  • 3811阅读
  • 2回复
新机介绍:Kenwood TH-255A [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2007-05-23
type:      amateur vhf transceiver
frequency range:      tx: 144-148 mhz
rx: 136-174 mhz
mode:      fm
rf power output:      hi: 3.5-5 w (depending on voltage)
lo: 0.3 w
sensitivity:      0.18 uv (12 db sinad, between 144-148 mhz)
selectivity:      10 khz (-6 db), 28 khz (-40 db)
image rejection:      n/a
voltage:      6-9 vdc (pb-43n or bt-14 battery packs)
current drain:      rx: 30-130 ma
tx: max 2 a
impedance:      50 ohms
dimensions (w*h*d):      58*120*39 mm (with bt-14)
weight:      259 gr (with bt-14)
manufactured:      2007-200x
离线BD7ISO
只看该作者 1楼 发表于: 2007-05-23
看这样子还不如中国货
离线BD3RJ
只看该作者 2楼 发表于: 2007-05-23
本年度最丑的机器了
