  • 3177阅读
  • 2回复
A0-27又咋了? [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2007-01-24
ao-27 rejuvenated, back on the air (jan 22, 2007) -- amsat news service reports that ao-27 (eyesat-1) has again been recovered and returned to operation. launched in september 1993, ao-27 had been non-operational for some time. michael wyrick, n3uc, of the ao-27 command team told ans that after addressing problems with the microsat's afsk modem, ground controllers were able to upload operational software. the satellite has been sending telemetry, and the analog transponder has been turned on again. under the current schedule, ao-27 is on during ascending (south-to-north) passes at approximately 30 degrees north latitude, although it's impossible to say when the satellite will be operational for a given location. an initial 20 seconds of telemetry are followed by 5 minutes of analog repeater operation. ao-27 then transmits another 60 seconds of telemetry before shutting down. the satellite carries a mode v/u fm repeater with the uplink at 145.850 mhz and the downlink at 436.795 mhz. "please keep in mind that ao-27 is 13 years old and takes some work to keep going," wyrick advised users. ground controllers are seeking help in logging telemetry from ao-27. visit the logging ao-27 telemetry page for information.
link to this story
离线bd5rv
只看该作者 1楼 发表于: 2007-01-24
说是复活了
离线BD3RJ
只看该作者 2楼 发表于: 2007-01-24
这个卫星寿命购长的啊?!!!
