  • 5185阅读
  • 20回复
功放欣赏:ALPHA 9500 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2007-04-24
价格8,950美刀
if it were alive the alpha 9500 would have the blood of champions coursing through its veins. the 9500 utilizes the same superbly designed rf deck found in its sire, the 87a. we didn’t stop there in designing this prodigy child, we took all the best parts of the 87a and made them better than they already were. rather than using a single microprocessor for control and processing the 9500 uses no less than 5; vastly expanding its ability to deliver crystal clear linear amplification. if anything the 9500 will tune more quickly and accurately than before. with a 3:1 swr this amplifier is as rugged and reliable as anything we’ve created yet, couple that with 4 antennae ports you have an amplifier that most hams only dream of.
measurements
width: 17.5"
height: 7.5"
depth: 19.75"
weight: 76 lbs.
specifications
frequency coverage: all amateur frequencies from 1.8-29.7 mhz
power output: 1500 watts minimum
3rd order im: <-30 dbc
swr tolerance: 3:1
drive power: 65 watts nominal
tube: eimac 8877
cooling: forced air
antenna outputs: 4xso-239 connectors
antenna selection: 1 or 2 outputs per band/segment
input: so-239 connector
tuning/band switching: automatic. manual override possible
power: 100,120,200,220,240v ac, 50/60 hz
power tap selection: automatic
interface: serial port. full remote control capability
protection: protected against all common faults
display: bar graphs as well as digital panel meter
t/r switching: vacuum relays; qsk (full break-in)
bypass capability: 1500 watts
wattmeter and antenna selector active in "on1" to allow use with exciter. hv and tube come on in "on2" for linear use.
离线BA0BZ
只看该作者 1楼 发表于: 2007-04-24
1995年到2005年期间,alpha总共生产并且卖掉了1500台87a,用家评价他的缺点,通常只有三个:
1、价格太贵
2、pin二极管qsk t/r切换电路太脆弱,容易在偶然的错误操作或者过高的swr下烧毁。
3、3cx800a的管子比较贵,即使是svetlana的仿造产品。
终于,alpha意识到了这个问题,屏弃了86、89、87a系列的超级迅速的全固态pin qsk电路,采用了寿命有限(2,000,000次动作寿命)、速度有限(6~8ms典型切换时间)但是健壮无比的kilovac hc-1真空陶瓷继电器作为t/r qsk切换。
arrl的报告还没有见到,让我个人来评价,唯一的不满足就是没有配备和acom 2000a一样的遥控盒子,虽然9500有遥控功能,但是必须运做于pc的软件操控之中。
当然,8,950 usd的价格也是我辈所不能企及的贵族奢侈产品……
备注:更换一只原厂eimac 8877管子的代价是 special price: $799.00,现在rfp特价销售
http://www.rfparts.com/tubetran.html
离线BA7EI
只看该作者 2楼 发表于: 2007-04-25
请问BD3RJ买了吗
[quote=bd3rj]价格8,950美刀
quote]
没有提供内部的结构图片,让大家无法进一步欣赏.
我觉得网络上卖的$1200元的811h电子管功放(800w) 可能介绍得更详细,更适合于不愿让无线电设备占据较大空间的发烧友使用.
离线BD3RJ
只看该作者 3楼 发表于: 2007-04-25
我要支持国货,要不该被你打了。等6cg
离线VR2KW
只看该作者 4楼 发表于: 2007-04-25
quote] [表情]
我觉得网络上卖的$1200元的811h电子管功放(800w) 可能介绍得更详细,更适合于不愿让无线电设备占据较大空间的发烧友使用. [表情]
1200元?什麽货币?
离线BD7YK
只看该作者 5楼 发表于: 2007-04-25
[quote=ba7ei]
1200元?什麽货币? [表情]
美金还差不多
离线BA7EI
只看该作者 6楼 发表于: 2007-04-25
1200元?什麽货币? [表情]
quote] [表情]
....................我觉得网络上卖的$1200元的811h电子管功放(800w) 可能介绍得更详细,更适合于不愿让无线电设备占据较大空间的发烧友使用. [表情]
已经标注了货币种类的啊,是美元.
离线BA7EI
只看该作者 7楼 发表于: 2007-04-25
我要支持国货,要不该被你打了。等6cg
这才是好同志,要购买国货精品
俺现在不能发射,而且已经拥有标准的400w设备,所以暂时停止购买制造一切以实用为主的设备.另外由于本人操控水平低,只能买皮实的设备;又由于国家信息产业部的要求可能越来越严格同时为避免妨碍其他业余爱好者的正常通联,我必须购买能够经得起无线电监测站测试考核的设备
希望看到能够满足以下全部要求的全自动功放精品:
1、抗满功率长发射时天线突然短路,并持续20分钟以上;
2、抗满功率长发射时天线突然开路,并持续20分钟以上;
3、在不与电台alc联结的情况下,必须保证抗至少五倍和不低于200瓦输入的过激励,同时不得对电台造成影响;
4、符合国家标准中的一切强制性指标要求,并留有不少于6db的余量;
5、最大额定输出功率不小于2kw;
6、总重量不大于50 kg;
7、总体积不大于xs-d12收信机主机;
8、必须带机内型自动天调,能够保障设备在驻波小于5的天线系统中实际输出的功率不小于最大额定功率的80%。
离线BA0BZ
只看该作者 8楼 发表于: 2007-04-26
假如楼上可以提供swr≥5下承受rtty(cw按长键)功率≥2000w、持续20分钟不烧毁的、高度小于8米、占地面积≤4.5平方米(包含拉线桩子,支撑结构件在内的所有组件的占地面积(包含空中的部分在地面的投影面积))、7.000~7.300、10.000~10.100、14.000~14.350、18.068~18.168、24.890~24.990、28.000~29.700、50.000~54.000mhz所有业余段内全业余段工作swr≤2.0:1,增益≥0dbi(增益测试基准天线为理想地平面,1/4波长垂直天线)的天线(不论成品型号或者diy产品),本人高价收购!
垂直笼形天线或者配备2000w自动天调已经失去了上述命题的意义,前者的支撑结构件远大于4.5平方米的占地面积,后者的实际增益难以满足命题要求……
个人愚见:swr≥3.0:1的时候还能够承受2000w以上的功率的天线是没有实际意义的,研发类似严酷场合的发射机也是没有实际意义的……
quote]
我觉得网络上卖…………………………………………………………可能介绍得更详细,更适合于不愿让无线电设备占据较大空间的发烧友使用. [/quote]
某型号800w真空管放大器带假负载输出800w rtty功率20分钟的后是……
离线BA7EI
只看该作者 9楼 发表于: 2007-04-26
假如楼上可以提供swr≥5下承受rtty(cw按长键)功率≥2000w、持续20分钟不烧毁的、高度小于8米、占地面积≤4.5平方米(包含拉线桩子,支撑结构件在内的所有组件的占地面积(包含空中的部分在地面的投影面积))、7.000~7.300、10.000~10.100、14.000~14.350、18.068~18.168、24.890~24.990、28.000~29.700、50.000~54.000mhz所有业余段内全业余段工作swr≤2.0:1,增益≥0dbi(增益测试基准天线为理想地平面,1/4波长垂直天线)的天线(不论成品型号或者diy产品),本人高价收购! [表情]
........…… [表情] [表情] [表情]
对于你提出的"swr≥3.0:1的时候还能够承受2000w以上的功率的天线是没有实际意义,研发类似严酷场合的发射机也是没有实际意义的"我不反对. 为此,我降低标准,
5、最大额定输出功率不小于1.6kw.
8、必须带机内型自动天调,能够保障设备在驻波小于3的天线系统中实际输出的功率不小于最大额定功率的75%。
超过400w的大功率pa我没有,但是我发现我们这儿军分区的76发射机正在用的天线好像是不能保证全段swr≤5.
我原来的实际要求是机内天调在天线系统的swr≤5的情况下可以准确调谐
另外,我不喜欢纯业余段发射的机器,希望在1.8mhz----32mhz全段均能发射,在业余段保证性能
离线BD3RJ
只看该作者 10楼 发表于: 2007-04-26
76能自动调谐吗?
离线BA7EI
只看该作者 11楼 发表于: 2007-04-26
76能自动调谐吗?
76能手动调谐
离线VR2KW
只看该作者 12楼 发表于: 2007-04-26
1200美元的811h是不是太贵了。
其实我对机器的要求很简单,就是在不接天线的情况下都能随时通遍全球任何一个角落
离线BA0BZ
只看该作者 13楼 发表于: 2008-08-24
9500谍照若干
照片引自alpha官方网站
明显还是有很浓厚的87a的做工的风格
离线BA0BZ
只看该作者 14楼 发表于: 2008-08-24
9500和2100并排放置,有浑然一体的美感
离线BG4XCR
只看该作者 15楼 发表于: 2008-08-24
&#9760;
    剧 毒!
离线BD8ATI
只看该作者 16楼 发表于: 2008-08-24
毒啊毒。。。。。。。。。。。
离线chengrc
只看该作者 17楼 发表于: 2008-08-24
yyyyyyyy
ddddddddddd
离线wytj
只看该作者 18楼 发表于: 2008-08-24
剧毒!为了你的健康,请远离毒品!
离线BA7EI
只看该作者 19楼 发表于: 2009-09-13
在与ba3rj钻牛角尖之后,更多的是震撼
