  • 8419阅读
  • 29回复
想要1台25W左右的小巧的短波全段机器,为什么就找不到? [复制链接]
离线bg8cq
只看楼主 倒序阅读 0楼 发表于: 2007-07-06
野外通联,应急通讯等都需要适合在野外使用的机器
小鬼子有817够小巧,可只有5w。703也只有10w。857(857如果做到25w估计就符合要求了)外观凹凸太多不如897好看,可897不够小巧。
满世界找不到小巧的机器(前提价格0-6000),郁闷啊.....
离线BG4XCR
只看该作者 1楼 发表于: 2007-07-06
hf-90
不过价格不菲,但也在可接受范围内
离线BG4XCR
只看该作者 2楼 发表于: 2007-07-06
离线秋枫
只看该作者 3楼 发表于: 2007-07-06
prc-174
离线chinasoldier
只看该作者 4楼 发表于: 2007-07-06
这两个都不错吧~~
离线BD2OB/7
只看该作者 5楼 发表于: 2007-07-06
Vertex VX-1210
frequency range: rx: 0.5 - 30 mhz
                tx: 1.6 - 30 mhz
number of channels: 500 channels
emission type: a1a(cw), j3e(lsb/usb), h3e(am), f1b(afsk)
channel spacing: 10hz
antenna impedance: 50 ohms (unbalanced)
temperature range: —22 f to +140 f (-30c to +60c)
frequency stability: ±1.0 ppm
display type: liquid-crystal (lcd), with illumination
key controls: 3 knobs, power switch, 3 programmable keys
power_requirements: dc 14.4 v lithium-ion battery
recharge time: 5 hours (typical)
current consumption: rx: 500 ma (saver off), 100 ma (saver on)
tx: 5a(20 w), 3a(5w)
case size (w/o knobs): 7.6(w) x 2.9(h) x 10.8(d) (193 x 74 x 274 mm)
weight (approx.): 7.1lbs. (3.2 kg) w/fnb-66ll lithium-ion battery
transmitter
power_output 20w/sw (j3e/a1a/f1 b), 10 w/2.5 w (h3e)
duty cycle 25 % voice
modulation type balanced modulator (ssb:j3e)
early stage/low level (am:h3e)
spurious emission -56db or better
carrier suppression 55db
undesired sideband suppression 55db@ 1.5 khztone
audio response (j3e) 350 2650 hz (-6 db)
3rd-order md -31db
microphone impedance 2 k ohms, condenser type
receiver
circuit type double conversion superheterodyne
intermediate frequency 47.055 mhz & 10.7 mhz
sensitivity 0.25 ~iv (j3e/a1a, 10 db s/n)
selectivity 2.4 khz/5.0 khz (—6 /—60 db)
if rejection 80 db
image rejection 80 db
clarifier adjustment range ±200 hz (j3e/a1 a/fl b), ±400 hz (h3e)
audio output at least 1.5 w into 4 ohms @ 10% thd
audio impedance 4 - 32 ohms
http://www.vertexstandard.com/indexvs.cfm?cmd=displayproducts&prodcatid=71&encprodid=173db78f4b4d5eb0b93fe40efa495610&divisionid=64&isarchived=0
http://www.yaesu.co.uk/vertex/export/vx1210/vx1210.htm
http://www.eham.net/reviews/detail/4822
http://www.youtube.com/results?search_query=vr2%2fkq6xa&search=search
离线BG1ESX
只看该作者 6楼 发表于: 2007-07-06
要找一个十全十美的机器是不容易啊!
离线ba7ib
只看该作者 7楼 发表于: 2007-07-06
买个二手的706mkii,把功率调到25w来用,完全满足要求!
离线bg7idf
只看该作者 8楼 发表于: 2007-07-06
trk-90 可以满足,不过没有新机了,功率35w
离线BD2QAA
只看该作者 9楼 发表于: 2007-07-06
老兄hf-90都被你折腾了,你还想弄什么呀
离线vr2cia
只看该作者 10楼 发表于: 2007-07-06
自己做一部吧.保证百分百满意.
离线bg8cq
只看该作者 11楼 发表于: 2007-07-06
这两个都不错吧~~
小兵啊,你老是发帖馋我,把你左边那个机机让给我吧
174太重不好
离线bg8cq
只看该作者 12楼 发表于: 2007-07-06
[quote=bd2ob/7]frequency range: rx: 0.5 - 30 mhz
                tx: 1.6 - 30 mhz
[/quote]
看上去像好机,加电池才6.4斤,不知要多少钱。
离线bg8cq
只看该作者 13楼 发表于: 2007-07-06
买个二手的706mkii,把功率调到25w来用,完全满足要求![表情]
这个方案是想过的,可是象我们这些业余使用的懒虫,重量很重要,如果706变成25w,那么散热器之类的也要从100w变成25w才是最佳,因为100w散热器比25w的要重、大很多,会比较不方便。
离线bg8cq
只看该作者 14楼 发表于: 2007-07-06
[quote=毕即兔]老兄hf-90都被你折腾了,你还想弄什么呀 [/quote]
hf90信道的,好用不好玩。
其实说白了,就是看中817的体积和重量,但实在接受不了5w的功率
这挨千刀的小鬼子,怎么就不做到25w呢,散热片稍微大一点不就行了吗
离线bg8cq
只看该作者 15楼 发表于: 2007-07-06
自己做一部吧.保证百分百满意. [表情] [表情] [表情]
没能力啊
离线BD2OB/7
只看该作者 16楼 发表于: 2007-07-06
hf90信道的,好用不好玩。
您的要求太苛刻了。
vx-1210也是信道的。www.hamradio.com 价格1799.95美元,还没有库存。它还没有内置天调。
http://www.twowayaccessories.com/vertex-standard-20w-hf-manpack-transceiver/hf-radio/yaesu-vertex--standard/product/code/vx-1210/
这里价格1095欧元。
我觉得移动使用时有天调还是很方便的。为什么非要25w?如果功率放宽要求ic-703就很合适了。10w在14mhz以上频率通联邻国还是很容易的。
离线BG4XCR
只看该作者 17楼 发表于: 2007-07-06
离线bg4kc
只看该作者 18楼 发表于: 2007-07-07
25w的ssb新机器,会有大散热片,不轻便。ft-80c就够轻,好像个空壳子。
离线bg8cq
只看该作者 19楼 发表于: 2007-07-10
[quote=bd2ob/7]您的要求太苛刻了。
这里价格1095欧元。
我觉得移动使用时有天调还是很方便的。为什么非要25w?如果功率放宽要求ic-703就很合适了。10w在14mhz以上频率通联邻国还是很容易的。[/quote]
是的,天调是我的标配,我有很小巧的cg100
为什么是25w,我大概的理由是:
1.在野外能保证实际辐射出去10w时效果是很不错的,天调损耗(30%)+馈线损耗(10%)+天线损耗(20%),这些损耗在野外情况下往往损耗是较大的,要达到前面的要求,设备输出需在25w(15-30w)左右。
2.在野外往往是听得见,而喊不出去,如果天线不变,高度不变时功率越大越好,可功率大了,供电的重量就是个问题,供25w的电池重量不会太大。
3.给这套25w的设备配上太阳能电池很容易实现,重量也不会太重。天线+机器+天条+电池+太阳能供电完全可以1个人背负,实现全天候使用。
4.不是理由的理由,经常在频率上听到很多友台用20-30瓦通联效果非常不错,而天线多是倒v、斜拉等简单天线,说明在野外20-30w用简单天线也有可能出很好的效果。
应急通讯和灾害时可随时使用,当然平时更可以随着兴致任何时间抓起来拿出去就可以使用,通联机率还比较高。
在家用功放,我觉得就比较完美了
