  • 43054阅读
  • 103回复
ICOM IC-2820H 使用简评 及 新着情报 [复制链接]
离线BD7PA
只看楼主 倒序阅读 0楼 发表于: 2007-04-07
icom ic-2820h 使用简评 及 新着情报
你的支持是本帖延续的重要源动力
离线BD7PA
只看该作者 1楼 发表于: 2007-04-07
全中文化的功能解释和说明,应用实例展示,有人支持便继续下去。.
离线BA7NQ
只看该作者 2楼 发表于: 2007-04-07
强啊!pa上仓了吗? :d
离线BA7NQ
只看该作者 3楼 发表于: 2007-04-07
gps接收机是标配啊!有没有gps的数据输出口,用来接外置的电子地图。
离线BD7PA
只看该作者 4楼 发表于: 2007-04-07
感谢 梁站 ba7nq 大佬支持~~
玩对讲机就像玩手机,新的、强劲功能的才过瘾,ic-2820h + ut-123 是必收机型、yaesu ftm-10 订了,在送往途中,20号到,如果有人有兴趣,也会上使用报告和新着情报。
gps 仅为日本本土版标配.
离线黑衣
只看该作者 5楼 发表于: 2007-04-07
好机器!
icom ic-2720h 144/440 mhz mobile   discontinued!
replaced by the ic-2820h
离线黑衣
只看该作者 6楼 发表于: 2007-04-07
the icom ic-2820h 2m/440 dual bander has all the features you would expect and some you would not! you get: separate front panel, wideband receive, 3 power settings, built-in ctcss decode/encode, selectable amber/green display, pc compatibility and 522 memory channels. v/v and u/u receive is available. the rear panel has two so-239 antenna jacks to support diversity reception (two antennas required). the diversity function compares the receiving signal strength from two different antennas, ant1 and ant2, and automatically selects the strongest signal. this feature is useful when you are listening in a moving vehicle or the transmitting station itself is moving. diversity receiving is available in 127 mhz, 136 mhz, 146 mhz, 375 mhz, 440 mhz and 500 mhz bands only.
the ic-2820h is d-star upgradeable with the optional ut-123 power output is 50/15/5 watts on 2 meters and 50/15/5 watts on 440 mhz. it is 9600 bps packet ready too (6 pin din). this radio comes with full function backlit hm-133 remote dtmf hand mic, mounting bracket, power cord and spare fuses. please note that the mic plugs into the body (not the head). main unit size: 5.9 x 1.65 x 7.4 inches 3.3 lbs (150x40x188 mm 1.5 kg). controller size: 5.9 x 2.6 x 1.25 inches 7.4 ounces (150x58x32mm 210g). this model requires 13.8 vdc at 12 amps. this radio is supplied with both the opc-1663 (11 foot) and opc-1712 (3.9 inch) head separation cables.
离线黑衣
只看该作者 7楼 发表于: 2007-04-07
icom ic-2820h
144/440 mhz mobile
order #2820
list price:   $768.00
your price: $649.95
离线BD7PA
只看该作者 8楼 发表于: 2007-04-07
昨天,调成大字体显示,拿给爸爸看,第一反应是:这 频率数字 是不是 大得 太夸张了!
离线BD7OE
只看该作者 9楼 发表于: 2007-04-07
好机器,支持pa。
在线BD7JAC
只看该作者 10楼 发表于: 2007-04-07
感谢 梁站 ba7nq 大佬支持~~
gps 仅为日本本土版标配.
想问一下上面所指的ut-123和ftm-10是什么冬冬?配件还是选件?
离线zdzd8888
只看该作者 11楼 发表于: 2007-04-07
晕~ 开了两个新贴~ 够你累的~
离线zdzd8888
只看该作者 12楼 发表于: 2007-04-07
ut-123应该就是gps组件吧~
看2820有几个版本~
2820 2820h 2820g
带g的就是指gps也就是本土版的吧~
离线BG4XCR
只看该作者 13楼 发表于: 2007-04-07
全模式就好了
离线BD7PA
只看该作者 14楼 发表于: 2007-04-07
文章要大于5只字
离线BD7PA
只看该作者 15楼 发表于: 2007-04-07
ut-123应该就是gps组件吧~
看2820有几个版本~
2820 2820h 2820g
带g的就是指gps也就是本土版的吧~
.信息提交时发生如下错误:
你输入的信息太短。请扩充你的信息至少为 5 字符。
离线BD8AAP
只看该作者 16楼 发表于: 2007-04-08
ICOM公司IC2820双段电台设备介绍
一、基本情况介绍
  icom公司于2007年初,推出了新款型的双段(u/v)车载式电台,设备型号为ic-2820,与以往不同的是,该设备提供了基本形态的gps(全球卫星定位系统)功能。
  针对不同的销售地区,该电台目前分为三个版本,并以不同的后缀加以区别,即:ic-2820dg、ic2820g、ic2820h。
其中,ic-2820dg、ic2820g两个版本为日本本国所使用,而ic-2820h则是针对其它国家或地区。ic-2820dg与ic-2820g相比较,其功能、性能以及配置均相同,区别仅在于发射功率的大小,前者的最大发射功率为:50w,后者为:20w。
  ic-2820h的最大发射功率也为:50w,与ic-2820dg不同的地方是,在“v”段上的发射频率范围有所限制,前者是:144mhz~148 mhz,后者是:144mhz~146 mhz。
二、基本功能介绍
1、显示屏、外观及结构
  显示屏较大(相对于其它机型),并采用点阵方式显示有关提示信息,由于采用的点阵比较细腻,不论是显示小字符、大字符时,均清晰、圆润。还可根据显示信息的多少,自动调整显示字符的大小,使之尽可能的采用较大字符。
可对lcd的亮度、颜色、对比度分别进行调整,其中颜色可在:橙红、橙色、黄色、绿色之间进行设定,做到了细微且平滑过度式的调整,以适应不同的使用者,对色泽方面的偏好。
  机头(显示部分)与主机之间的连接,采用了两块圆形磁铁(安装在机头一侧)进行有效吸附,主机一端有两组吸附点,根据不同的吸附点,可调整机头与主机之间的高度差(距离有限),使用者不需要另外购买其它的选配件便能够连接使用,且拆装也很快捷、方便。而这一功能设计,既是它的优点,也是它存在的瑕疵。
  当机头与主机有效吸附之后,用于gps的天线插头,便无法插入到主机插座上,这对于非分体安装的使用者来讲,只能被动放弃使用gps的功能,否则就只能采用分体形式的安装,也就是说,原不需要另外购买选配件的初衷,是不能办到的。换句话讲,还是需要您diy或是另外购买选配件,如:mb-65选件。
2、gps功能
  ic-2820提供了gps的基本功能,通过一个小型的平板天线(采用了磁性材料,方便吸附),可将采集到的卫星数据,通过lcd动态的显示出来,这些数据包括:
●经度
●纬度
●utc时间(可设置时差)
●海拔高度
●模拟图示指南针
●自身与对方之间的距离(可适应动态变化,并自动计算)
  在显示上述数据的同时,还能够显示出主频段(main.band)的工作频率,且能够实时监听来自主频段、副频段的声音信号。
在实际使用过程中,个人感觉对于gps天线的摆放位置方面的要求似乎并不苛刻,吸附在阳台的空调机上或金属花架上均可,如果方向合适,摆放在室内也可。当lcd上“gps”字符开始闪烁时,相关数据将丢失,此时则需要调整一下天线的位置。
3、菜单功能
  提供了分类、嵌入式的多级功能菜单,每一级菜单及选项,均给出了相对应的编号,如:13/14(gps set mode)等,提示信息较为详尽,使得在进行参数变更设置操作时,易于理解。由于采用了点阵式显示方式,所给出的提示信息既丰富也正规,与其它笔划式显示方式比较,更加符合人们常规的识别习惯方式,使得人、机间的对话界面,变得友好和易于操控。
以设置时差为例,操作、提示步骤及详细设置方法如下:
注:当“gps“字符在闪烁时,表示未接收到卫星的信号!
①、按【f】键,进入提示菜单,在lcd屏最后一行出现:
“mode ts scp skip m.n sngl menu”或
“ce   cd cq r>cs msg rec   menu”提示信息;
②、按“menu”所对应的功能键↘【v/mhz scan】;
③、旋转【dial】波轮,出现13/14“gps set mode”菜单选项;
④、按【main.band】键,出现04/7菜单,可选项有(7项):
      gps speed       9600
      units           m
      compass arrowhead
utc offset       +8:00
gps datum         0
alm area1     00’15’’
      alm area2     00’15’’
⑤、旋转【dial】波轮,出现04/07 utc offset +8:00菜单选项;
⑥、按【main.band】键,进行确认;
⑦、旋转【dial】波轮,可对时差进行-12小时至+12小时之间进行调整
注:调整步长为5分钟;
⑧、按【main.band】键,进行确认;
⑨、按【f】键退出。
4、工作模式
ic-2820提供了五种工作模式供使用者选择,且选定的工作模式均会通过lcd显示出来,具体工作模式如下:
①、      fm
②、      fm-n
③、      am
④、      am-n
⑤、      dv(需具备ut-123模块)
三、ic-2820dg部分指标介绍
●发射功率、电流
频段      hi(高功)      消耗电流      mid(中功)      消耗电流      low(低功)      消耗电流
144mhz      50w             13.0a             约15w             约7.5a          约5w        约5.5a
430mhz      50w             13.0a             约15w             约7.5a           约5w           约5.5a
●发射频率范围
v段(144mhz):144.000mhz ~ 146.000mhz
u段(430mhz):430.000mhz ~ 440.000mhz
●接收频率范围
主通道(左侧)                     副通道(右侧)
118.000 mhz ~ 282.895 mhz      118.000 mhz ~ 173.995 mhz
255.100 mhz ~ 261.895 mhz      375.100 mhz ~ 376.895 mhz
266.100 mhz ~ 270.895 mhz      382.100 mhz ~ 411.895 mhz
275.100 mhz ~ 379.895 mhz      415.100 mhz ~ 549.995 mhz
382.100 mhz ~ 411.895 mhz      834.100 mhz ~ 859.890 mhz
415.100 mhz ~ 549.995 mhz      889.100 mhz ~ 914.890 mhz
无800 mhz、900 mhz段位      960.100 mhz ~ 999.990 mhz
●主通道(左侧)接收灵敏度
频率范围      fm 12db sinad      am 10db s/n
118.000 mhz ~ 159.995 mhz      -10dbμ(0.32μv)      0dbμ(1μv)
160.000 mhz ~ 179.995 mhz       -5dbμ(0.56μv)      ————
180.000 mhz ~ 219.995 mhz      +15dbμ(5.6μv)      ————
220.000 mhz ~ 224.995 mhz       -5dbμ(0.56μv)      +5dbμ(1.8μv)
225.000 mhz ~ 349.995 mhz      +15dbμ(5.6μv)      +25dbμ(18μv)
350.000 mhz ~ 359.995 mhz       -5dbμ(0.56μv)      +5dbμ(1.8μv)
360.000 mhz ~ 374.995 mhz      +15dbμ(5.6μv)      +25dbμ(18μv)
375.000 mhz ~ 399.995 mhz       -5dbμ(0.56μv)      +5dbμ(1.8μv)
400.000 mhz ~ 499.995 mhz      -10dbμ(0.32μv)      ————
500.000 mhz ~ 549.995 mhz       -5dbμ(0.56μv)      ————
●副通道(右侧)接收灵敏度
160.000 mhz ~ 173.995 mhz       -5dbμ(0.56μv)      ————
810.000 mhz ~ 879.995 mhz       -2dbμ(0.79μv)      ————
880.000 mhz ~ 879.995 mhz       +5dbμ(1.8μv)      ————
●存贮信道数量
常规存贮信道(mr):500个(0 ~ 499)
程序扫描信道(program-ch)10组(20个):
  0a - 0b、1a - 1b、2a - 2b、3a - 3b、4a - 4b、
  5a - 5b、6a - 6b、7a - 7b、8a - 8b、9a - 9b。
呼叫信道(call-ch)2个 :c0、c1。
主通道(左侧)、副通道(右侧)均使用同一个存贮信道资源!
●存贮信道命名
命名字符长度:8个字符
可用字符集有:a ~ z、a ~ z、0 ~ 9、(space)、!部分日文字符
●工作温度范围:-10℃ ~ +60℃
●频率稳定度: ±2.5ppm(-10℃ ~ +60℃)
●频率步进值: 5khz、6.25khz、10khz、12.5khz、15khz、
20khz、 25khz、30khz、50khz
●设备中频:38.55mhz/450khz(左侧“主通道”)
46.35mhz/450khz(右侧“副通道”)
●选择性
    fm narrow —— 6khz以上/6db、20khz以下/60db
    fm wide   —— 10khz以上/6db、30khz以下/60db
    dv       —— 50db以上
●隔离度
    vhf段 —— 60db以上
    uhf段(右侧“副通道”) —— 60db以上
    uhf段(左侧“副通道”) —— 55db以上
●工作电压:dc 13.8v ±15%
●接地方式:负极接地
●收信电流:1.8a(最大值)
        1.2a(待机状态)
●喇叭阻抗:8Ω
●音频功率:2.4w
●整机尺寸:150(w)×58(h)×31.5(d)mm
●整机重量:1.5kg
四、其它
  ic-2820所采用的散热方式与以往有所不同,靠近设备前端上下的两个面均开有散热孔洞,当散热风机工作时,会在设备外部形成风口,在设备内部形成风道,此设计有利于快速降温,但却带来了噪声偏大的问题,若在卧室内使用这一现象尤为突出。
  关于控制软件方面,icom公司目前提供了两类产品:opc-478u、cs-2820。opc-478u产品是一个接口设备,用于电台与pc机之间的连接(使用usb接口),配套的光盘提供了该设备的驱动程序,整个光盘的信息容量为754k。
  cs-2820则应该是安装在pc上,用于操控ic-2820的软件。
  由于ic-2820目前还属于较新的机型,使用者大多还处在摸索阶段,本人给出的介绍可能难免出现错误或是笔误,这一点也请大家谅解。在此感谢7pa所开的专贴,为大家提供了一个学习、交流的平台,这对大家了解这款设备、用好这款设备无疑将起到积极的作用。
  以上介绍仅供同好之间参考和交流。
离线BD7PA
只看该作者 17楼 发表于: 2007-04-08
非常好的介绍资料, 感谢bd8aap的辛勤努力!! 让我对此机有了更深一步的认识和了解!
离线BD8AAP
只看该作者 18楼 发表于: 2007-04-08
IC-2820实物图片-01
ic-2820实物图片-01
离线BD8AAP
只看该作者 19楼 发表于: 2007-04-08
IC-2820实物图片-02
ic-2820实物图片-02
