  • 5646阅读
  • 20回复
KU9C写给信 - 关于BS7H QSL卡注意问题 [复制链接]
离线BA7NQ
只看楼主 倒序阅读 0楼 发表于: 2007-05-21
folks,
i have received quite a number of qso not in logs, i forgot my qso detail, my dog/significant other/kid/etc trashed my log, etc questions in the last week, so let me help with some ground rules:
i'm not in a position to answer whether you are in or not in the log at the moment. rather than ask via email, i'd ask you to kindly put the inquiry in a note with your qsl to me. i'll research the log as i work your qsl request, and respond accordingly. if you are not in the web log, don't give up, put down every qso you believe you had, and i'll do the rest. if the web log shows 20ssb, put down every qso you think you had on 20 ssb, not just the first. don't be embarassed with dupes, rather, give me all the qsos you've had, i'll see the dupes anyway, but if you are not in the log the first time, it will save me a lot of time researching. remember, every researched call takes time from processing other cards. if it's a busted call, i'll use well-established judgement in issuing the card, and may ask you to help confirm that the person's whose call appears did not make a qso.
if you do not have any detail besides what is in the web log online, it's impossible for me to give you credit for the card. i need to have some supporting detail on your qso. give me your best guess from memory, who you heard work bs7h just before or after. chances are one of your friends was in the hunt at the same time, and can help. remember, it will be a lot easier to remember it now than a month from now. and, i'm not in a position to issue a qsl to you 'just because' the web log says you're there. not the way it works.
don't fret the 39 cent stamp or the 84 cent stamp you sent before the postage increase. i'll cover it.
if i do not respond to your email, please don't take it personally. please follow the guidelines here.   i tend to not answer the emails when they ask the questions above, as each email is roughly equivalent to the time it takes to answer 2-3 qsls...and i tend to choose to answer the cards first.
i'll let you know when the cards start going out via this forum.
as an aside, if you have a problem with how i do qsls, how long it takes to get a card from me, etc, please take it up with me directly. i don't appreciate reading it third hand via a reflector, etc. frankly, if you are kind enough to send me a note, i'll be glad to help research it. in many cases, i may be able to help you understand why the process take so long for your qsl, as i keep pretty good records of those calls that take time, and for what reasons that is the case.
73
steve ku9c
离线BD4SO
只看该作者 1楼 发表于: 2007-05-21
ok,阅读了。知道了,幸好我认为有一个qso没有查到无所谓,不会去发mail什么的查询。通道就可以了,不在乎多少了,比美国东岸的那些没有叫的ham,我们可是幸运多了
离线bg5baj
只看该作者 2楼 发表于: 2007-05-21
天书啊,请高手翻译下
离线BD6SN
只看该作者 3楼 发表于: 2007-05-21
爱好而已,都是玩的东西。。。不要太认真。。。
离线bv2ac
只看该作者 4楼 发表于: 2007-05-21
大意是他家的狗狗或小孩把 log 玩丟了,.... 天阿, 不會要我們的團隊再去做一次吧... :)
离线BA1RB
只看该作者 5楼 发表于: 2007-05-21
老蔡,你再仔细看看谁家的狗狗或小孩把谁的log 玩丟了...
离线bv2ac
只看该作者 6楼 发表于: 2007-05-21
明白了... 有狗與小孩的不適合玩無線電... nq 不去是對的... :)
离线ba7ib
只看该作者 7楼 发表于: 2007-05-21
没看懂,我想知道怎么跟bs7h交换卡片?
离线BA7NO
只看该作者 8楼 发表于: 2007-05-21
像我不懂鸟语的可试一下这个:
http://www.google.com/language_tools?hl=zh-cn
离线BD4SO
只看该作者 9楼 发表于: 2007-05-21
[quote=bg7 msn]像我不懂鸟语的可试一下这个:
http://www.google.com/language_tools?hl=zh-cn[/quote]
如果用这个翻译的话,哈哈,要看的云里雾里的
离线BA7NO
只看该作者 10楼 发表于: 2007-05-21
没办法,凑和.凑和.哈哈!
离线BA4RF
只看该作者 11楼 发表于: 2007-05-21
大意是:
1,别写email问他为什么网上查不到自己的某个qso
2,你在寄卡片的时候把你所有认为成功的联络都写上,一个波段有多个也要都写上,如果网上某个qso查不到,最好回忆一下你联络那个时间前后分别有哪些人联络了bs7h。
重点就是这些啦
离线BA6QH/QRP
只看该作者 12楼 发表于: 2007-05-21
不是说一起寄过来的吗?
离线BA4RF
只看该作者 13楼 发表于: 2007-05-21
这个是写给全世界ham的,不是写给中国蛤蟆的
离线BG7LKJ
只看该作者 14楼 发表于: 2007-05-21
嗯,很好的说,看来又有戏了
离线bg4wzh1
只看该作者 15楼 发表于: 2007-05-22
不是写给中国蛤蟆的
离线bv2ac
只看该作者 16楼 发表于: 2007-05-22
主要是寫給美國腿看的.... 因為提到郵費 39分錢 84 分錢. 美國以外非得 一兩塊錢不行.
他還提到一個觀念, 不知我解讀對不對, 重複通訊, 好像不是值得提倡的. 尤其 4dw 兄也期期以為不可, 這增加我的信念...
許多人為了保險起見, 就一直作同波段重複通訊, 換 op 也重複, 換日子也重複, ku9c 似乎替這些人解套, 認為他們有通就提出來, 不必害羞(本意是重複通信應該自覺可羞吧...), 以增加獲卡的機會, 當然 ku9c 似乎只會回覆第一次通聯那一張....
离线BD7YA
只看该作者 17楼 发表于: 2007-05-30
看了好久才看明白!
离线BD5SLD
只看该作者 18楼 发表于: 2007-06-08
请教
查不到交寄qsl的截止日期。本周末投邮来得及吧?
bd5sld/landi
离线bv2ac
只看该作者 19楼 发表于: 2007-06-08
查了字典, folks 是 "鄉親們" 的意思, 所以應該是寫給美國蛤蟆的....
