  • 3392阅读
  • 7回复
请教如何用WL管理TEST卡片? [复制链接]
离线bd2bt
只看楼主 倒序阅读 0楼 发表于: 2007-01-16
请教如何用wl管理test卡片?
离线BA7NQ
只看该作者 1楼 发表于: 2007-01-16
请教如何用wl管理test卡片?
writelog是比赛软件,没有卡片管理的功能。
我们的处理方法是,把每次比赛的log,导出为adif文件格式,再导入到专门卡片管理打印软件,例如bv。
http://www.df3cb.com
离线bd2bt
只看该作者 2楼 发表于: 2007-01-16
谢谢.我在帮助文件里看到有关qsl的说明,好象可以打印并作出标记,还请哪位给翻译一下.
qsl records
the format of the printing on the qsl is controlled by the dialog box available under file qsl comment.
the qsl printing dialog "print rst from field labeled:" list box selects which column in the log will provide the data for printing the rst on the card. when a qsl is printed for a qso that is blank in that selected field, then 599 or 59 is printed on the qsl depending on the mode of the qso.
the text you enter in the "print this on each qsl" box is printed on the fourth line of qsls as they are printed.
and the text you enter in the "comment for records in .qsl file" is added to the .qsl file (see below) the next time you do a file save.
for record keeping, writelog maintains a qsl sent and qsl received flag for each qso. this flag is displayed if the appropriate button is activated under the setup display format menu entry. the sent flag is turned on (and so indicated by an "s" in the display) for every qso for which a qsl is printed. turn it off or on by making the log window active, highlight the desired qso, and type s to toggle the sent flag, r to toggle the received flag. additional qsl information is stored in a .qsl text file at file save time. the additional file is always named with extension qsl, and is always appended to-i.e. writelog doesn't alter existing data in qsl files, although you may do so with an editor
离线bd2bt
只看该作者 3楼 发表于: 2007-01-16
为了我等使用方便请哪位大侠翻译下文,谢谢!
qsl printing
printing qsls is a two step process. first you use the edit mark qso to print qsl to mark each qso that needs a qsl printedall highlighted qsos at the time you select the command get marked. . (or a right click on a qso pops up a menu with a selection to mark to print a qsl). if you have the setup display format set so that qsl information is displayed in the log window, then each qso to have a qsl printed will be marked with a "p" symbol.
then use file print qsls to get a print preview of how your qsls will be printed, and the print command in that window to send the qsls to the printer.
or you can use file qsl labels to file to make a file of the qsos to have qsls printed. (both of these menu options will write only those qsos that have been marked using edit mark qso to print qsl, unless none have been marked, in which case they will write all the qsos in the log.)
if you want just a text file with all the qsl information in it, then use the file print qsl labels to file... entry. the resulting file can be reformatted to match the label layout that you have. the format of the printing on the qsl is controlled by the dialog box available under edit qsl comment.
alternatively, writelog will write the qsos into an adif formatted file using file qsl labels to file, adif. in this case, the label you have entered in file qsl comment is written to the adif file as a column named comment_on_qsl_card. this option is useful for answering a number of qsls in one sitting: go through your qsls, open .wl files as needed to find the corresponding log entries, mark the qsos to print a qsl and when you finish with a .wl file, use file qsl labels to adif which will create an adif file with just those qsos in it. finally, create a new empty log, add a comment_on_qsl_card column to it, and file import all the adi files you created, which will make a log of all the qsos (and only the qsos) that you marked for qsl printing. file print qsls now will print them all.
when you do a file print qsls, the comment from file qsl comment is put on each qsl, unless there is a column in the log named comment_on_qsl_card, in which case the entry from that column is what is printed.
离线bd2bt
只看该作者 4楼 发表于: 2007-01-16
file qsl page setup
use this dialog to tell writelog how to arrange qsls on the printer. if you are using labels with more than one on a page, and if you have an incomplete page of labels to print, use the number of labels to skip on the first page box to skip the holes on the page.
附件: Doc1.doc (0 K) 下载次数:49
离线BA4XA
只看该作者 5楼 发表于: 2007-01-18
谁知道怎么在bv7里,设计打印格式?
离线BA5CW
只看该作者 6楼 发表于: 2007-01-18
bv lable designer 窗口,layout 菜单,layout setting,选择相应的标签纸张,你就能看清楚标签上的打印内容了,内容和位置都是可以改的。
离线bd2bt
只看该作者 7楼 发表于: 2007-01-25
继续求教,想明白上段英文的意思。今天收到第4期会刊,拜读了1rb的翻译文章---
