  • 3324阅读
  • 2回复
请教一个RTTY竞赛的问题 [复制链接]
离线BD1FJP
只看楼主 倒序阅读 0楼 发表于: 2007-02-03
今天1800(utc)就要开赛的ty mex rtty contest是哪个机构主办的,规则是什么?
请知道的朋友指教。谢谢
离线BD1FJP
只看该作者 1楼 发表于: 2007-02-03
终于找到了一个2006年的规则,贴在这里供感兴趣的朋友参考.现在我这里进不了fmre的官方网站,所以也下载不了他的fmre rtty international contest forms,好像writelog中也没有设置这个比赛的相关信息。我认为这个比赛对于通联美洲电台还是有益的。下面是2006年的文档:
federacion mexicana de radioexperimentadores, a. c. «f.m.r.e.»
2006 - mexico rtty international contest rules
1.- object: contact and exchange qso information with as many stations as possible. any station may work any other station. the call will be cq xe test or cq mexico test.
2.- contest period: first weekend of february. begins 1800 utc saturday, february 4, and ends 1759 utc sunday, february 5, 2006. the participants can operate the full 24 hours.
3.- mode: baudot rtty only.
4.- bands: all amateur bands, 3.5 to 28 mhz. (except 10, 18 & 24 mhz.)
5.- entry categories: a) single operator single radio, and b) single operator two radio. both categories “all band” only. high power permitted.
6.- exchange:
mexico: signal report and state.
dx: signal report and serial number, starting with 001
7.- scoring:
     (a) qso points: count two points for each completed qso in the same country. count three points for each completed qso in different country. count four points with any xe station.
     (b) multiplier: count only once, each mexico states and distrito federal (32 entities) and each dxcc country in each band worked. mexico do not count as dxcc country.
8.- reporting:
     (a) entries must be postmarked no later than 30 days after the end of the contest (march 5, 2006). no late entries can be accepted. use fmre rtty international contest forms. look for forms internet fmre address: www.fmre.org.mx. link : concursos/contests.
     (b) an official summary sheet or reasonable facsimile with a signed contest participation disclaimer is required with all entries.
     (c) logs must indicate date, time in utc, band, calls and complete exchanges (sent and received), multipliers and qso points. multipliers should be marked clearly in the log the first time they are worked. send entries to: jose levy.- xe1j. dirección de concursos fmre. clavel 333. colima, col. 28030. mexico. or via internet: «xe1j@ucol.mx»
9.- awards: original certificates will be awarded to the three first places dxcc and mexico stations on each category. also, recognition to first place in each dxcc country and in each mexico state when sufficient score is obtained.
10.- disqualification: for excess duplicate contacts and call sign or exchange errors.
源文档 <http://66.218.69.11/search/cache?p=fmre+rtty&ei=utf-8&fr=yfp-t-501&fp_ip=cn&x=wrt&meta=0&u=www.fmre.org.mx/rules-rtty-2006-english.htm&w=fmre+rtty&d=actexuxsooxs&icp=1&.intl=us>
离线BA7JC
只看该作者 2楼 发表于: 2007-02-03
2007 fmre (xe) rtty contest rules
2.- contest period: first weekend of february. begins 1800 utc saturday, february 3, and ends 1759 utc sunday, february 4, 2007. the participants can operate the full 24 hours.
"all band" only. high power permitted.
6.- exchange:
7.- scoring:
8.- reporting:
entries must be postmarked no later than 30 days after the end of the contest (march 4, 2007). no late entries can be accepted. use fmre rtty international contest forms. look for forms internet fmre address: www.fmre.org.mx. link : concursos/contests.
an official summary sheet or reasonable facsimile with a signed contest participation disclaimer is required with all entries. claimed score is obligatory.
logs must indicate date, time in utc, band, calls and complete exchanges (sent and received), multipliers and qso points. multipliers should be marked clearly in the log the first time they are worked. send entries to: jose levy.- xe1j. dirección de concursos fmre. clavel 333. colima, col. 28030. mexico. or via internet: &laquo;xe1j@ucol.mx&raquo;
states of mexico and abbreviation
aguascalientes = ags baja california = bc baja california sur = bcs campeche = cam
chiapas = chs chihuahua = chh coahuila = coa colima = col
distrito federal = df estado de mexico = emx durango = dgo guanajuato = gto
guerrero = gro hidalgo = hgo jalisco = jal michoacan = mic
morelos = mor nayarit = nay nuevo leon = nl oaxaca = oax
puebla = pue queretaro = qro quintana roo = qtr san luis potosi = slp
sinaloa = sin sonora = son tabasco = tab tamaulipas = tms
tlaxcala = tlx veracruz = ver yucatan = yuc zacatecas = zac
