  • 5258阅读
  • 1回复
THROB et THROBX [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2007-07-04
throb and throbx are experimental multi-tone frequency shift keyed (mfsk) modes, good for low power transmission without being sensible to doppler as are psk transmissions. the use of raised cosine shaped tones pulses applied to each character gives a characteristic "throbbing" sound, hence the name of the modes. throbx is an improved throb mode but only for speeds of 1 and 2 bauds. the minimum signal-to-noise ratio is about - 18.5 db for throbx at 1 baud.
  this mode is included into the software multipsk by patrick f6cte, there is the description of this mode and its variants as well as the specifications coming from his software :
created by : lionel sear g3ppt, in 2000 for throb and 2003 for throbx
preliminary   : throbx is an evolution of throb.
description :
baud rate   : 1, 2 or 4 (1 or 2 in throbx)
speed   : 10, 20 or 40 wpm (=10 x baud rate) or 60, 120 or 240 characters/min (=60 x baud rate) (10 or 20 wpm in throbx)
modulation : - for throb: fsk 9 tones with 1 or 2 tones send in the same time (which give 45 possibilities including the idle tone)
            - for throbx: fsk 11 tones with 2 tones send at the same time (which give 55 possibilities including the 2 possible idle characters)
reception mode: only one side (usb or lsb), usb is recommended
character set : for throb: 46 &#171; fixed length &#187; characters: a..z 0..9 , . ’ / ( ) ? @ = <space> (with use of a &#171; shift &#187; character for ?@=). no error reset character.
  : for throbx: 53 characters: a..z 0..9 , . ’ / ( ) ? @ = # " + - ; : ! <space> . no error reset character.
shape of pulse   : for the 1 or 2 bauds modes: rectangular at the center with leading and trailing quarters as raised cosine. for the 4 bauds mode (throb only): raised cosine
space between tones : for throb: 8 hz (1 or 2 bauds) or 16 hz (4 bauds), for throb: 7.8125 hz ,
bandwidth : for throb: 72 hz (1 or 2 bauds), 144 hz (4 bauds), for throbx: 94 hz
demodulation : non-coherent,
synchronization : automatic on incoming &#171; throbs &#187;
correction code : no
convolution code : no
interleaving : no
automatic frequency correction : +/- 3 hz,
drift tolerance : 4 bauds: 40 hz/mn max, 2 bauds: 20 hz/mn max, 1 baud: 10 hz/mn max according to signal-to-noise ratio,
pmean/ppeak : 0.35 for 1 and 2 bauds modes, 0.19 for 4 bauds
lowest s/n : throbx: -18,5 db for the 1 baud, -17.5 db for the 2 bauds
                    throb: -16 db for the 1 baud, -14.5 db for the 2 bauds et -12 db for the 4 bauds
recommanded frequencies for throb, throbx (usb)
valid also for domino, mfsk16, mfsk8.
1838, 3580, 7037, 10147, 14080, 18105, 21080, 24929, 28080 khz
the throbx, mfsk8, dominof and dominoex modes are qrp transmissions. they are very little used. patrick f6cte proposes to focus calls in the same conditions as for psk10, pskfec31, psk63f, pskam10/31/50 :
*   14075 khz usb (af around 1000 hz) at 17h00 utc,
*   10148 khz usb (af around 1000 hz) at 22h00 utc.
      * 144620 khz usb (af around 1000 hz) at 20h00 utc.
离线BD2ALB
只看该作者 1楼 发表于: 2009-11-08
各种微功率通信模式真多,,,
