  • 2177阅读
  • 0回复
Agilent10076A电压探头 [复制链接]
离线chengy
只看楼主 倒序阅读 0楼 发表于: 2007-03-24
agilent10076a 电压探头
100:1 high-voltage probe
the 10076a 4kv 100:1 passive probe gives you the voltage and band-width you need for making high-voltage measurements.its compactdesign makes it easier to probe today''s small power electronics com-ponents and its rugged construction means it can withstand roughhandling without breaking.you can measure dc voltages up to 4 kv peak.the 250 mhz probe bandwidth enables you to capture fast,high-voltage signals.the 10077a accesory kit can be used with thishigh voltage probe for wider range of application.
生产厂家:安捷伦agilent
基本全新 用过几次 没有附件资料
价格:750元
