  • 4288阅读
  • 0回复
新机欣赏:Elecraft K3/100w [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2007-05-08
type:      amateur hf/vhf transceiver
frequency range:      tx: 10-160 m + warc / 6 m
rx: 0.5-30 / 50-54 mhz
mode:      am/fm/ssb/cw
rf power output:      max 100 / 100 w
sensitivity:      n/a
selectivity:      n/a
image rejection:      n/a
voltage:      13.8 vdc
current drain:      rx: ? ma
tx: max ? ma
impedance:      50 ohms, 2*so-239
dimensions (w*h*d):      ? mm
weight:      ? kg
manufactured:      usa, 2007-200x
other:      rs-232c. built-in psk31/cw/rtty decoder/encoder
built-in keyer. dvr option. sub rx option
related documents:
http://www.elecraft.com/news.htm
