resulting wpm (words per minute) rate.
codex
     total morse speed is dependant upon the character speed, inter-character delay and inter-word delay, to the codex test formula. this formula is based on the number of times the word "codex" can be transmitted as morse code in 1 minute. the variation of any one component will affect the resulting wpm (words per minute) rate.
vvvvv
     total morse speed is dependant upon the character speed, inter-character delay and inter-word delay, to the vvvvv test formula. this formula is based on the number of times the word "vvvvv" can be transmitted as morse code in 1 minute. the variation of any one component will affect the resulting wpm (words per minute) rate.
mrx software
morse码的时间间隔,俺简单归纳为:1:3:3:7
即嘀(dit)为1时间单位
哒(dah)为3时间单位
一个字母中嘀或哒(统称为element,元素)的间隔为1时间单位,相当于1嘀
一个单词中字母与字母的间隔为3时间单位,相当于1哒
单词与单词的间隔为7时间单位
此乃标准morse电码,手键可以随心所欲一些,不必拘泥。这也正是手键的个人风格与魅力所在。当然也不能偏差太远,否则不容易分辨。俺就听过有些手键高手发的码,全粘在一块了 发的人心里当然忒清楚,听的人就受苦了,这时就要连蒙带猜了!
morse code timing
     the following time values are used in the formation of morse symbols:
dit:                              1 time unit.
     dah:                              3 time units.
     space between elements of a symbol:      1 time unit.
     space between symbols:            3 time units.
     space between words:                  7 time units.
mrx software: www.mrx.com.au
以下为paris方法的时间数据,只列出25以下的速度。单位是毫秒。
morse speed data (paris).
     the following table displays morse component values used to obtain morse speeds, paris test, at differing symbol speeds. each block contains morse speed settings to obtain the bolded heading speed. for example if you wanted morse sounded at a total speed of 5 words per minute, using 12 word per minute symbols: set the symbol speed to 12 wpm, the inter-character delay to 1404 milliseconds and the inter-word delay to 3284 milliseconds.
码速(wpm)         /       字母间的间隔         /         单词间的间隔
symbol speed      /      inter-character delay      /      inter-word delay
________________________________________________________
5 wpm
      5                   720                        1680
      6                   915                        2140
      7                  1059                        2463
      8                  1161                        2706
      9                  1245                        2897
     10                  1308                        3048
     11                  1362                        3173
     12                  1404                        3284
     13                  1443                        3376
     14                  1473                        3442
     15                  1503                        3508
     16                  1527                        3567
     17                  1548                        3607
18                  1566                        3659
     19                  1587                        3699
     20                  1602                        3732
symbol speed            inter-character delay            inter-word delay
___________________________________________________________
6 wpm
      6                   600                        1400
      7                   741                        1735
      8                   846                        1966
      9                   927                        2169
     10                   993                        2308
     11                  1044                        2445
     12                  1089                        2544
     13                  1128                        2636
     14                  1158                        2702
     15                  1188                        2768
     16                  1212                        2827
     17                  1230                        2879
18                  1251                        2919
     19                  1272                        2959
     20                  1284                        3004
7 wpm
      7                   516                        1207
      8                   618                        1450
      9                   702                        1641
     10                   765                        1792
     11                   819                        1917
     12                   864                        2015
     13                   903                        2108
     14                   933                        2173
     15                   963                        2239
     16                   987                        2298
     17                  1005                        2351
18                  1026                        2390
     19                  1044                        2443
     20                  1059                        2476
8 wpm
      8                   450                        1050
      9                   534                        1241
     10                   597                        1392
     11                   651                        1517
     12                   696                        1616
     13                   735                        1708
     14                   762                        1786
     15                   792                        1852
     16                   816                        1911
     17                   837                        1951
     18                   855                        2003
19                   876                        2043
     20                   891                        2076
9 wpm
      9                   402                         935
     10                   465                        1086
     11                   519                        1211
     12                   564                        1310
     13                   603                        1402
     14                   633                        1468
     15                   660                        1546
     16                   687                        1593
     17                   705                        1645
     18                   726                        1685
     19                   744                        1737
     20                   759                        1770
10 wpm
     10                   360                         840
     11                   414                         965
     12                   459                        1064
     13                   498                        1156
     14                   525                        1234
     15                   555                        1300
     16                   579                        1359
     17                   600                        1399
     18                   618                        1451
     19                   639                        1491
     20                   654                        1524
11 wpm
11                   327                         767
     12                   372                         866
     13                   411                         958
     14                   441                        1024
     15                   471                        1090
     16                   495                        1149
     17                   513                        1201
     18                   534                        1241
     19                   552                        1293
     20                   567                        1326
12 wpm
     12                   300                         700
     13                   339                         792
     14                   369                         858
     15                   399                         924
16                   423                         983
     17                   441                        1023
     18                   462                        1075
     19                   480                        1127
     20                   495                        1160
13 wpm
     13                   279                         647
     14                   309                         713
     15                   336                         792
     16                   363                         838
     17                   381                         891
     18                   402                         930
     19                   420                         983
     20                   435                        1016
14 wpm
     14                   255                         599
     15                   285                         665
     16                   309                         724
     17                   330                         764
     18                   348                         816
     19                   369                         856
     20                   384                         889
15 wpm
     15                   240                         560
     16                   264                         619
     17                   285                         659
     18                   303                         711
     19                   324                         751
     20                   339                         784
16 wpm
     16                   225                         525
     17                   246                         565
     18                   264                         617
     19                   285                         657
     20                   297                         702
17 wpm
     17                   210                         488
     18                   288                         541
     19                   249                         580
     20                   264                         613
18 wpm
     18                   198                         465
     19                   219                         504
     20                   234                         537
19 wpm
     19                   189                         448
     20                   204                         481
20 wpm
     20                   180                         420
21 wpm
     21                   171                         407
22 wpm
     22                   162                         374
23 wpm
     23                   156                         372
24 wpm
     24                   150                         350
25 wpm
     25                   144                         336
mrx software
简单地说,wpm即一分钟发送或接受多少个词(word,平均为5个字母一个词)。
据统计,一般人正常说话的速度为120wpm,而即使是cw高手,最快也不过40wpm左右(个别疯子除外 :d ),可见cw是一种多么“缓慢”的语言!
离线BA7JS
只看该作者 6楼 发表于: 2007-08-29
180码等于多少wpm?
俺一般这样计算:除以5, 即36wpm。
除了wpm,还有一个计量单位叫做cpm, characters per minute
我猜cpm比较接近大伙常说的“码”。
离线ahhui
只看该作者 7楼 发表于: 2007-08-29
我猜cpm比较接近大伙常说的“码”。
也是lpm吧? letters per minute?
离线BG7RMD
只看该作者 8楼 发表于: 2007-08-29
我猜cpm比较接近大伙常说的“码”。
喔,谢谢指点。
现在用cvc的自动键,用最高速度180码发,感觉太快了,经常发错。
离线BG1PDP
只看该作者 9楼 发表于: 2007-08-29
探讨这个问题一定要有个前提。
以字码为例,以koch软件为标准。我是这样计算:
每分钟实际字符数=wpmx3.9
wpm=100/3.9=25wpm
因为统计每分钟实际字符数一定要扣除组之间的空格。
离线BA7JS
只看该作者 10楼 发表于: 2007-08-29
[quote=行者8989]探讨这个问题一定要有个前提。
每分钟实际字符数=wpmx3.9
wpm=100/3.9=25wpm
因为统计每分钟实际字符数一定要扣除组之间的空格。[/quote]
呵呵,俺的观点正好相反:组之间的空格是morse有机的组成部分,就是比例为7个时间单位的那部分,不可或缺。
对于业余通联使用的英语明语(包括q简语和缩写)来说,计算公式应为:
字符数(码数)=wpmx5
wpm=字符数/5
专业的纯数字报,尤其是短码,是一种特例。
离线BA7JS
只看该作者 11楼 发表于: 2007-08-29
是一回事!
俺个人认为characters较为贴切,包括了letters, numbers, and punctuations, and so on...
180马?!离疯子也就不远了!!!
离线lwt
只看该作者 12楼 发表于: 2007-08-29
9号调幅波????? 什么原理?
离线BG1PDP
只看该作者 13楼 发表于: 2007-08-29
字符数(码数)=wpmx5
wpm=字符数/5
报文中组之间的空格是不可缺少的。但其毕竟不是有效字符,所以统计时就不算数了。上世纪60年代的收发报竞赛活动当时就是这样规定的。所以说来说去,这就是一个规定而已。要算就都算,要不算就都不算。如果不搞竞赛也就无所谓了。
离线BA7JS
只看该作者 14楼 发表于: 2007-08-29
很有意思的规定!
但就计算收发报的速度而言,不算是不行滴,它毕竟占用了相当的时间。计算成绩当然可以不算,或者都算! 出来的名次都是一样滴!
离线BA4VE
只看该作者 15楼 发表于: 2007-08-29
拥koch的40wpm抄报确实有点难 关键是击键速度跟不上
离线BG1PDP
只看该作者 16楼 发表于: 2007-08-29
很有意思的规定!
但就计算收发报的速度而言,不算是不行滴,它毕竟占用了相当的时间。计算成绩当然可以不算,或者都算! 出来的名次都是一样滴![表情]
是的,由于间隔不算,所以在专业报务员考试手键发报,也有人为了提点速度就有意缩小大间隔。考官会给个评语:大间隔小。
离线BG1PDP
只看该作者 17楼 发表于: 2007-08-29
我的感觉是,脑子反映速度跟不上了,就是力不从心。
我认为,比赛抄报速度的黄金年龄是15-20岁。
离线BG4DVK
只看该作者 18楼 发表于: 2007-08-30
刚才去mr的成绩榜看了一下,昨天出了个第一名,真不能想像一个小时怎么可以做414个qso,平均下来6.9qso/min
汗。。。。。。
# call points mult score date
1 it9ryh 414 252 104328 2007-08-29
离线BA7JS
只看该作者 19楼 发表于: 2007-08-30
汗。。。。。。
疯子!疯子! :d
