  • 4165阅读
  • 9回复
都是做东西,6CG已经成功登陆美国市场了 [复制链接]
离线BD3RJ
只看楼主 倒序阅读 0楼 发表于: 2006-11-22
这个MFJ926就是6CG的产品
http://www.mfjenterprises.com/products.php?prodid=mfj-926
离线soom
只看该作者 1楼 发表于: 2006-11-23
顶!
weather-sealed for outdoor or marine use -- tough and durable!
mfj-926 automatic antenna tuner covers the entire hf band, 1.6-30 mhz. it handles 200 watts pep maximum with a 10 watts minimum input power. mfj-926 is weather-sealed for outdoor or marine use outside at the base of your ham station antenna -- a durable hard plastic cover and chassis plus an inner lip black rubber seal keeps the interior electronics cool and dry for many years of dependable use. mfj-926 has a very fast-tuning: initial tuning is less than 2 seconds and less than .2 seconds tuning from memory. it has 200 memory channels. tunes 6 to 30 mhz with wire greater than 8 feet and tunes 1.6-30 mhz with wire greater than 27 feet. for 50 ohm transceivers. requires 13.8 vdc at 1.5 amps. sleek, sexy and compact -- measures just 91/4wx 141/4hx3d inches. weighs just 4 pounds. this tuner is built-to-last the elements! it is weather-sealed for outdoor or marine use. all connections are double protected with rubber sealing, entire cabinet is specially weather sealed with internal rubber lip. includes mounting holes with metal strap on each end for easy securing.
离线BA8MM
只看该作者 2楼 发表于: 2006-11-23
很不错的说,关注~
离线BA6BF
只看该作者 3楼 发表于: 2006-11-23
这不是mfj公司的产品吗?
离线BD3RJ
只看该作者 4楼 发表于: 2006-11-23
与其在国内受气挣小钱,还不如出去闯一下.
离线BD7JAC
只看该作者 5楼 发表于: 2006-11-23
贴牌生产,据说日本某知名天线不也是找其他厂家加工的吗?关键是把住自己品牌的品质关,别让人家坏了自己名声便可。这样生产、销售方都可获得双赢。
不过生产方多数在羽翼丰满之后都会再做自己的品牌或者改变个外形和型号给第二家第三家贴牌,这种情况在商品中见得多,希望不远将来可以看到6cg自己打出的中国品牌。
离线BG4AGP
只看该作者 6楼 发表于: 2006-11-23
可喜可贺!
1) 美国卖的东西,折算成rmb可能比国内卖还便宜,例如dvd机和卫星接收机
2)mfj有1年no matter what保修/更换,最终可能退货到生产商手中
3)贴图是mfj-926的外观和内部图,是否和6cg的一样?
离线神秘色彩
只看该作者 7楼 发表于: 2006-11-24
mfj-926
price: $399.95
离线BD6QI
只看该作者 8楼 发表于: 2006-11-25
3rj又他奶奶的扯*
离线BD3RJ
只看该作者 9楼 发表于: 2006-11-27
3rj又他奶奶的扯*
你又嫉妒啦?
