  • 6296阅读
  • 2回复
IC-751、 IC-751A的常见病维修资料(部分翻译成中文) [复制链接]
离线paging
只看楼主 倒序阅读 0楼 发表于: 2007-01-09
ic-751、 ic-751a的常见病
msn:bg2rn@hotmail.com
unless otherwise noted, the following applies to both models. symptom: distorted, or no rx/tx on one or more bands. problem may be temperature related.
1、在某一个或多个波段无收发,问题可能是温度引起的。
probable cause: 1) bad trimmer capacitors on pll unit. 坏电容
2) noisy variable可变 resistor on pll unit. 坏可调电阻
cure: replace plastic trimmer 整形capacitors c78, c88, c97, and c107 with equivalent等容量的ceramic陶瓷 types. remove excessive过多的腊 wax from around replacement trimmers to prevent wax contamination. we suggest using a 12 pf trimmer capacitor for c97 instead of a 7 pf as listed in the service manual. this will allow you to properly adjust the hpl lock voltage for that band. modification: if variable resistor r43 on the pll unit is the 470 ohm type, replace it with a fixed-value 220 ohm version. if it's the 2.2 k type, replace it with a fixed-value 1.2 k resistor.
remarks: while the pll unit is lifted, we recommend soldering all joints in the regulator section as this area runs hot. also, inspect检查 electrolytic capacitors c128, c129, c132, and c137 in the regulator circuit for discoloration变色caused by overheating. replace all overheated capacitors to prevent future failures.
2、频率显示超出正常范围,调节大旋扭有时出现奇怪字符号,设备工作不正常,频繁启动几次电源开关可能恢复暂时正常,问题可能是温度引起的。
symptom: erratic display i.e., frequency listed will be out of the normal operating range of the radio. rotating the vfo knob may cause strange characters to appear in the display. radio does not work properly. cycling the power switch a few times may restore operation temporarily. problem may be temperature related.
probable causes: 1) cracked破碎的 solder on ram unit is causing logic errors. 补焊
2) program in ram unit is corrupted. ram失效
3) burned/overheated r20 resistor on logic unit is causing low voltage in logic unit. 电阻过热
cure: check for burned r20 resistor (10 ohm, 1/2 watt) on logic unit. if it looks ok, 重焊接resolder cracked solder joints at j1 and j2 connectors on ram unit, then reprogram. if this does not help, then the ram unit must be replaced. if the substitute ram unit does not cure the problem, there may be noise from the dc-dc converter causing the logic unit to glitch失灵. follow instructions for "no frequency display" problem.
3、除了fm模式外,在任何波段无接收音。
symptom: no rx audio in any mode except fm. no tx. unit is not unlocked.
probable cause: pbt oscillator is not running.
cure: verify absence缺乏 of 9.4665 mhz signal at w86 test point on main unit in 751a, or w134 test point in the ic-751. replace faulty缺点的 x7 crystal on main unit in ic-751a, or x5 crystal in the ic-751.
4、usb模式频率工作不稳定。
symptom: frequency instability in usb mode.
probable causes: bad trimmer capacitor in bfo section on main unit. 坏电容
cure: replace plastic trimmer capacitor with a 30 pf ceramic trimmer capacitor and realign.
5、在usb和lsb模式下,有强烈的噪音。
symptom: drastic猛烈的 change in audio frequency response between usb and lsb., i.e. usb audio has too much bass while lsb audio has too much treble三倍. tx frequency response is also poor.
probable cause: misadjustment失误调整 of the bfo or pbt oscillator, or a faulty crystal filter fl-30 (or fl-80 in 751a) on the main unit.
cure: check adjustment of the bfo and pbt oscillator. if these are ok, then the problem is most likely in the filter.
remarks: if the problem is intermittent间歇的, and the radio is an ic-751 (not "a" version), then the ground return path for the -5 v supply between the display and main units may be poor. to cure this, connect a short wire jumper between the unused pin 2 at j2 connector on the display unit and chassis底盘 ground at the closest mounting screw of the main unit pcb. if no spare pin is handy for the connector at j2, the jumper may be soldered to the shield 屏蔽罩of t1 transformer instead.
6、在安装有内部电源工作时,无论接收还是发射,有交流声。
symptom: ac hum翁声 or buzz in transmit and receive audio when an internal power supply is installed.
probable cause: ac is being induced into the pll from the ac wires and power supply case.
cure: twist the ac wires that run from the rear panel to the power switch and route them away from the pll unit. tape them up against the chassis if necessary.
remarks: in some radios, especially older ic-751s, it is not possible to completely eliminate all ac hum when using the internal power supply.
7、没有或者说非常低的接收灵敏度。
symptom: no, or very low rx sensitivity.
probable cause: bad components on rf unit, probable result of rf overload. to verify this, check dc voltages at d47 diode on rf unit. correct voltages are: cathode阴极 side- rx: 8.5 v, tx: 13.8 v. anode阳极 side- rx: 9.0 v, tx: 9.5 v.
cure: replace all of these components on the rf unit: d42, d44, d45, d46, d47 diodes, q15 transistor. check c174 and c179 capacitors for leakiness泄露减少. there may be other failures. unit is not repaired until listed voltages at d47 diode are correct.
8、可接收强信号,但灵敏度偏低。
symptom: distorted不难理解 rx on strong signals. bc band rx sensitivity may be low or marginal.边缘
probable cause: q15 transistor on the rf unit has become leaky.
cure: check and replace q15 transistor. if q15 transistor is leaky, there may be other problems on the rf unit. see cure for rx problem listed above.
9、当连接有室外天线时,不能接收,测量天线坐的芯,对地电压有6v。
symptom: rx disappears when outer conductor of coax is connected to antenna jack. inspection reveals 6 volts dc at the center conductor of the antenna jack.
probable cause: shorted dc-blocking capacitor c40 on the ant sw unit.
cure: replace the capacitor.
remarks: there are probably other problems on the rf unit if this capacitor is bad. check the voltages at d47 diode on the rf unit. radio may have been struck 罢工by lightning or sustained持续 a large rf overload through the antenna jack.
9、当安装有ux-14组件时,在旋转大钮时,经常接收减弱。
symptom: rx cuts消减 out randomly when turning vfo knob in ic-751a with ux-14 installed.
probable cause: incompatibility不兼容 between ux-14 and 751a is causing the pll to unlock.
cure: turn off transceive mode on ux-14 (bank s1, switch #3 to off position).
10、接收到杂乱无章的、象鸟叫的声音。
symptom: hash noise in rx, birdies.
probable causes: 1) voltage regulators on pll unit are oscillating, producing noise on vcc line.
2) overheated components and/or loose screws are causing the power supply to run noisy. 3) noisy dc-dc converter on display unit.
cure: replace overheated c129, c132, and c137 regulator filter capacitors on pll unit. inspect power supply for overheated components, tighten the screws that hold down the reg. unit. don't forget to tighten the screw hidden beneath之下 the wire bundle捆 where the dc output lines leave the case. if none of these help, and radio is a ic-751 (not a version), then the display dc-dc converter may need modification. contact icom technical support for update information.
11、ic-751a没有接收声音,但信号强度能在s表上有显示。
symptom: no receiver audio at all in ic-751a. signals can be seen on s-meter.
probable causes: cracked solder joint on main unit is causing no vcc to the audio amp.
cure: resolder cracked solder joint at l46 coil on main unit. repair damaged foil金属 trace, if necessary. re-route ferrite beads so they will not press down on l46 coil (or any other components) when the top cover is reinstalled.
12、ic-751接收声音偏低。
symptom: rx audio seems low in ic-751.
probable causes: unit needs update to audio amp circuitry on main unit.
cure: contact icom technical support for update bulletin.
13、在所有模式下,均无发射功率,问题在j8插座的可能性较大。
symptom: no tx output in all modes. problem is traced to no output at j8 connector on the rf unit.
probable causes: bad q14 transistor amplifier on rf unit.
cure: replace q14 transistor. there may be other problems on the rf unit. check the dc voltages at d47 diode.
14、在ssb模式下发射,声音刺耳;在高mic增益情况下,发射功率低;cw、rtty、fm看起来正常;所有模式的接收正常。
symptom: distorted/raspy刺耳 sounding ssb tx. average talk power is low, even at higher mic gain levels. cw, rtty and fm seem normal. rx in all modes is ok.
probable causes: 1) external 3rd party power supply needs additional rf decoupling褪偶合.
2) no bias偏置 voltage to driver or pa transistors.
cure: install rf decoupling capacitors on 3rd party power supply (if used). if this does not help, measure voltage at bases of driver and pa transistors in tx ssb mode. should be around 0.67 volts. 0 volts indicates trouble and probably a bad q6 transistor. if problem is intermittent, check for bad solder at the legs of q6 transistor, or d2 diode.
remarks: the driver and pa idle current are set too high in some ic-751s (not a version). align the idle current as per the service manual after repairs are made.
15、当使用内置电源,功率输出逐渐加大时,电源反复关断,而用外置电源,则工作正常。
symptom: when using an internal power supply, the power to the radio flutters搬动 on and off when the tx power output is increased toward maximum. unit runs fine when the internal power supply is substituted with an external supply.
probable causes: cracked solder in the current sensing circuit of the power supply is shutting it down prematurely.
cure: resolder joints at the r26 resistor (0.0012 ohm) inside the power supply.
remarks: this resistor appears as a metal bar soldered to the bottom pc board. solder the edges of the bar before the holes at either end.
16、发射有自激输出。
symptom: tx oscillations/spurious寄生 output.
probable causes: 1) open resistor or faulty electrolytic capacitors on pa unit.
2) pa unit needs modification.
3) bad drivers or pa transistors.
4) burned components on the ant sw unit.
cure: check the value of r22 resistor (4.7 ohms) on pa unit. (this resistor may look ok but still be open.) replace c18 and c25 capacitors on the pa unit if they appear swollen肿涨 or overheated. modification for old ic-751: install a metal film, 220-ohm 1/2 watt resistor parallel to c6 capacitor on pa unit if there isn't one installed already. inspect the d4 area of the ant sw unit and replace any burned components. if none of these solutions solve the problem, disconnect the j10 connector on the rf unit and see if the problem goes away. if it does, then there is a problem with the tx/rx switching on the rf unit. if disconnecting j10 connector doesn't help, then most likely either the drivers or pa transistors are bad, especially if the alc meter deflection偏转 is low.
remarks: the spurious output may also be caused by incorrect band switch voltage to the low-pass filter unit, or even faulty/burned components on the filter unit itself. the above causes should be ruled out first since low-pass filter failures are uncommon in the ic-751(a).
17、在fm模式下工作,ic-751存在断续的、低功率发射问题。
symptom: intermittent断续 low fm tx output power in ic-751.
probable causes: bad relay rl1 on fm unit.
cure: replace bad rl1 relay (221-d009-m).
18、在rtty 、cw模式下没有发射,在ssb 、am模式下正常。
symptom: no tx output at all in rtty or cw modes. ssb and am are ok.
probable causes: bad carrier generator crystal on main unit.
cure: replace bad x1 crystal on main unit.
19、无显示,仅仅有小数点显示,问题反复出现,与元件过热影响有关。
symptom: no frequency display, only decimal points. problem may be intermittent or temperature related.
probable causes: display dc-dc converter has noisy噪音 output.
cure: replace all of the following dried-out electrolytic capacitors on the display unit: c17, c18, c20, c21, c22, c23, c24, and c25. (these capacitors are light yellow when they are new. capacitors that have turned brown are old and dried-out).
remarks: while servicing the dc-dc converter section, be on the lookout for cracked solder joints, as this section of the radio tends往往 to run hot. also, it would be a good idea to reprogram the ram card after servicing the dc-dc section.
20、ic-751在ssb模式下,极低的载波功率输出,与调整不恰当有关。
symptom: poor carrier suppression抑制 in ssb mode in ic-751. will not adjust properly.
probable causes: main unit needs factory update.
21、在ssb模式下发射,声音低而浑浊不清,甚至显示屏关闭。
symptom: low garbled浑浊 audio sound in speaker/headphones in ssb tx, even with monitor turned off.
probable causes: rf feedback. 1) inadequate station ground.
2) external 3rd party power supply needs rf decoupling.
3) main unit needs factory update (ic-751 only).
cure: check station ground. if a 3rd party power supply is being used, add rf decoupling capacitors to output terminals to prevent regulation problems. if the problem occurs in an ic-751, a factory update may need to be installed to the main unit. contact icom tech support for this information.
22、设备看起来一直工作在“sacn”模式下。
symptom: radio seems to be stuck in "scan" mode.
probable causes: bad ic2 chip on the logic unit.
cure: replace ic2 integrated circuit (rp5g01-007).
23、设备内部发出大的高音调的叫声。
symptom: loud, high pitched 斜度squeal尖叫 emanates发出 from inside radio.
probable causes: dc-dc converter transformer has a loose core.磁心松动
cure: replace t1 transformer (to-9) on display unit.
24、vfo调节不稳,但缓慢调节大旋钮时,显示数字不增长。
symptom: vfo tuning is erratic不稳, sometimes skips when changing frequencies or bands. display does not increment smoothly when vfo knob is turned slowly.
probable causes: dirty rotary encoder.
cure: remove white plastic cover from back of rotary encoder and spray clean the carbon track with blue shower solvent. spin vfo knob vigorously while spraying.
remarks: do not let solvent saturate the display unit or allow it to come into contact with the plastic display lens. stuff塞 a paper towe毛巾 between the rotary encoder and display unit to catch spray run-off.
25、显示屏上反复出现缺字段或模式指示符的故障。
symptom: missing segments or mode indicators on display. problem may be intermittent.
probable causes: bad connection between logic and display units.
cure: check the connectors j5 and j13 on the logic unit where the flex cables to the display unit are attached. if they look ok, and none of their connector spring contacts flattened, replace the flex cables.
26、低mic增益的问题。
symptom: low mic gain when using heil mic element.
cure: install modification: in 751, change value of r264 resistor on main unit to 200 k. in 751a, change value of r21 resistor on af-vr unit to 47 k.
离线BG6QCB
只看该作者 1楼 发表于: 2007-01-09
能否把它全部翻译出来谢谢了。
离线paging
只看该作者 2楼 发表于: 2007-01-10
凑呵看吧,老夫翻译上文就累了一下午,颈椎这个痛啊!
