  • 5520阅读
  • 11回复
AGWTracker Mobile - APRS Program for WM5 [复制链接]
离线VR2VJJ
只看楼主 倒序阅读 0楼 发表于: 2007-03-12
由 agwtracker yahoo group 轉貼:
     from            "(sv2agw)george rossopoulos" <sv2agw@freemail.gr>       mar 11 (1 day ago)
     reply-to            agwtracker@yahoogroups.com
     date            mar 11, 2007 4:47 pm
     subject            re: [agwtracker] agwtracker goes mobile.......... part 2
     mailed-by            returns.groups.yahoo.com
hi
from now on i will post everything about agwtracker mobile to this list
only.
first of all i would like to thank all of you who responded positive about
this project.
its really impressive how many responded, amazing, there are a lot of those
units out there.
the program as i already stated is not even beta version....
a new version will released on monday.
it will have the gps view and capability to tx position from gps.
so far the only way to transmit/receive data is only over internet (or
wifi).
very soon we will be able to connect with any tranceiver using the new tnc
from elcom which will have bluetooth.
i will release "packet engine pocket" as soon agwtracker pocket becomes
stable.
about the program itself now, as you have seen it looks exactly like
agwtracker for pcs. i am going to use it mobile and i will change the
interface so to be usefull for mobile use. large buttons to push with finger
etc...
any ideas are welcome..
that's for now
73
(sv2agw) george rossopoulos
sv2agw@elcom.gr <mailto:sv2agw%40elcom.gr>
www.elcom.gr/sv2agw
+306932465216
george rossopoulos
nikanoros 59
54250,thessaloniki
greece
离线VR2VJJ
只看该作者 1楼 发表于: 2007-03-12
http://www.elcom.gr/sv2agw/pocket_trk.htm
wah.. 有藍芽的 tnc.. woow. 不知道會不會很貴呢? ;-)
离线BD6CR
只看该作者 2楼 发表于: 2007-03-12
我最喜欢的部分是这个:
wifi).
离线bd4rs
只看该作者 3楼 发表于: 2007-03-13
下载了.并装在dopod c600上,但运行以后没有任何程序出来.
不知是不是系统还不行.操作系统是wm5. cpu:omap850 195mhz,总内寸44.69mb.程序是装在还有百兆空间的sd卡上.
离线BD6CR
只看该作者 4楼 发表于: 2007-03-14
先解压,有两个文件,其中一个直接运行就行了.
离线bd4rs
只看该作者 5楼 发表于: 2007-03-14
是解压装了两个文件,运行.exe文件后,好象建了一个maps的目录,我将pc的agwtracker下maps目录下的地图文件copy了两个过去.运行还是没有反映.
离线BG5HMT
只看该作者 6楼 发表于: 2007-03-14
wifi).
不知道gprs行不行呢?
我的在d900上装了以后(wm5)有点不正常,界面上有几个字没显示出来,不过看起来主要功能是正常的。
还有地图一定要自己手工拷贝到map目录里面吧,google map什么的好像是灰色的。不像agwtracker for pc版本那样直接可以用google map。不然连google maps mobile的功能都代替拉,哈哈。
不知道正式版本出来会怎么样?要是又能发位置信号,又能看别人位置,再结合卫星地图,那爽翻了!pc也不要了,ge mobile也代替了,直接在上面看到自己在哪里,又看到别人在哪里,就好了!
离线BG5HMT
只看该作者 7楼 发表于: 2007-03-18
今天试验了一下agw mobile。是将多普达d900连电脑上上网的。
1.显示有点问题,就是几块卡片最上方的字显示不全。
2.地图功能有问题。在电脑上完全可以用的bmp地图文件,在d900里面打开是空白的,什么都没显示。
3.在d900上我输入了自己的呼号,因为手头没我家的详细地址,输入了n30度,e120度。然后点tx posintion,过会在电脑上就看到自己了!这一过程,不超过5秒钟。
4.服务器没有列表选择,自己按照电脑上可以用的输入一个。之后会在相同目录下形成一个txt文件,按理应该记录服务器的名字,只是有点小问题,里面多一些乱码。自己整理一下,以后就能自动出来了。
5.登陆的时候有个选项,我自己试验了一下,不选也一样能从软件发送信号。
离线BG5HMT
只看该作者 8楼 发表于: 2007-03-18
其实就试验了一小部分功能,证明了该软件:
1.可以发送位置信号给服务器;
2.可以在列表上看到各台站的位置。
试验失败的是:地图功能。
还没有试验的是:
1.连接gps。(因为蓝牙gps没在手边)
2.通过gprs上网。(因为还没去办套餐,没想好办啥套餐)
啥硬件都不需要安装就可以玩aprs的时代看来就要来了。但是会不会因为门槛很低,玩的人一下暴多带来别的问题呢?
离线BD6CR
只看该作者 9楼 发表于: 2007-03-19
我通过gprs上网连成了,但是地图还没试.另外,gps怎么设置呢?似乎没有什么地方可以设置gps的.
1.可以发送位置信号给服务器;
2.可以在列表上看到各台站的位置。
试验失败的是:地图功能。
还没有试验的是:
离线BG5HMT
只看该作者 10楼 发表于: 2007-03-19
今天继续试验。
找了半天,软件里竟然没有gps选项。晕了....
赶紧上agwtraker的网站去看,正好这两天有更新的beta版本!看了一下,主要有两个方面的改进:
1.出现了gps界面,虽然乱七八糟,有些还似乎藏在哪里,显示不出来,不过基本功能是有了。能接收蓝牙gps的信号;
2.有个aprsever.txt的文档,那些服务器的文本信息在里面,只要选一下就可以了,不用自己输了。
今天试验成功的是gps的接收,还有通过wifi能上网发位置信号。
然而最大两个问题没有解决:
1.发送的是固定站台信号,就是自己输入的经纬度。而接收来的gps信号竟然无法发出去,即使我删除自己设的经纬度也是一样。
2.无法显示地图,依然只能在列表上看见别人,而无法显示别人位置。
看来,发gps位置信号和在地图上显示他人位置的功能该软件其实都未做到,只是给我们看到一些希望。
怪不得这个软件几天就要有新的版本,看来离成熟还有一些时间。
离线BG5HMT
只看该作者 11楼 发表于: 2007-03-19
弄个新版本
去下载一个最新版本的,好像是3.13日,我今天刚下载,就看到有gps那个选项卡拉!
软件里面gps全自动设置,我没有做任何设置,就能看到一些卫星状态显示和经纬度显示。
我的d900是com8或com4都可以的。
不过我还是无法发gps位置信号!只能发手工设定的位置信号。
