  • 4539阅读
  • 11回复
业余无线电气球将发射 [复制链接]
离线bd4rs
只看楼主 倒序阅读 0楼 发表于: 2007-07-22
simsat balloon to launch next week
a high-altitude balloon carrying amateur radio is being prepared for launch july 24 and 25 that will offer hams and students in maryland, washington dc and a 20 state region a special opportunity to participate in the operations.
"balloon launches are being offered as part of a two-week science camp called reach for the stars! at the university of maryland eastern shore," said pat kilroy, n8pk, a long time space and near-space experimenter and engineer at the nasa goddard space flight center in greenbelt, maryland. "within minutes of release from umes, the balloon's radio footprint will grow to cover all of maryland, virginia, delaware and many adjoining states. at its peak of about 100,000 feet, the signals from the balloon will be heard by all within a 400 mile radius, reaching northward to maine, westward out to detroit and cincinnati, and south to savannah."
the first flight on the morning of tuesday, july 24, is a practice flight. an automatic packet reporting system (aprs) module will be flown along with a student-built "cricketsat" module. the cricketsat, conceived by bob twiggs, ke6qmd, is comprised of a small temperature sensing circuit connected to a tiny transmitter whose output audio tone frequency is proportional to the outside air temperature at altitude. the software used by participants to measure the tone frequency is digipan. "when you measure the frequency of the tone and record the time of day, then you can compare your figures to those on a look up table from the web page to reveal both the air temperature around the balloon and its altitude at that particular time, respectively," kilroy said.
the second flight will take place on the morning of the following day. designated "simsat-3b," it will carry a corner reflector experiment and possibly a cross-band repeater in addition to another aprs module and cricketsat.
the balloon's primary vhf frequency will be 144.390 mhz fm downlink aprs and on http://www.findu.com/. the hf net frequency is 3860 khz ssb, plus or minus other traffic. the vhf net frequency is wa3row/r salisbury on 146.820 mhz fm; this repeater employs a 156.7 hz pl tone for access.
amateur radio operators are invited to participate. a list of tasks that hams can do either on their own or in groups, as well as additional mission details, is on kilroy's web page.
http://www.arrl.org/news/stories/2007/07/19/100/?nc=1
离线BA5RW
只看该作者 1楼 发表于: 2007-07-22
我们只想没人做。
离线bv2ac
只看该作者 2楼 发表于: 2007-07-22
ba1fb 火腿生平最大的心願就是作 avr 汽球信標了..
http://www.qsl.net/ba1fb/
昨天去買了二顆 at90s2313 +書, 正式跟隨 1fb 的腳步..
离线bv2ac
只看该作者 3楼 发表于: 2007-07-23
bv4di 的翻譯...
bv4di 發表時間: 2007/7/23 0:56
版主
註冊日: 2003/10/14
來自:
發表數: 837 simsat高空氣球升空
在美國經常的以教育實驗為目的,進行高空氣球業餘無線電通訊實驗,,這個高空氣球將於7月24日25日升空,提供馬理蘭、華盛頓dc以及20州區域裡的業餘無線電人員以及學生一個特殊的機會參與。
這個高空氣球是在馬里蘭東岸大學裡所舉行的一個科學營隊的活動,這個活動稱之為到達星際reach for the stars!
這個氣球最高可達100000英尺,通訊涵蓋面積達400英里半徑的範圍。
第一次的飛行將在7月24日星期二早上,內含一個自動封包報導系統automatic packet reporting system (aprs),同時伴隨著學生所製的cricketsat,cricketsat的構想是由bob twiggs, ke6qmd所提出,內涵小型的溫度探測器以及小的發射機,而他的輸出音調頻率正比於環境的溫度。
第二次升空就在隔天早上,指定為simsat-3b,這個會攜帶著一個角型的反射體實驗,以及可能的跨頻段中繼以及另外一個aprs模組以及cricketsat。
版主說明:
在美國nasa經常資助這類行活動,用以培養太空科技人造衛星科技人才,對於學生而言這是一種便宜又方便的實驗管道。
而在此聲明一下,若是您有興趣於這種實驗,同時計畫要進行這種實驗,不要忘了高空氣球其實對飛航安全亦是有影響,所以釋放之前,風向氣流的掌握以及認識航道的所在是必須的,另外亦要查一下是否有相關的法律規定,並提出相關的申請,以保障您以及所有人員的安全。
de bv4di http://www.ham.com.tw/index.html
email: bv4di<at>ms2.hinet.net 註<at>就是@
email主旨請加keyword "ham" 或"ctarl"
离线bh7iav
只看该作者 4楼 发表于: 2007-07-24
bv4di 的翻譯...
版主
註冊日: 2003/10/14
來自:
版主說明:
使用的蘋率?
离线alex911
只看该作者 5楼 发表于: 2007-07-24
没图片吗?
离线BA7EI
只看该作者 6楼 发表于: 2007-07-24
佩服啊!不知什么时候中国火腿有这方面的动作
要想让高空氣球對飛航安全的影響到最小,需要让氣球飞到平流层,至少在20000米以上高空,而且要做到雷达隐形,以免被空军击毁。气球本体、太阳能加蓄电池供电系统、飞行高度控制系统、氢气制备及平衡系统、各种不同类型传感器、中继台(至少两套)、当系统降低到13000米高空时的自毁爆炸系统(炸碎仪器吊仓,点燃飞艇)等,先不说这个最多能支持一个月的一次性系统的代价,其研发技术小组所需要涉及的各方面技术都是前沿科技!
附件: 平流层气球载通信系统.pdf (0 K) 下载次数:133
离线bg2rah
只看该作者 7楼 发表于: 2007-07-24
我们马上就要放卫星喽.
离线bd4rs
只看该作者 8楼 发表于: 2007-07-25
我这考虑,现在有些玩热气球和滑翔伞甚至轻型飞机的ham,在上面装个aprs发信装置,即当了信标,地面ham又可监视到整个飞行的路径,而且覆盖的范围很广。
离线bd4rs
只看该作者 9楼 发表于: 2007-07-25
使用的蘋率?
离线bg8by
只看该作者 10楼 发表于: 2007-07-25
低温怎么解决
离线BA7EI
只看该作者 11楼 发表于: 2007-07-26
低温怎么解决
如果要实用,还有一个大问题__如何让这个庞然大物一直"悬停"在某个地方啊!
