  • 3924阅读
  • 2回复
谁能把军刀里的功能菜单定义解释一下 [复制链接]
离线bg7fq
只看楼主 倒序阅读 0楼 发表于: 2007-04-17
里面功能太多,英文又看不懂,请高手指点指点
离线bg7fq
只看该作者 1楼 发表于: 2007-04-17
h251      60 sec. tot
h901      non-standard tot
       silent monitor
h371      zone and channel operation
h560      talkaround
h256      two zone operation
h396      channel only operation
h346      zone display names
h380      channel display names
h397      menu lock
h345      radio lock
h669      omit inadvertent lock
h153      omit all tones
h384      muting via keypad
h365      transmit inhibit on busy channel
h359      channel busy led
h906      low battery led
h375      selectable pl (encode only)
h649      selectable pl (encode/decode)
h958      unit id - mdc 600
h961      unit id and emergency - mdc 600
h963      unit id w/ audible emergency - mdc 600
h923      unit id w/ emergency revert - mdc 600
h959      unit id - mdc 1200
h962      unit id and emergency - mdc 1200
h967      unit id w/ audible emergency - mdc 1200
h946      unit id w/ emergency revert - mdc 1200
h368      autodial
h297      manual telephone interconnect
h444      delete proper code detect
h245      delete clear mode alert tone on tx
h244      delete clear/coded transmission switch
h400      secure voice slaved to a mode
h401      clear voice slaved to a mode
h432      vp capable-only
h273      operator selectable scan
h344      mode slaved scan
h852      6d master option
h549      8d master option (advanced statalert)
谁能翻译一下么?谢谢!
离线zhangbo
只看该作者 2楼 发表于: 2007-04-18
h251 60 sec. tot   60秒发射超时时间
h901 non-standard tot 非标准发射超时时间
silent monitor   静音监听
h371 zone and channel operation   区域和频道操作
h560 talkaround   广播
h256 two zone operation 两区操作
h396 channel only operation 仅频道操作
h346 zone display names 显示区域名称
h380 channel display names 显示频道名称
h397 menu lock 菜单锁定
h345 radio lock 无线电锁定
h669 omit inadvertent lock 避免误操作锁定
h153 omit all tones 忽略所有音频
h384 muting via keypad 键盘音消除
h365 transmit inhibit on busy channel 忙频道发射抑制
h359 channel busy led 频道忙指示灯
h906 low battery led 低电池指示灯
h375 selectable pl (encode only) 可选择的pl (仅编码)
h649 selectable pl (encode/decode) 可选择的pl (编解码)
h958 unit id - mdc 600 设备识别号
h961 unit id and emergency - mdc 600 设备识别号和紧急呼叫
h963 unit id w/ audible emergency - mdc 600 设备识别号和有声紧急呼叫
h923 unit id w/ emergency revert - mdc 600 设备识别号和紧急呼叫回复
h959 unit id - mdc 1200 设备识别号
h962 unit id and emergency - mdc 1200 设备识别号和紧急呼叫
h967 unit id w/ audible emergency - mdc 1200 设备识别号和有声紧急呼叫
h946 unit id w/ emergency revert - mdc 1200 设备识别号和紧急呼叫回复
h368 autodial 自动拨号
h297 manual telephone interconnect 手动电话中继
h444 delete proper code detect 删除监测到的代码
h245 delete clear mode alert tone on tx 删除明码模式的发射时警告音
h244 delete clear/coded transmission switch 删除明码/密码发射开关
h400 secure voice slaved to a mode 保密语音归属于a模式
h401 clear voice slaved to a mode 非保密语音归属于a模式
h432 vp capable-only 仅vp有此能力
h273 operator selectable scan 用户可选的扫描
h344 mode slaved scan 模式归属于扫描
h852 6d master option 主要的选项
h549 8d master option (advanced statalert) 高级主要选项
不知道对不对,你让我玩玩,可能就知道了。
