  • 2036阅读
  • 2回复
基础知识3 [复制链接]
离线paging
只看楼主 倒序阅读 0楼 发表于: 2006-12-01
when you make a rf or if amplifier in your transmitter,and if you feel "this driver must make more 3db output, or else that cannot drive the final linear-amplifier". in that case, please make driver-transistor parallel like the figure. in some case the parallel transistor makes more output than the single of it
离线paging
只看该作者 1楼 发表于: 2006-12-01
Vout=(1.9N-0.7) volts [N=number of the LED]
vout=(1.9n-0.7) volts [n=number of the led]
离线yake10
只看该作者 2楼 发表于: 2006-12-02
能不能先翻个面?
