  • 2910阅读
  • 2回复
少见的接收机DRAKE-SW8 [复制链接]
离线huashao128
只看楼主 倒序阅读 0楼 发表于: 2007-02-20
昨天刚到手,感觉音色不错,灵敏度还可以。因为比较少见,给大家介绍一下。
下面是参数
specifications
dimensions ............ 11.5w x 5.25h x 13d inches
weight ................ 10 lbs. (13 lbs. ship)
frequency range ....... 100 - 30000 khz
                87 - 108 mhz
                118 - 137 mhz
ac power .............. 120 vac 60 hz adapter
                or 6 internal d cells
antenna 1 ............. 50 ohms unbalanced
antenna 2 ............. 50 or 500 ohms unbalanced
antenna fm/air ........ 300 ohms
selectivity ........... @ -6db   mode
                6.0 khz   am
                4.0 khz   am
                2.3 khz   lsb/usb
ultimate selectivity .. > 95 db
image rejection ....... > 60 db   .5-30 mhz
                > 50 db   87-108 mhz
                > 60 db 118-137 mhz
i.f. rejection ........ > 80 db   55.845 mhz
                > 80 db     455 khz
ip3 intercept point ... > -20dbm 5 khz spacing
                > +10dbm 20 khz "
dynamic range ......... > 95 db .5-30 mhz ssb
sensitivity ........... 10 db s+ n/n
ssb             < 0.5&#181;v   .5-30 mhz
am               < 2.0&#181;v   .5-30 mhz
fm (20 db s/n)         < 4.0&#181;v   87-108 mhz
fm (20 db s/n)         < 4.0&#181;v   118-137 mhz
freq. stability ....... ± 10 ppm. 0° to 50° c.
freq. accuracy ........ ± 100 hz. @ 50° c.
ext. speaker output ... 2 watts, 4 ohms. < 5% distortion
line output ........... 300 mv, 4.7k ohms.
operating temp. ....... 0° to 50° c.
离线BG9TF
只看该作者 1楼 发表于: 2007-02-20
你的万用表好脏啊!
离线BD7PA
只看该作者 2楼 发表于: 2007-02-21
几过瘾,水.
